Question about Amana 24 in. ADB1500AWS Stainless Steel Dishwasher
My Amana SofSound 2 (model DWA33AL) is not draining and I am unable to find an owner's manual so that I can take it apart and find the problem. Can anyone provide some suggestions? The ones that are posted do not apply to this model Thank you for your help
SOURCE: Amana Sofsound II Dishwasher, heated
push the button for a different option: it's like a radio button in Hypercard: one must be chosen, and choosing one will "unselect" the others.
Posted on Aug 14, 2009
  • 71 Answers
SOURCE: amana sofsound II will not drain I can see nothing
There is a solenoid that needs to move for the machine to drain. The solenoid is located at or very near the drain hose under the machine. It should have two wires going to it.
The solenoid won't work if...
There is something inside the pipe preventing the solenoid from moving OR
The wiring to the solenoid is broken/worn out, OR
The controller is not telling the solenoid to move OR
The solenoid is broken/worn out.
If you remove the drain hose from the machine you should be able to check if anything is blocking the valve.
Check for power (use a voltmeter but be careful it is probably 110Volts) to the solenoid when the machine should be draining. This verifies the controller and the wiring.
Check the resistance of the solenoid.
Many dishwashers have the wiring diagram in a little envelope under the machine. Take the panel off below the door and look around for any paper. Sometimes the resistance values for the solenoid (and other components) is listed on the wiring diagram.
Be careful and turn off the power when necessary.
Posted on Jan 04, 2010
  • 1416 Answers
SOURCE: My Amana sofsound dishwasher is
When you open the washing machine lid and discover it full of water, it means it didn't drain before the spin cycle. You may be confronted with a tub full of sopping wet clothes at an inconvenient time, but don't panic and call a repairman. Chances are the trouble is with the drain hose or the pump and you can fix it yourself with just a few simple tools.
Difficulty: Moderately Challenging INSTRUCTION BELOW.
  1. 1 Look at the drain hose to make sure it isn't kinked or clogged. If there is a piece of clothing lodged in there, clear away the hose from the pump and yank the clothing out.
  2. 2 Take a look at the switch under the lid of the washing machine. If it doesn't click when you press it, it may be broken and the washer may stop during the drain cycle. Call a repairman to repair or replace the switch.
  3. 3 Examine the clothes tub and the outer tub of the washer for anything that may be stuck in there.
  4. 4 Open the main access panel of the washer and take out the large rubber hose connecting the pump to the lower part of the outer tub.
  5. 5 Check to see if there is a piece of clothing stuck in there. If so, use a pair of needle-nose pliers to grab the clothing and pull it through the port. If it is difficult to reach, you will need to take out the agitator, the top part of the outer cylinder, and the interior tub to grab it. Unless you have special skills and tools, you may want to call a repairman.
  6. 6 Inspect the pump for a clog or frozen pulley. To check if the pulley is broken or frozen, take the pump out and attempt to turn it manually with your hands. If it's stiff or appears frozen, install a new pump.
THANKS.
Posted on Oct 23, 2010
  • 1416 Answers
SOURCE: My Amana sofsound dishwasher is not draining
Thanks for visiting .
Daniel S
  • 4323 Answers
SOURCE: Flashing lights on Amana SofSound...nothing will
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 16, 2011
Where is the filter located on an unidentified washing machine?
Inlet or drain-filter????
ow To Clean Your Washing Machine Filter - YouTube
? 2:43
https://www.youtube.com/watch?v=Mmvr4Xn2W1w
Jun 17, 2012 - Uploaded by Kenneth Watt
For more washing machine help please see our website at ... Far more helpful than the wretched manual that came with ourwashing machine. :) ... I just did this to my washing machine, the filter was blocked up with wool, ...
[PDF]Owner's Manual
shop.amana.com/assets/pdfs/literature/40068302.PDF
manual stays with washer. Contents. Important ... Keep this manual and your sales receipt together in a safe place for ... Amana Appliances offers long-term.
How to Empty and Clean Out Your Washer's Drain Pump Filter
www.homesavvyatoz.com/washer-drain-pump-filter/
Oct 13, 2011 - Do you have a front load clothes washing machine? Have you every wondered what happens to that spare change you occasionally forget to ...
Amana NFW7300WW Washer Locate drain pump filter
Dec 30, 2015 | Washing Machines
Amana owners manuals
What model Amana air conditioner?
Jul 15, 2013 | Heating & Cooling
My Amana sofsound dishwasher is not cleaning the dishes
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 22, 2012 | Amana 24 in. ADB1500AWS Stainless Steel...
How to change belt on Amana SofSound 1 commercial quality washer
You call a technician. This is something that probably shouldn't be instructed in just text.
Nov 14, 2012 | Washing Machines
Oct 23, 2010 | Amana 24 in. ADB1500AWS Stainless Steel...
My Amana sofsound dishwasher is not draining.
THANKS.
Sandy grit left on dishes.
I was having a different issue with the same model but I think my issues solution might help yours. My dishwasher was not draining properly. It was the air gap that sits on top of the counter by the sink. It was clogged. We removed it and cleaned it out. Maybe if your air gap is slightly clogged as well it is not allowing the dirty water to flow out properly leaving you with gritty dishes. Hope this helps.
Jul 20, 2010 | Amana 24 in. ADB1200AW Built-In Dishwasher
HOW CAN I GET A REPLACEMENT OWNER'S MANUAL FOR AN AMANA HEAT PUMP, MODE APH1536M41? MY INSTALLER "BORROWED" MINE AND DOESN'T SEEM INCLINED TO GIVE IT BACK TO ME.
Technical Manual
Warranty
Spec Info
And here is some contact information. I was unable to locate a manual (owner's manual) online for you, but perhaps one of the following contacts can help you............
CONTACT: AirEase; attn Coushatta Fuller, 803-738-4114; 972-808-8450 (fax); coushatta.fuller@alliedair.com; www.alliedair.com.
TECHNICAL SUPPORT: Available 7 a.m.-7 p.m. Central, Monday-Friday, via Goodman's technical hotline, 888-593-9988.
Apr 03, 2010 | Amana Heating & Cooling
Amana sofsound II will not drain I can see nothing
Jan 04, 2010 | Dishwashers
Amana Sofsound II Dishwasher, heated dry display light won't shut off
Aug 23, 2008 | Amana Dishwashers
Amana 24 in. ADB1500AWS Stainless Steel Dishwasher Logo
87 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Charles T Nevin
Charles T Nevin
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
