Question about Samsung Eternity Cell Phone
Well i was trying to do my pin number so no one could get on to it without a code and im not sure what i pressed im really confused but they have asked me for a PUK number and im not sure what that is plz help
    Sergeant:
  • 171 Answers
The puk code is provided by the service provider. It comes with your sim card. So all you have to do is just call the customer care center of your service provider and ask for the puk code of your number. They should be able to provide you with it. The pin code also comes with your sim card. You should have asked the service provider the very moment your phone requested it. Anyway now ask for your puk code.
Good Luck
Posted on Dec 31, 2010
Turn off alarm without key fob
First off, you need to know the PIN.
Setting the PIN is as follows:
Think of a five-digit PIN, and write it down. Think of this set of numbers as a password for starting your bike and disabling the alarm during those times when you don't have your fob.
Turn the ignition key on, then off, then on, then off, then on again. Then press the left turn-signal switch twice. Press the right turn-signal switch once, and the current PIN should appear in your odometer.
Be sure the first digit of the PIN is flashing. Enter the first digit of your new PIN by pressing the left turn signal to cycle through the numbers.
Press the right turn signal once to switch to the second digit, and select the correct number with the left turn signal. Repeat this process until your new PIN is entered correctly.
Press the right turn signal once, then turn the ignition key off to save the PIN you selected.
Now, how to disable:
Let's assume for simplicity that your code is set at 31313 and you wish to use the manual disarm of the security system using the directional switches as if you lost your fob and cannot disarm the system.
Your security system will disarm the bike and it cannot be started without deactivating the system first.
If you are unsure of what the manual code is refer to the top of this page or check with your dealer and set one if it has not been set by them.
Again this is based on your code being 31313 just to make it easier to understand.
1. Turn the ignition to Accessory.
2. Press both turn signals. (security light should flash rapidly)
3. Press left turn signal button 3 times (the 1st "3" of the PIN). Press right turn signal button 1 time (to "set" the code number).
4. Press left turn signal button 1 time (2nd number of PIN). Press right turn signal button 1 time.
5. Press left turn signal button 3 times. Press right turn signal button 1 time.
6. Press left turn signal button 1 time. Press right turn signal button 1 time.
7. Press left turn signal button 3 times. Press right turn signal button 1 time.
Security light stops flashing and security system is disarmed.
If you've changed the number, use your new number instead of 31313.
Dec 25, 2013 | Harley Davidson Motorcycles
Forgot pin code for grundig gud300hd freeview hd box
Ok this info does not seem to be anywhere so here goes.....
Grundig gud300hd and others of same build alba ect...... set top box pin reset
UNLOCK CODE1. Press MENU and go to Settings and press OK.
2. Go to Parental Control and press OK. The 'Enter the PIN Code' menu will be displayed.
3. Press i (information) button once then enter 4000.
4. Go to Change PIN Code and press OK.
5. Press i (information) button once then enter 4000.
6. When it prompts for New PIN enter the desired PIN number using 0~9 keys. Enter it again to confirm.
hope it helps
Nov 24, 2012 | Grundig Televison & Video
It started out neending a pin number for parental control that I haqve NO memory of putting in. I tried every numeric password that I have ever used, and they were all incorrect. It then asked when I...
put that you forgot your password, then it will give you a confirmation number. go to the website below and put the confirmation number and date on your time zone. ( just for them to know where the wii console if from)
and you will get the reset code for your wii.
http://wii.marcansoft.com/parental.psp
Jun 17, 2010 | Nintendo Wii Console
Beringher CT100.. X Pattern on LED grid when testing an xlr cable
This site has diagrams... not the best but clear enough.
PLEASE note that the pin numbering is kind of goofy... The pins of both the male and female tie to identical pin numbers.
You PROBABLY have misread the numbering at one end.
A KEY thing is to get the shield on pin 1 at both ends.
I recommend that you uncap BOTH connectors, mate them, and verify the same color goes straight across as you solder the wires..
Note: I had some brand new cables delivered that the shield had been connected to pin 3 (middle one) and I had hum ! Note that this defect would NOT be caught by your cable tester as there was conituity between corresponding pin numbers.
May 04, 2010 | Behringer Ct100 Cable Tester
I just changed battery and then i found i couldn't use radio anymore. The window show "code" everytime i tried to turn on radio. My car is 1995 Hyundai excel. How do you enter the radio code?...
look in the handbook for the radio,it should tell you how to put the code in.most radios accept the code via the preset tuning buttons,ie first number is number one and so on then press number five to lock it in ,but some radios you press number one for first nunber then when its entered via tuner up and down press one again and enter second number.then am/fm button to lock but some use the tape player play knob ,really is confusing trust me on this .Change a customers battery and then find they dont have code number,also often happens is that change battery and dammed factory immobiliser cuts in...Who would be a mechanic?? any rich widows out their ??
Dec 30, 2008 | Car Audio & Video
NEED PUK CODE
i have locked my phone but dont know my puk or pin
Nov 03, 2008 | Samsung J700 Cellular Phone
Blackjack i607 how to block withheld numbers
yellow!!!
yeah you can do that:
heres what you need to do:
  1. While in standby mode, press the left soft key for Start
  2. Select Settings
  3. Select All Calls
  4. Select Fixed Dialing
  5. Press the OK button to check or uncheck the "enable fixed dialing" box
  6. Press the left soft key for Done to set the Fixed Dialing Number changes
  7. Enter your PIN2 code
note: only people listed on your phonebook or your contacts can call you
* if you dont know your PIN code get it from your service provider
;p
Jun 25, 2008 | Samsung BlackJack Smartphone
PIN CODE
The only way to unlock a PIN locked Garmin is to enter the correct PIN number, or take the unit to the location where the PIN was set. Your only other option is to send the unit to Garmin.
Mar 09, 2008 | Garmin Nuvi 660 GPS Receiver
Pin unloock
how do i unlock my garmin i never put i pin number but is asking me the pin is a garmin street pilot c 550 thank you
Sep 23, 2007 | Garmin StreetPilot c550 GPS Receiver
Samsung Eternity  Cell Phone Logo
76 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
