Question about Samsung HTTZ522T Theater System
Hdmi input from does not receive signal. Have connected output from cable box directly to TV and signal is there. Unit does not pick up signal. HDMI output from component works fine, as I can play DVDs and CD's.
I have the same issue. I've opened up several tickets with Samsung tech support. I'm concluding that it's the BluRay rcvr has bad hdmi input & output circuitry. I'm returning mine to Best Buy where I purchased it for a replacement. Before I leave the store, I'm going to make sure that the replacement unit's hdmi inputs & outputs work @ the store.
Posted on Dec 29, 2010
Why did I lose the video signal from the receiver to the TV?
I assume you have tried both hdmi cables from box to tv. If both works good.Cconnect to amp. Connect cable box also on other hdmi inputs like bd, dvd, etc to make sure the spesific port is not faulty. If still no picture try to lower hdmi video display on cable box. You amp may not be able to display the higher resolution.
May 06, 2015 | Onkyo TX-NR535 Receiver 5.2 Channels, 65...
What is the correct wiring connection using hdmi and optical cables from a lcd tv to yamaha yht292
If you tv has a hdmi input, connect it to the Yahama receiver hdmi output (out). If you are using a satellite receiver, digital converter, or a cable box with hdmi output(s), connect them to the Yahama hdmi input (in) for video and audio signals. If the above box(es) do not have hdmi capabilities, then connect the box(es) to the Yahama with either component (preferred), svideo, or yellow RCA compsite video jack (least preferred) for the video signal. For audio, connect the box(es) with optical or coax (preferred) or left-right-center-front-rear patch cords.
It really all depends on what outputs are available on the boxes and/or signal source(s).
Hope this helps,
Rhais
Sep 19, 2009 | Yamaha YHT-390 Theater System
Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Jun 05, 2009 | Yamaha RX-V463 Receiver
Connection problem with HDMI cables on Denon AVR-589
I want to clairify you install, you sat you have I an HDMI cable running from the Time Warner Cable box to the AVR-589, going in to the TV/CBL input. From the Denon AVR-589, I have an HDMI cable running from the output to my Toshiba RV525U television.
Check the connection at the TV, if as you indicated above you have an HDMI cable from the HDMI out from the Denon to an HDMI output on the TV, if this is the case you need to have that HDMI cable plugged into an input on the TV not an output
Feb 27, 2009 | Denon AVR588 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
Jan 14, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
Samsung HTTZ522T Theater System Logo
188 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
