Question about Sylvania G-Netbook
Does the 2 gig sd card dowload up date have tobe done on anouther computer or can it be done on the synet07526 and why can it not be bone on the synet
    Genius:
  • 1,267 Answers
It has to be done on another computer, in short one that has an unzip program. The file is zipped up in a file that has to be expanded in order to get the file needed for the SYNET07526 to recognize when it boots up, namely a file called script. This file must exist in the root directory of the SD card in order for the boot system to recognize that it is an update. That is one of the first tasks built into the boot loader and if it is missing, it passes on to its next task. If it exist, it starts executing the code in the script file which is first to erase the ROM chip where the existing OS resides, then start reading back in the code found at the rest of the script file. If you have a bad down load or an error in the down load, then this causes the system to malfunction and you have to do it all over again.
short answer is the CE does not have a file to unzip the zipped package.
See my TIP at http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing to see a more detailed "How To"
Posted on Dec 29, 2010
Testimonial: "boy boy you sure are knowlegable about pc espically the synet where most people are not you are more knowlegable than the tecs thanks again"
SD Card Full
When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it.
You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
Mar 25, 2013 | Tascam DP-008 8-Track Pocketstudio
No keybord action says all files are emty
You seem to have a problem with your operating system. Pleasee try to follow the detail below.
I suspect that your operating system is "KAPUT", that is to say non-operative due to contamination. If this is a SYNET07526, then you can go to www.digitalgadgets.com and download a replacement system (upgrade) to that book. You have to follow a definite method to load the system. It entails buying a SD card of at least 1G and properly formatting it. (normally they come already formatted). You then will have to down load the upgrade to another computer and unzip the file. You would then copy the "script" file only to the root directory of the SD card. Turn the power off of the SYNET07526, insert the SD card in the slot upside down, turn on the SYNET07526, and see if it will load the operating system along with the APPS. You may want to read my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing to be sure that you understand exactly how to do it.
Jun 12, 2011 | Sylvania G-Netbook
The screen says loading device drivers but it wont load
Please try and follow the detail listed below.
I can't start my synet7wid and the battery is full,is the first time becaue is new.when i turn on all she do is loading device drivers. i need your help please.
Please try and follow the detail below. The SYNET7WID is the same as a SYNET07526, the SYNET7WID is sold by Sears and Kmart, while the SYNET07526 is sold by CVS. The upgrade for the SYNET07526 will work for the SYNET7WID.
Jun 11, 2011 | Sylvania G-Netbook
Sylvania smartbook,the power comes on but the screen is dead took the battery out and use just the house power did the reset still the screen is dead help me please
Jun 09, 2011 | Sylvania G-Netbook
Bought 2 gig sd card to update my sylvania 7"smart book synet07526 like recomened sd card does not show up brand new scan disk sd card whats up
First of all, you must be sure that the SD card is formatted with the proper formatting as http://digitalgadgets.com/netbooks/7-in-netbook.htm indicates to be FAT 32. Then you have to down load the indicated file and unzip the file to expose a file called script in the root directory of the SD card. All of this has to be done on another computer with an unzip program installed. Then you place the properly fixed SD card in your SYNET07526, that card goes in upside down!, then you turn on your SYNET07526, and away you go. Read my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Dec 22, 2010 | Computers & Internet
How do you format the ativa sd 2gm memory card
my wife music on my sd card and i can not take it off how do i do that its a 2 gig ativa sd card and its for a cam
Oct 17, 2008 | Electronics - Others
IQue 3600 sim card problem
from Garmin:
Question: Why wont the PC recognise my the SD card in my iQue 3600?
--> Answer: Go to My computer and look for the following directory:
  • C: > Program Files > Palm > (user name) > file called 'sync'
  • Double click on this file and delete the four bottom rows that will look something like this:
"SlotId=0
MediaType=1935960423
DisplayName=SecureDigital (SD) Card
InstallDirName=Slot-SD"
  • Then try a HotSync as normal, it should then 'see' your SD card.
  • If all fails delete a second user name as sometimes this interferes.
Mar 14, 2008 | Garmin iQue 3600 GPS Receiver
2 Gig SD card in my unit won't let me add anymore mp3's but I have only used 690MB of the card
It maybe that the system will not recognize any storage medium larger than 700megs or so. regardless of the size of medium. You can try and format the card but my instinct tells me you have reached the GPS's ability to store info. lemme know if this helps.
Jul 04, 2007 | Garmin StreetPilot c550 GPS Receiver
Sylvania G-Netbook Logo
253 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
