Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
I have a 1997 polaris indy xc 600 tripple that is getting to much gas and the crank keeps filling up with gas. It wont even start.
Bad needle and seat in carburetors allowing gas leak by needle in carbs. Turn off gas when not in use and will help get by until you can replace them
Posted on Jan 03, 2011
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
I have a 97 polaris indy 600 it starts and drives great but when u come to a stop i press the gas but it just wont go u got to kind of push it to get it going
The belt needs the tension adjusted or the clutch is going out. More than likely you just need to adjust the belt.
Jan 23, 2014 | Winter Sports
Polaris 2003 600 classic perc rverse problem
my 2003 polaris 550 indy's reverse doesn't work maybe once in a great while it will work but like tonight i rode for about 1 hour and tried to put it in reverse and it didnt work it died down and stalled out then started it back up and tried it again and it went forward i need help and information
Nov 21, 2012 | Polaris New Genuine Polaris Snowmobile...
I have a 1995 polaris 600 triple it fires but does not want to keep running seems like not getting gas it will fire on full choke off it wont even fire
CHECK THE COMPRESSION OF THE ENGINE, IF IT IS AT ABOUT 120PSI AND DOES NOT HAVE A DIFFERENCE BETWEEN CYLINDERS OF 15% THAN CHECK YOUR FUEL PUMP. YOU DO THIS BY REMOVING THE SPARK PLUGS AND FUEL LINES TO YOUR CARBS AND PULLING IT OVER. IF FUEL COMES OUT OF YOUR LINES THAN THE FUEL PUMP IS GOOD. THAN I WOULD CHECK YOUR CRANK SEALS FOR LEAKING
Dec 24, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 97 polaris indy 500 snowmobile. The spark
Wait, it just wont turn over, like the engine won't rotate?, that is either a broken crank, which not unusual for those 500's or you seized it, (welded the piston to the jugs). if this isn't what you mean, and it will turn over but not on its own power, then either your jets in the carbs are clogged, fuel may get to it, but not through it, or your rings are stuck closed and giving you low compression, check this by pulling it over slowly, you should feel each piston completing the revolution with a prominent glug glug. grab your primary clutch and rotate it back and forth, it should have a bit of play, but if it clanks and has alot of play, your crank is busted
Feb 16, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 1997 polaris xc 600 sled gas shutoff up or down
The petcock for the gas should be in line with the fuel line for it to be on. If it is perpendicular to the line it isoff.
Dec 27, 2009 | Polaris New Genuine Polaris Snowmobile...
Xc 600 stalling
when it stalls, is it on a warmer day? ie 20+ degrees? is it overeheating or hot? If you have never had the carbs serviced, the summer/fall may be a good time. inside the carbs, you have differnt circuits, they may be gummed up. Good luck
Feb 08, 2009 | Polaris New Genuine Polaris Snowmobile...
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
586 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
