How do I remove the timer knob on a Kleenmaid LWK 74 washing machine?
  • 38 Answers
SOURCE: washing machine
take the top piece off by hand. Below that should be a plastic cover hiding a bolt. Lift up this plastic cover and remove bolt. Lift agitator up. Might have to wiggle it a bit.
Posted on Jun 22, 2008
  • 1028 Answers
SOURCE: Sears Kenmore Elite washing Machine.
probably new timer part inside timer that locks shaft when pushed inis not grabbing and locking
Posted on Jul 17, 2008
duby1990
  • 367 Answers
SOURCE: how does the timer knob come off
Push the knob to the off position then spin it to the left. it should just screw off. There is only one or two models that dont. To acces the timer you have to take the 2 screws out of the corners of the control panel (philips) They are either on the front or the back of the machine, left and right corners. The whole control panel will pull forward and then lift up and flip back. Theres the timer. Any more questions let me know.
Posted on Nov 21, 2008
  • 72 Answers
SOURCE: Roper top load washing machine. Fills with water and then stops
Check out the drain pump, it is not uncommon stuff gets stuck in the impeller preventing it to do its work.
Also check out the drain filter and that the drain tube is not clogged. Very common causes of trouble in my experience and would give symptoms like you describe..
A good method to check if the output side is clear may seem a little gross but... take a deep breath and blow through the drain tube from the other end (taking whatever precautions you feel like).... It should be possible and if you can't, you know where the problem is.
Posted on May 21, 2009
  • 1937 Answers
SOURCE: removeing timer switch knob
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
The knob screws onto a medal shaft that goes through the timer.
Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
Then you simply have to disconnect the timer.
The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
Posted on Jun 08, 2010
I have a kleenmaid washing machine its about 30 yrs old and still runs well but it is now leaking oil from under the adjitator how do i fix it.
Sounds like the seal for the transmission is leaking oil through the seal. You will need to remove the tub or turn the machine upside down to remove the transmission and replace the seal. That is if the seal is still made.
Nov 17, 2015 | Washing Machines
How to replace the timer on a Kenmore 90 series washing machine?
The timer on a washing Kenmore washing machine is the brains of the unit. The timer controls how long the clothes are to be washed, rinsed, spun and dried. The timer is located behind the timer knob in the main control panel. If the timer fails, it can be replaced with just a few hand tools.
1 Unplug the washing machine's cord from the electrical outlet.
2 Remove the two screws securing the main-panel end caps with a Phillips-head screwdriver. Lift the main panel up and rotate it backward so the inside of the panel is exposed. If your model does not have end caps, slide a putty knife between the main panel and the washing machine's top, then pry up to free the panel from its retaining clips.
3 Turn the knob by hand from one side while looking at the back of the timer from the other side. You should see the timer knob's shaft turning. Grasp the black plastic locking tab in the center of the timer knob's shaft with a pair of needle-nose pliers and pull it out. You should feel a click.
4 Pull the timer knob off of its shaft. You may need to hold the locking tab with the pliers as you do this. Remove the trim plate from under the knob.
5 Unplug the wiring connector from the back of the timer. Remove the screws securing the timer to the main panel with a nut driver and remove the timer.
6 Install the new timer into the panel and secure it with the screws, using a nut driver. Install the timer's trim plate and wire connector.
7 Install the knob onto the timer's shaft. Make sure the locking tab is still pulled out before installing the knob. Once the knob is pushed onto the shaft, hold the knob with one hand while pushing the locking tab in from the other side. You should feel it click into position.
8 Reinstall the main panel and end caps, if applicable. Plug in the electrical cord and run the washer on various wash and rinse cycles to test that the timer is working.
Things You Will Need
  • Phillips-head screwdriver
  • Putty knife
  • Nut driver
  • Needle-nose pliers
  • Timer
Warning
  • Pulling or installing the timer knob without first pulling the locking tab can break the tab, the shaft or the knob.
Apr 24, 2014 | Kenmore 15944 Top Load Washer
Kleenmaid top loader replace timer
Kleenmaid timers do fail from time to time. Reconditioned timers are a viable remedy and not as expensive as new ones. Depending on where in oz you are, a tech will have to sight the faulty timer to ensure the correct replacement unit. You can't rely on model number alone........Nomess
Apr 07, 2010 | Washing Machines
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
I have a 15 year old Kleenmaid Heavy Duty washing machine, the wash selection knob has broken, where can i get another in the Newcastle area. Second hand will be fine. Lyn
IT IS TIME TO BUY A NEW WASHING MACHINE. IT MAY COST MORE, BUT TRUST ME, YOU WILL FEEL BETTER KNOWING YOU BOUGHT A NEW WASHER. THE KNOB ON THE OLD ONE THAT IS BROKEN, CAN BE REPLACED, BUT I DON'T KNOW HOW. GOOD LUCK.
RODNEY
May 14, 2009 | Washing Machines
Kleenmaid KAW 693W-3050 7KG Washer
open the control panel use pliers on the back of the timer shaft then try to remove the knob
Aug 15, 2008 | Washing Machines
Replacing timer
  • push the timer in and turn it counter clockwise. this should unscrew it.
  • if that does not work, check the back of the timer for a black plastic tab. pull it out to unlock the timer knob from the timer.
  • there are many different styles of timer knobs.
Jun 29, 2008 | Frigidaire GLWS1349A Top Load Washer
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
