Question about HP Compaq 1701 17" Flat Panel LCD Monitor
My monitor boots up with a white screen only - HP Compaq 1701 17" Flat Panel LCD Monitor
    Genius:
  • 1,288 Answers
Could be video card, cable or malfunction in the monitor, try another monitor to eliminate at least the possibility of it being a graphics card issue, thereafter, check connections from the computer to the monitor, if that fails, I'd suggest taking to a TV repairman
Posted on Dec 28, 2010
2 Suggested Answers
bilua
  • 102 Answers
SOURCE: monitor white screen
Unplug the harddrive and see if you can boot up into BIOS. A bios virus is almost unheard-of.
If it will boot then re-connect the harddrive and see if you can get it to boot into safemode. Press F8 during bootup to enter safemode. Run virus scan from there.
If it will not boot at all with the harddrive connected then suggest you slave the drive in another working system and see if it causes a problem there. If so the problem is hardware related. If the other machine will boot with this drive as slave then you may be able to run a virus scan on it from the host machine but perhaps you should consider retrieving anything important and format the drive. Put it back where it came from and reinstal windows.
It must be helpful to you
Thanks
Posted on Aug 17, 2009
No display it is power is on
Hook up to external monitor .. Does the pre boot screen pop up (black and white writing at start ) ? If display runs on external monitor then your screen needs replacing usually or if you see a vague image on laptop screen then inverter or backlight is gone .. if no display on external and no pre boot screen probably the graphics chip on laptop has malfunctioned.
Dec 15, 2014 | Acer AL2021M (Silver) 20" LCD Monitor
Al1916w acer monitor screen coming white
If you hold a flashlight to the screen when you turn on the laptop,do you see your windows booting up in the dark?
Aug 13, 2014 | Acer Computers & Internet
Blank screen/white screen
Plug in a monitor to the VGA connector on the side. The white screen usually indicates a failed inverter. By using an external monitor you will cut down the likely causes.
Apr 30, 2013 | HP Compaq for Presario V3000 Motherboard
What would cause monitor to show white screen when pc is booted up?
Will the monitor go into it's own config screen ? If not, it could be defective. You said it displayed a white screen so it is not likely that the brightness control is turned way down.
Check that the monitor is connected correctly to the system. Try another monitor that is known to be good. Does the monitor work on another system, say a laptop or another desktop?
Windows will boot up without a monitor and if you are running any servers on it, you can try to connect over your LAN. If the computer takes it's IP address from a local router, you can check the router status screens to see if the address is in use. That would prove Windows is running and that the monitor could be the problem.
Used monitors are not expensive these days so they are easy to replace. You should have multiple monitors anyway. This is the 21st century, not the twentieth when screen size revealed your pay grade in the organization.
Aug 16, 2012 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
How to fix emachines netbook , model 250-1162 the 10.1 LED LCD screen will not turn on
Is it the screen or the laptop?
Have you plugged an external monitor to see if its booting?
If it is booting with an external monitor, you may need a replacement screen (google your model and replacement screen)
If its not booting, you could try this.....
http://www.fixya.com/support/r5335055-unable_start_windows
Jul 18, 2010 | Acer eMachines eM2501162 Netbook
My laptop is compal n30n3 when i start my laptop its screen gets white and remains white
Try booting up from a recovery boot up CD. This will test whether it is a hardware or software issue. If there's no white screen with the CD boot, then it could be a malware or some other driver/program corruption. If however, the white screen still shows up during a CD boot, then it could be an overheating issue due to a cooling fan blockage (the fan may not turn on at all). Or it could be the monitor itself in which case I'd suggest you try connecting the laptop to an external (LCD) monitor and see if the problem then persists. Hope it all goes well for you. If any of my suggestions work, please do rate me. Thanks
Feb 04, 2010 | Compal Computers & Internet
White Vertical Band on Screen
Hi...there,
It's seems you got a busted screen panel...
Dec 15, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
HP Compaq 1701 17" Flat Panel LCD Monitor Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
