Question about Honda Electrical Supplies
It will start on full choke and run for about 5 seconds and shuts off. I changed oil because it was black. It did same thing a year ago and shop said the fuel line was blocked? I ran it for about 25 minutes today and it then quit and would not run for more than 5 seconds after lengthy cranking. Is there a reset procedure after changing oil? THANKS
    President:
  • 2,468 Answers
First if its a honda,is it a gas/oil mix as the gas/oil mix plugs up quicker than a 4 cycle engine ?even 4 cycle engines that get bad gas i.e. water in the gas will plug up the carburator from rust, white rust(from water minerals) corrosion,dirt,etc.,when its running and just as it dies out,pull out the choke and see if it picks back up in r.p.m.'s,if it does,then you know its lacking fuel from starvation from plugged fuel lines/carb to keep running,then you need to re-build the carburator or you could first try a can of carb cleaner while its running down into the carburators intake,but this is a tell-tale sign of a bad/dirty carb,try this,with a small wrench,pull off the carburarors "sediment bowl" located just ubder the carbs body and carefully unscrew the brass nut and remove this bowl(careful to NOT lose the gasket) and see how moch water/dirt,etc., is in the bowl if theres water it will look like droplets in the gas in there,if you have this contamination you need to clean out both the gas tank and carburator and all fuel lines leading to and from these to the engine
Posted on Dec 28, 2010
Mine starts, runs 5 minutes, tries to die, runs 5 more minutes (poorly) with full choke, then dies. Carb? Cool?
need vehicle make and year. "Full" choke will always flood the engine causing it to dye. once running reduce choke. Is this automatic or manual choke?
Apr 07, 2017 | Garden
I was using my o17 saw today it was runing Just fine I shut it off when I went to start it again it fired on choke seting after that I could not get it to do anything what is wrong with it
All 2-strokes love to run rich when cold thus full choke till it kicks, half choke to start and leave on for 5 seconds high rev's to warm & lubricate, then no choke to run. Restart when hot is 1 pull full choke (you are now flooded) & then no choke til it starts. Try it. Works every time on all of my 2-stroke engines.
Apr 22, 2015 | Garden
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
Weedwacker -purchased more than a year ago, never been able to start it. Lost owner's manual - can I get a copy on line?
Should be able to google model #. Make sure you have a 40:1 fuel oil mix. Pump primer bulb 4-5 times, put on full choke, when attempts to start set choke to half. After it starts open choke. If won't start and has been sitting for months with fuel in it, the carb is more than likley gummed up.If you paide less than $100.00 for it it is not worth having it repaired at a shop. You can although purchase a new carb at eparts, or sears parts direct for around $ 30.00. Just need the model#. Good luck.
May 14, 2011 | Craftsman 25cc Gas Line Trimmer
I cant start my leaf blower
I would suggest a new plug and fresh gas and oil mix.push the primer bulb 8-10 times and turn choke to full.pull cord about 4 or 5 times until it starts.if it don,t stay running turn choke to half and pull cord until starts should stay running.let run for about 10 seconds then turn off choke.Almost forgot that during this whole process you hold throttle wide open.
Dec 08, 2010 | Garden
Hi since weather has changed my zx9 wont staret just turns over i had the carbs balanced couple months ago i have put new battery on had plugs checked was told there fine oil and filter changed checked all...
hi m8t it sounds like a couple of things 1 you my have mioster in the wireloom thats why your useing a hairdryer under the tank..2the timeing my be out or the tappits my be loose reset them...3 the choke my be jammed just make sure that the choke runs freely on the cabs....ps sorry for the spelling...if the wireloom has water damage dry it of and tap it up hope this helps you
Nov 12, 2010 | kawasaki Full Suspension Mountain Bike Men
Brand new Honda Generator 2000i will not start. uhhg
Hi and welcome to FixYa I am Kelly.
Things that must be verified.
1. Fuel selector: ON
2. Start run sw: ON
3. Oil Level : Full
4. Choke selector FULL ON for no more than 2 pulls initially The half choke then off
5. Spark at the Spark Plug YES? NO?
a. No spark suspect low oil level sensor is grounding the ignition either due to low oil level or it just is not working properly.
After doing all of the above...
Spark Plug WET or DRY? Dry and still won't start check fuel supply. If you use the choke with the start run switch in the off position the spark plug should get WET. Spark plug does not get wet... with choke on and ignition off. Fuel supply problem.
At this point I suspect either the Oil Level is incorrect or... that the FUEL SELECTOR is OFF.
If you need more help just respond here and we can press on.
Thanks for choosing FixYa
Kelly
Sep 02, 2010 | Honda Electrical Supplies
I don't know how much oil i need for an oil change
With oil filter you'll need 5 quarts. After changing oil and filter run briefly and check for leaks. Shut down the engine and check oil level is correct.
I hope this may have helped,
Tom
Oct 18, 2009 | 1993 Ford Probe
Honda em2500 starts, runs 1 minute, quits and will not restart
If the oil level is low it will do this, but I also know this to happen when the oil is very cold (thick) an won't fow back own o the crankcase where the oil sensor is. The slow return results in a low oil level. My solution is to start it, when it dies wait a couple of minutes and retry... after a few starts, the oil will warm up, thus flowing back down faster and it then will run. Another option is to use a thinner oil ie;5-30w.
Apr 19, 2009 | Electrical Supplies
Stihl KM 55 won't start
1. 1st change the spark plug to NGK BPMR 7A.
2. Set the kill switch to on position (I)
3. lock the throttle interlock on
4. Do not prime the fuel bulb...this may cause flooding.
5. set the choke to full choke.
6. pull the cord gently until the piston resists then pull hard
7. repeat pull a second time
8. open choke all the way
9. pull cord again hard.
engine should start within 2-3 pulls, release throttle and feather the throttle until stable
Apr 04, 2009 | Hand Tools
Electrical Supplies Logo
269 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
