Question about Kenmore Washing Machines
The washer turns on but when your press the button to start it doesnt start. The door locks, the timer runs, then it goes to LD ? Its a top loader Kenmore Eliete. My email address is bowen755@gmail.com Thanks for your time!!!
  • 4 more comments
  • Kim Bowen Dec 28, 2010
    Ok Daniel Thanks for being quick!!! Anyways blew thru the hose its hard to blow thru what do I do to clear the hose?
    I did keep blowing thru hose, it cleared. I set to do the rince and spin. Water filled up wont spin water out. Help?
    I blew thru it. I turned on rince and spin. Water filled up timer working but now wont spin water out.
    Thanks for your time.
    Kim
    Where filter pump? where drain pump?
    Well took back apart kept blowing the hose like before. Tried finding the pump etc now just flooded. It poured water on top of water. Anyways my Washer is Kenmoew Olite Oasos HE the numbers i found are kme washer 883049005089 D26 m27092 hopefully this helps Thanks for all your help. Kim
  • Kim Bowen Dec 29, 2010
    After it flooded the floor it stopped with code FL ?
  • 1,998 Answers
Ok couple questions first what is the model number of your machine? Oh i see your unit is a top loader ok LD is a long drain error code here are a couple things you can do to fix the problem
.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation thanks again
Rick
Posted on Dec 29, 2010
  • 4,323 Answers
Hi
Error code LD means Long Drain. It flashes when washer takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. With the tub empty try a Drain and Spin only cycle. If the LD error is still there then access the control board in the console. There is a pressure hose. Make sure it is not kinked or twisted. You can remove it and try to blow through it to the air trap. If you can't blow through it then this might be the cause of the LD error. Just make sure that the pressure hose is clear and that the drains pump does drain and is working fine. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 28, 2010
  • 2 more comments
  • Daniel Scott
    Daniel Scott Dec 28, 2010
    Take it apart and clean it and also clean the pump filter.
  • Daniel Scott
    As I said if you have cleaned the pump filter and still it wont drain water out then check the drain pump operation if it is not working then it should be replaced.
  • Daniel Scott
    Drain pump and drain pump filter is located at the bottom of the unit. Post back with the model no if you need more assistance.
  • Daniel Scott
    Daniel Scott Dec 29, 2010
    "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed. If you have already cleaned everything and you are sure that the pump is working fine then press cancel to clear display.
Samsung WF42H5400 AW/A2 Washer was briefly unplugged, then plugged back in. Now, it will not power on. Any ideas as to why?
hi Peggy.
Main reasons a washer will not start (either front or top load):
1. Power breaker off, washer not plugged in.
2. Lid switch faulty, door switch faulty.
3. Start switch and or timer faulty.
4. Washer motor faulty.
5. Main control board faulty or shorted.
Power to Washer
Be sure the washer is plugged into the electrical outlet in the wall. Also be sure the breaker switch in the breaker box is turned on. If you live in an older home your box may be called a fuse box. If so, make sure the fuse is in good working condition.
Door Switch Strike (Front Load Washer)
The door switch is a safety feature on front loading washing machines. On front loaders, the door switch must be closed and the door must be locked. If this switch malfunctions, the washer won't start. This switch is in the door frame of the washing machine where the door shuts. If you suspect the door switch is causing your washer to not start, carefully check the strike where it engages into the door lock assembly. Be sure the lock is working properly by keeping the door shut and locked shut. You can check the door switch for continuity with a multimeter. Be sure to disconnect the power to the washer when you check for continuity. If there is no continuity, replace the door switch.
Lid Switch (Top Load Washer)
A lid switch is a safety device located under the lid on top load washers. This lid switch will not let the motor operate when the the lid is open. If the lid switch is faulty, then the washing machine will not start. It may fill with water but will not spin if the switch is faulty. Some lid switches on top loaders also control the water inlet valve. In some top load washers, if the lid switch is bad, the washer will not fill with water. The lid switch is under the lid. There is a pin or pusher attached to the lid. This pin or pusher (when lid is closed) will press the lid switch. If your washer will not start, be sure the switch is being pressed. If the lid switch is being pressed but no power is being supplied to the washers motor, then the switch is most likely bad. To test the switch, turn off power to washer and remove the wires from the lid switch. Check the switch for continuity with a multimeter. If there is no continuity, replace the lid switch.
