Question about LG 42LC2D 42 in. LCD HDTV
Why does LG 42" take 30 minutes to turn on?
Tip
How to backup cust in lg pop (lg gd510) cell phone.
Download lg utilities from the link provided below.<br /><br />http://www.mylgpop.com/index.php?action=dlattach;topic=827.0;attach=266<br /><br />Next, ensure your phone is switched <b><span>ON</span></b>, then remove your battery and SIM card (and memory card if you have one), and insert only your battery. This will turn off your phone, but don't turn it back on.<br />Now you must type exactly this into LG-Utils-0.4.2. It IS CasE sEnsETivE. "\" or "Backslash" can be found in between "Z" and "Shift (Up arrow)" on the bottom left of the keyboard.<br /><br />D [ENTER]<br />\ \. \ USB1 [ENTER]<br />C: \ GD510.flb [ENTER]<br />CUST [<span><b><span style="text-decoration: underline;">Don't press</span></b></span> ENTER]<br /><br />Plug the USB end of the cable into your computer, but <span><b><span style="text-decoration: underline;">NOT</span></b></span> the micro USB into the phone. Open up the small flap on the side of the phone that protects the micro USB. Press "ENTER" and QUICKLY insert the other end of the USB cable into your phone. Now wait for about 5 minutes.<br />After 5 Minutes, the program will come up with an error. As long as it has been about 5 minutes, this is normal. Once it has finished, you can disconnect your phone. Remove the battery again, and insert it. Turn your phone on.<br /><br /><b><span></span></b> Minimise LG-Utils-0.4.2, and go into "C Drive". You will now see a new file, called CUST.big. This should be 133MB in size. <span><b><span style="text-decoration: underline;">DO NOT DELETE THIS FILE!!!</span></b></span> You must make a backup copy of this file. Create a new folder anywhere on your computer, called "CUST Backup". Copy the CUST.big file, and paste it into your new folder. This may take a few moments.<br /><br />Thus the backup is taken.<br />
on Mar 04, 2011 | LG GD510 Cell Phone
Our LG takes a while to turn on....is there someway to fix this?
replace bulging capacitor at power supply board the it will resume to normal operation.
Jul 21, 2012 | LG Televison & Video
Why is my LG 32LC7D TV taking 5 minutes to have a picture when turning on.?
Likely signs of a issue that is going to only get worse---could be in power supply of set (first place to look) or could be main board or something that it controls.
Kind of like "My car runs rough when cold" it is a issue that is not full blown yet.
Jun 01, 2012 | LG 32LC7D Television
I have the "please wait"
The problem is associated with the Laser / Drive Mechanism.
I take it they told you to :-
1) Unplug and leave for a few minutes.
2) With the On/Off Button Pressed, Plug in and wait for the unit to reset.
If you've done this and still get the same fault then it requires further investigation by an engineer but not necessarily an LG one.
Apr 24, 2011 | LG LHB535 Theater System
When my dad tries to make a phone call, it says "emergency only." He isn't sure how he turned that mode on and I can't figure it out either. Or how to turn it off. He has service and he also has...
ok .that is my problem to when i try to call it says "sim blocked" and "emergency calls only" and i called the tracfone number and they tell you how to fix it.
Feb 12, 2011 | LG TracFone 600 Cell Phone - TF600GP4
Hello, I tried to update my new LG N2B1DD2 to last firmware version. Now it has on the screen "F/W Update.." and nothing happen. I read that usually neds 1-5 minutes for upgrade but passed over...
Hi florent_elev, what i did was create a volume and then ran the firmware update. This worked for me and it took me to firmware version 1.0.0_2569. It was about 3 to 5 minutes to complete.
Dec 29, 2010 | LG N2B1DD2 2TB Super Multi NAS with Bluray...
LG 42LC2D 42 in. LCD HDTV Logo
59 people viewed this question
Computer Repairing
Computer Repairing
