Question about Sanyo DS31520 31" TV
I'm trying to connect an antenna to this Sanyo DS 25320. Do I need a converter box?
5 Suggested Answers
SOURCE: Sanyo DS31590 and converter box
I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
Good Luck
Posted on Feb 29, 2008
  • 520 Answers
SOURCE: trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Posted on Jun 28, 2008
SOURCE: How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Posted on Jan 01, 2009
  • 83 Answers
SOURCE: Is my Sanyo DS20930 digital ready or will it need a converter box
if it was bought prior to 2005 it may not be, if it has freeview/freesat in it then it will be digital ready or if you have sky/virgin then you will be ok
Posted on Jan 24, 2009
Can I program a ds converter box with an rca universal remote ? I only get 4 channels. The remote was given to me and it did not come with a remote.
Check the antenna connection to the DS Box. If the external antenna is not pointed to the majority of the station transmitters, the DS box may indeed only "see" 4 channels with sufficient signal strength.
Mar 09, 2015 | RCA Televison & Video
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
Need operators manuel for DS 25320
hi,
I have the owners manual for Sanyo DS 25320 with me in pdf format. If you can give your email address then I will sent the manual to you. Can't upload the file through this site as it is a pdf file.
ok
Sep 21, 2011 | Televison & Video
Sanyo TV, older model, tv converter box, terk antenna, will not p
DP models are already digital there is no need of a converter box. connect a outdoor antenna to the tv directly.
Mar 04, 2009 | Sanyo DP32746 32 in. LCD Television
Don't know where the antenna input is on my tv
You can download the manual for this TV from Sanyo here:
http://www.sanyotv.com/CLT2054%20(E)%205071--.pdf
It has all the hookup information for you.
All the input jacks are on the rear of the set, and they are pretty clearly labeled.
You can connect the converter box two ways. One is to use the RF output from the converter to the antenna input on the rear of the TV. Then set the TV to channel 3 or 4, depending on the converter box setting.
The second method, which is better, is to connect the direct video and audio outputs from the converter box to one of the TV's A/V inputs. The cable you need is usually supplied with the converter box. Just follow the color-coded jacks at both ends: red and white for right and left channel audio, yellow for video. Then set the TV to that source. This will give better quality picture and sound from the box.
Please take a moment to rate this solution if it has helped you. Thanks for asking here!
Feb 07, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Sanyo DS31590 31'' TV DO I NEED CONVERTER BOX?
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Nov 21, 2008 | Sanyo DS31590 31" TV
DTV Compatible
If you do not have cable or satellite then you will need a converter box for Antenna only those who will be using antenna for signal will need box.
Oct 30, 2008 | Sanyo DS20930 20" TV
Digital capable
You will only need the converter box if you use an antenna. If you have a cable tv service, they will do the conversion on their end.
Jul 19, 2008 | Sanyo DS31520 31" TV
Trouble receiving local channels on TV using new Magnavox converter box
Jun 27, 2008 | Sanyo DS27910 27" TV
Sanyo DS31520 31" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