Start Switch and Timer (Top Load Washer)
The start switch timer on top load washers is part of the timer. This starting switch is turned on by pulling out the timer knob. If after pulling the timer knob the washer will not start, you can test it for continuity with a multimeter. Remove power from the washing machine and find the timer contacts. Some top loaders have a start switch that is a momentary contact type of switch. This switch will be located on the control panel. You can also test this switch for continuity with a multimeter while pushing the button in. Remove power from the washer before testing for continuity. If there is no continuity, replace the start switch and or timer.
Timer Knobs
Sometimes the timer knob wears out and cannot properly engage the timer shaft. If this is the case, then the knob is at fault. The knob cannot grip the shaft therefore is unable to turn the machine on. A worn knob will cause it to slip. Turn off power to the washer and inspect the back of the timer. Make sure the timer shaft engages the knob when it is pulled in or pushed out. If the knob is worn, replace it with a new one.
Drive Motor
Both top and front load washers use a motor that spins and agitates. (A top load washer uses a reversing motor) The motor spins in one direction to agitate and the other direction to spin. When the wash motor will not turn on it may be faulty. If the motor makes strange humming sounds then the motor may be at fault. To test the motor, remove the belts and try to start the motor. If it runs then you know something else in the washer is causing the issue. On newer direct drive washers, you will have to disconnect the pump and the coupling to the trans. If the direct drive motor turns on, then then you have a transmission issue or possibly the pump. If the direct drive motor won't start then it should be replaced. On front load washers the motor drives the washing basket with a ribbed belt. Remove the belt and try to start the motor. If the motor runs, then be sure the basket turns and doesn't have anything stuck or jammed between it and the outer tub basket.
Main Electric Control Board
The control board controls every component in your washer. If the main control board does not properly control the motor, the filling valve, the drain motor, or the door lock, the washer will not start. The only way to determine if the control board is at fault is to visually inspect it. Check for burned areas or any component on the board that may look burned or damaged. If you find burned areas or components on the control board, remove and replace it.
or read up more at this link.
samsung washing machine will not turn on Google Search
Dec 12, 2017 | Samsung Washing Machines
Turn on machine door locks ready to run but water doesnt start to cycle
Affinity Service manual
The brain might not be getting door lock confirmation due to corrosion in the lock terminals or the door lock itself could be broken.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 19, 2010 | Frigidaire ATF6000ES Front Load Washer
Ld code appears intermittantly
ld is a long drain time...you may have something in he drain or a bad inpeller in the drain pump...it is taking too long to drain out
Sep 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Lid lock what does this mean
the lid is auto lock after you press start
Jun 18, 2009 | Fisher and Paykel IWL12 Top Load Washer
Control Lock is on my front loader.
ok, you are in the model selection part of the service mode. for 6240 I believe the model code is 3 select this and press start. normally to release control lock press and hold small I button by start button.
if model selection in incorrect it can still be corrected. only difference in models is cycles matching the labels. you can tell by the time indication for each cycle if it doesnt look right then check book inside top cover
Mar 29, 2009 | GE WBVH6240F Front Load Washer
How to get access to door interlock mechanism?
IT MIGHT BE EASY FOR YOU TO GET TO THE DOOR LOCK FROM THE TOP OF THE MACHINE.IF YOU HAVE REMOVED THE 2 SCREWS HOLDING THE LOCK IN PLACE YOU SHOULD BE ABLE TO SEE IT HANGGING FROM THE TOP ITS BEST YOU HAVE A NEW LOCK ON HAND TO REPLACE IT.IF ALL FAILS BEST YOU SEEK THE HELP OF A TECHNICIAN.LET ME NO IF YOU NEED EXTRA ASSISTANCE.GOODLUCK.MOHAMED
May 21, 2008 | Hotpoint BWM12 Front Load Washer
Samsung electronics clothes washer model j845
If you have a face icon lit up the child lock is on, press and hold spin and rinse buttons until it goes off
Apr 26, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
