Question about OKI MICROLINE 320 Turbo Matrix Printer
Okidata 320 Turbo randomly prints (PJL USTATUS TIMED = 10 12345X12345XPJL) while printing documents.
5 Suggested Answers
SOURCE: Oki 320 turbo alarm light
Check/clean the carriage sensor. This part is under the head/ribbon holder assembly. You should also check the tensioner to the black guide/railings when the carriage assembly runs. This is the one with the gear.
Efi
Posted on Nov 12, 2007
SOURCE: Okidata 320 Turbo print head carriage slamming
There is a Optical sensor under the print head drive assy. You might have dust blocking this sensor.
Posted on Feb 14, 2008
SOURCE: Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
Posted on May 23, 2008
Sphynkter
  • 221 Answers
SOURCE: Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
I just had this exact same problem - same printer, same Jetdirect model. Mine turned out to be the parallel printer mode setting inside the JetDirect. I connected to the configuraiton page by IP, then changed the Parallel mode from "AUTO" to "Centronics", tested it, and it worked fine after that. Hope it helps.
Posted on May 11, 2009
Printer spit out the following automically @PJL INFO PAGECOUNT
Bob, Not sure if it will help you now but I just ran into the problem you had. I was getting an @PJL not @PJL but nonetheless...
In my case the problem happened at the same time each day, this helped in troubleshooting. In order to track this down, at the times that the errors occur, which was the same time each day, shutdown/turn off HALF of your PC'S. If the printout still occurred at the normal times, then the problem was with the OTHER (currently running PC'S), do this until you have it down to one PC that was causing the problem.
find out what the process is that is running.
run microsoft windows task manager and show all processes BUT microsoft processes.
you will see a process that is similar, if not identical, to FC Print Track, you will need to kill it off. Their cause was they had someone come in to service one of his xerox copiers, the tech put a program on the PC to track the amount of toner the copier used, this is what was causing the errors on the okidata printers. Contact the copier repair person and have them uninstall the software that was put on.
Jun 03, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
I have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Nov 09, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
OKIDATA 490 printers started printing the following and there were no changes made to any software/network/hardware. The emulation is and has always been Epson LQ - ''12345X@PJL @PJL INFO PAGECOUNT...
We had this same problem and discovered that some vendor installed a program called "Print Track" which discovered every printer on the network using port 9100 and sent a query for how many pages were printed. Removing this software from the offending PC resolved this issue. We used the "job log" from one of the Okidata printers to find the IP address of the PC that was causing this.
Jul 07, 2009 | Computers & Internet
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 320 Turbo -- Unclear characters in output
If it is not the ribbon, you may have to replace the print head.
Genuine Okidata Print Head
Mfr Part #:
50063802
Hope that helps...
Jun 21, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printing jibberish
Hello babytenbucks,
I can help you setup your Okidata 320 printer.
Connect the printer to the printer port coming off the motherboard. Usually it's colored pink. Also known as LPT1.
If your operating system is Win XP do this. Open Control panel, open Printer & Faxes. Click File, Add new printer.
Uncheck, automatically detect & install my plug & play printer.
Click Next. Allow it to use LPT1. Click next.
There are two windows here. On the left is Manufacture on the right is Printers. Scroll through Manufacture till you find
Okidata. Under Printer, scroll down till you see Okidata ML 320 Turbo/D (IBM), click next. You can give it a new name or leave it as is. Make the 320 the default printer. You can let it print a test page. Either way re-start the system. Try another test page.
Click the link below for a .pdf file which is the manual for your
Okidata 320 Turbo.
http://www.precision.com/manuals/Okidata_ML320_321_Manual.pdf
If you do not have Adobe's pdf reader download it from the next link.
http://adobe-reader.download-express.org/now/
babytenbucks, if your still have any trouble please just post back & we'll get it solved.
Good day!
& please vote...
Feb 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Feb 07, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
88 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
