Question about Hotpoint Dryers
My dryer starts to squek real loud when it is running
    Top Expert:
  • Hotpoint Master
  • 80,417 Answers
The source of this noise is usualy the dryer drum drive belt.
  • Unplug the electrical cord before replacing the dryer belt.
  • 2
    Pull open the dryer door and locate the screws underneath the top lip that secure the top of the dryer.
  • 3
    Unfasten the screws holding the top on with a screwdriver and lift the top, flipping it back and resting it on the hinges.
  • 4
    Unfasten the holding the front panel on the cabinet, using a screwdriver. These screws are at the top on the inside of the panel.
  • 5
    Disconnect the door switch wires on the back of the front panel by hand, pulling the connector straight out off the electrical prongs and setting the front panel aside.
  • 6
    Locate the idler arm pulley next to the motor on the bottom of the cabinet near the back and push the idler arm forward to relieve the tension on the old belt.
  • 7
    Remove the old belt from around the idler and motor pulleys as well as from around the dryer drum and take the belt out of the dryer cabinet.
  • 8
    Place the new dryer belt around the drum in the center of the cabinet, fitting the belt inside the V-groove in the center of the drum, and lay the rest of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
  • 9
    Move the idler arm forward to allow room for the belt and thread the end of the new belt around the idler arm pulley and over the motor pulley, letting the idler arm move back to apply tension to the new belt. Check the new belt over to verify that it is lined up correctly in the V-groove on the drum and around the pulleys and that there are no twists in the belt.
  • 10
    Place the front panel back on the dryer cabinet, securing it with the screws on the top of the panel with a screwdriver, and plug the door switch wires back into the electrical prongs, pressing the switch wires on by hand on the back of the front panel.
  • 11
    Lower the top of the dryer back down onto the cabinet and secure it with the screws underneath the lip of the front panel.
  • 12
    Plug the electrical cord of the Hotpoint dryer into the electrical outlet.
  • Posted on Dec 28, 2010
    The dryer has a very loud shrieking squeking
    Hi dear.It's bearing problem & needs to be replaced.I hope that helps.Thanks.
    Feb 13, 2011 | Dryers
    Dryer is making loud squeking noise. changed rollers did not fix problem
    Sorry to read about your problem, I hope this helps you out.
    you must have a drum bearing issue
    I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
    Dec 24, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
    My dryer has a loud squek when it starts and goes for about one minute and then quits. What should I do?
    That is probably a roller or that crappy idler that comes in some models. You need to break it down and do a looksee. Here is a nice pictoral: KENMORE DRYER
    Bonus stuff here
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Aug 15, 2010 | Kenmore 62802 Electric Dryer
    My Kenmore front loading dryer squeaks loud now when I start drying clothes. I clean up around the dryer and took the vent off and cleaned the lint and particles out of the vent and vent tube.sometimes it...
    either the bottom pulley or the rollers are whats making the squeking noise you can buy a dryer belt kit which comes with two rollers pulley and a new belt for around 25-30 from marcone appliance
    Jul 12, 2010 | Dryers
    Very loud squeking from dryer
    Most of the time that dryer drum bearing WE3X75 is the problem. You need to remove the drum to replace it.
    Feb 08, 2010 | Dryers
    Squeking noise
    Here is a handy GUIDE
    Jun 26, 2009 | GE DBSR453EBWW Electric Dryer
    Dryer body very hot, loud squeking, soot from ball in back
    I would replace the high limit control and the thermostat to be on the safe side. There is a real danger of burning the house down.
    Nov 25, 2008 | Kenmore 62602 Electric Dryer
    Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
    Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
    Oct 19, 2008 | Magic Chef CYG4000AWW Gas Dryer
    Dryers Logo
    137 people viewed this question
    Top Hotpoint Dryers Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
