1.
S-Video – This is probably the most commonmethod out there currently because an S-Video cable is cheap as heckand just about every TV under the sun has a S-Video port. You’ll haveto make sure you laptop is equipped with this port. Remember, there aretwo types of S-Video cables:
4-pin and 7-pin. Mostlaptops and PC’s are equipped with a 7-pin port, so if your TV only hasa 4-pin S-Video port, then this method will not work.
2.
VGA – If you have a HDTV, then you will bebetter off connecting using a VGA cable. It gives much better qualitythan S-Video and as with S-Video, the cable is very cheap. You usuallywon’t find a VGA port on regular TV’s though, so this option is if youhave an HDTV.
3.
DVI - DVI stands for
Digital Visual Interfacewith “digital” being the key word there. The digital signal will give ahigher quality picture than either S-Video or VGA. Of course, yourcomputer will need to have a DVI connection and your TV will need to bean HDTV. This cord is definitely not cheap, it ranges anywhere from $40to $80.
4.
HDMI – Using HDMI will give you the best qualityby far. No computers that I know of yet have HDMI ports, but you canget a DVI to HDMI cable to connect it to your HDTV. HDMI is compatiblewith DVI.
5.
Scan Converter Box – This is the last methodthat I could think of and it involves using a scan converter box, whichtakes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel
