Question about Vacuums
I put brand new T8 light bulbs in a fixture but the lights are still flickering is it the ballast.
    Master:
  • 383 Answers
Are they actually flickering on and off?- or just sort of Twirling patterns of lighter and darker shade of light? -- That is normal when the bulbs are new-- That should become steady in a few days.
If not-- tell us more what is happening-- in detail.
Mack B
Posted on Dec 28, 2010
The light on a fan is flickering. It doesn't appear to be the light bulbs. This fan has a remote control and it controls the fan OK and turns the light on and off but it flickers. What could be...
Try changing or testing the batteries in the remote or take the remote out of the fans range. See if this stops the flickering. It can also be the individual bulb. Sometimes the monofillament wires become loosened. It won't hurt the fan to use a broken bulb but it will shorten the life of the bulb. They do get the daylights shook out of them! If all the bulbs flicker it can be the twist connects. These are located under the ceiling plate cover. To check, shut off the fan or turn off the braker switch to make sure you don't get a shock (but I really doubt it). Remove the face plate ceiling screws to expose the wiring. There should be a black and a red cap that holds wires together. Black is ground red is power. One at a time hold the wires of the black cap with one hand and give the cap a gentle clockwise twist with your other hand to see if they need tightening. Repeat with the other colored cap. Push the wires back up inside the housing if needed and replace the cover.
These are the simpelist things to try before calling an expert. I hope this helps?
Sep 22, 2011 | Vacuums
Hello I have a hapton bay flush mount ceiling light fixture. The bulbs broke and I would like to replace them, however I seem to can open the fixture. It does not have a screw. Please help me. Ingrid
Hello, W/D here.
Try pulling (firmly, but not too hard) straight down. Most fixtures without screws holding them on will have a spring clip inside the globe to hold it to the fixture.
Best regards, --W/D--
Apr 03, 2011 | Vacuums
How will i install a new lightbulb in my house? better if you will send me a diagram. thanks
First off all make sure the light swicth is off if there is a light shade around it take is off then hold the light the white light fitting and get hold off the bulb then push up gently and turn the bulb antiy clockwise and it will pop out to replace new bulb off same watts do the same as taking it out but in reverse then put shade back on then try the swicth to see if it turns on if not the bulb is no good try a new on but be gentle with them they brake easy ok hope this helps you
Mar 28, 2011 | Vacuums
I plug in cord to charge unit. Light goes on. I put unit down, light goes off. I twist cord, light flickers. I lift unit up and twist cord light goes on. I put unit down or lie it down light goes off. Unit...
You have to use the same diagnostic procedures that you already have to isolate which area of the cord is broken. Carefully test, by wiggling, etc. the end of the cord that plugs into the wall. If this end is faulty, you can purchase a plug end at a hardware store and replace it.
If the cord is broken at the sweeper end, unless you can open and repair the break, you will probably need a new charger.
Gary
Feb 21, 2011 | Vacuums
LIGHTING QUESTION: I have a GE Pro line T8 Ballast w/ (8) wires (2) Blue, (2) Red, (2) yellow plus Black & White. I know what the Black & White are for and are not connected to the lamps. Can you...
Try this link-- for a wiring diagram--- let us know if this helps-- Mack
http://www.replicasuper.com/wp-content/uploads/2016/01/T12-Ballast-Wiring-Diagram-Here-Is-An-Example-Of-A-Circuit-That-You-Can-Make-The-Guidelines-For-Making.jpg
Oct 27, 2017 | Vacuums
I have a Hampton Bay Midili fan which I just installed about a month ago and it was working fine. A few days ago when I flipped the switch on the light flickered on and off consistently until I turned the...
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Jun 06, 2010 | Vacuums
I bought a ceiling fan from lowe's, got it home got ceiling fan up in the bathroom, when we put in the light one of the halogen bulbs does not work , also two of the cobalt blue glass covers are cracked...
If this is a new product and it is defective, take it back to Lowe's and insist on a replacement, talk to the manager if you have to. This site will only advise you on how to fix it.
Mar 05, 2008 | Vacuums
Vacuums Logo
47 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
