Question about HP Officejet 7210 All-In-One InkJet Printer
HP 7210 pagecount
On an HP7210, I was wondering if it was possible to get a print out of the pagecount and other details of the printer, via the printer itself, the menu doesn't seem to show an option for it.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Yes, we can get the page count of the all-in-one.
Print the self-test report from the front panel of the all-in-one. In that report, the page count will be mentioned.
If we reset the printer then it will become zero and starts again.
Perform below steps to print self-test page.
  1. On the front panel of the product, press Menu (or Setup) .
  2. Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK .
  3. Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK
Posted on Jul 07, 2008
I have an HP Officejet 7210 All-in-One. I would like to know if there is any way to print a document that only needs black ink, even though a message always pops out that I have to remove and check the...
Hi
Black is not True black. It is slightly brown.
Printing in black uses mainly black but may also a tiny amount of a mixture of some of the other colours.
To minimize the usage of other colours:
HP Solution Center > Settings > Print Settings > Printer Settings > Color > tick Black Print Cartridge Only > OK.
HP ink can be expensive. It is possible to economize on HP inks in some cartridge formats by using Ink refill kits.
I hope this helps.
Aug 24, 2011 | HP Officejet 7210 All-In-One InkJet...
Hi I have a 7210 HP officejet printer that is out of color ink but am in a bind because I need to print now!! Was wondering if you knew if it is possible to bypass flashing "replace color...
k go to printer & fax right click on the printer then properties then preferences then maintenance then select the cartridge black only then, your ready to print
Aug 09, 2011 | Office Equipment & Supplies
Dell 3110 laserjet printer, belt unit close to life
This message is displayed when the pagecount of the transfer belt is 80,000 (ish)+.
The rated life of the transfer belt in the Dell 3110/3115 is 100,000 pages.
After that pagecount the transfer belt 'expires' and no further printing is possible until the transfer belt is replaced.
Feb 03, 2011 | Dell 3110cn Laser Printer
My 7210 a) Will not print colour via the pc but will by "copy"b) I cannot get the scan to work
Sounds like if only the copy will work, from a button on the machine, your drivers and software are not loaded correctly
Jul 13, 2010 | HP Officejet 7210 All-In-One InkJet...
How do you set date and time on HP7210 printer?
Press: Setup, press: 4, press: ok, enter Date, then Time
Time is found in Basic Fax Settings option 4 and option 1 on the HP OfficeJet 7210 All-in-one series printer fax scanner
May 14, 2010 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 7210 Is Very Very Slow (10 mins / page printing)
And I have exactly the same problem too that has happened in the last few weeks.
I've tried reinstalling the software/drivers and resetting the printer to factory settings but no joy. An upgrade either windows or HP must have caused this!
Mar 29, 2010 | HP Officejet 7210 All-In-One InkJet...
How do you set HP7210 all in one for distinctive ring fax
The user manual is posted here if you have access online: http://h10032.www1.hp.com/ctg/Manual/c00278645.pdf
and distinctive ring information is on pages 77, 79, 83, 84, 97, 102, 103, 119, 187, and 189. Hope this helps you find info to set your 7210 for distinctive ringing.
Jul 15, 2009 | HP Officejet 7210 All-In-One InkJet...
HP7210 Installation to MacOSX 10.5.5. No Device Found
I suspect you are right that it's the USB cable. If the printer does TCP/IP you should try plugging an Ethernet cable from the printer to an empty port in your router. Get the IP from the printer configuration page and print to the IP using a general postscript driver. If that doesn't work, it's the printer...if it does you can start troubleshooting back to the machine.
Dec 10, 2008 | HP Officejet 7210 All-In-One InkJet...
HP 7210 All In One Printer; printer speed
Could it be that you have the quality set to Best, either at the printer or through the application you are trying to print with? If so, on the printer, you can select Normal and in the application, select Properties on the Print window and find the Normal setting.
Aug 26, 2008 | HP Officejet 7210 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
322 people viewed this question
Ben Johnson
