Question about GE JBS55 Electric Kitchen Range
When our family returned from out of town, we had no heat. I plugged in a small space heater close to the stove to help heat the kitchen. A bit later, I started to make toast and a breaker flipped. Flipped the breaker back on... everything was back in order (so it seemed). It wasn't until later when I went to turn on the stove top to cook that I found the stove and oven would not heat. All lights (clock and element lights) work but the stove top and oven will not heat. I've tried re-tripping the breaker but that doesn't resolve anything. Any suggestions?
  • GE Master
  • 3,921 Answers
Power must be reaching the stove for the lights to work so it would seem something has gone wrong inside the stove. Only exposing the internal connections and testing the circuits will trace the fault.
Posted on Apr 30, 2017
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
MNTECH
  • 1543 Answers
SOURCE: PF on Whirlpool super capacity 465 electric Stove Model RF366PXGW2
PF = Power Failure. Sounds like you have a bad electrical connection. With your breaker off, check that the connections from the cord to the range are all good and tight. Next, check the receptacle where the cord plugs in. Remove the cover and check the connections there as well. Examine the power cord also. There could even be a poor connection at the breaker box (at the circuit breaker or the neutral buss bar) but not as likely, as your problem appeared when you moved your range.
Posted on Oct 19, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven will not heat
Although I am not familiar with this oven, living in the u/k, I would say that without any doubt the oven element(s) have failed, more so if the fan is working, so I would have hesitation that you replace the suspect element (s)..
Plz let me know how you get on.Thanks.
Posted on Jan 03, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Posted on Feb 08, 2009
blueextc3221
  • 15935 Answers
SOURCE: GE Stove clock shows FFF and oven will not work
GE Error Code: FFF
Condition: Door motor safety circuit
Fix: Repair Electronic Range Control (ERC)
Usually, failure happens after power surge.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 13, 2009
1991 Lincoln Town Car Heat Trapped
The valve that allows hot water into heater core is stuck in the closed position. It needs to be replaced.
Apr 02, 2017 | 1991 Lincoln Town Car
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
Oven stopped working
I had that problem also I have a maytag thoe. I was told ( by maytag )not to have the stove to close to the wall because the panel gets to hot and shuts down everything.Try pulling the stove a little bit away from the wall to let the heat out.Also check to see if the outlet to the stove has power to it.Hope this somewhat helps.
Feb 21, 2011 | KitchenAid KERC506 Electric Kitchen Range
Oven doesn't get hot. stove top works.
Get the heating element changed and all will be well.
Dec 09, 2009 | Maytag MER5530 Electric Kitchen Range
Cleaning a grill
Vulcan has an online site that allows you to down load the operation manual for just about every model... here' s link... their op manual looks pretty helpful!
Vulcan site
May 24, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Oven will not heat
ok few things sound like the gas valve may be turned off what i mean about turned off is at the gas valve contro;l normally installed under the stove on the left side of the valve tere is a verry small lever that serve as a shut of vave i have seen those lever in plastic normally red it may have sticked it self close or fallen out check on the floor if you do not see any small parts another thing check for fuse also there is a solenoid valvve that possibly not opening up one more thing does your stove connect to a normall 120 volt plug or does is connect to your 220 volt electric stove plug with a adapter if so check your breakers thanks gilles_dumais@hotmail.com
Mar 15, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Get too much of a gas smell when Magic Chef oven prheats up.
gas does NOT take that long to heat up!!
Shut that thing off before you kill your family !!!
Take it back or call someone to fix it !
This is a ticking bomb you have,...
If You smell gas then you should call the city or 911 .
Jan 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Power out on Whirlpool over-the-stove microwave
Yes, There are fuses inside the keyboard panel. I would have to take a look at the manual for the specific model you have to identify the easiest way to check the fuse.
Before you go that far check above the hood and see if you can locate the plug end of the microwave. Most installations have a dedicated receptacle above the exhaust vent and microwave. It is usually a space too small for good storage so most housewives store small items and cookbooks in this space. It is usually the culprit for a microwave suddenly going out without someone placing metal inside the oven and heating it.
Heating a metal object or operating a microwave for an extended time will usually blow the fuse.
r_craig@basicisp.net
Jan 06, 2009 | Bosch HMT9626GB Microwave Oven
Pressure cooker safety
From the point of view of the pressure cooker, there shouldn't be any problem at all provided you follow the pressure cooker instructions.
From the point of view of the stove, the only thing you might want to watch out for is point loading - some older pressure cookers can get a bit domed at the bottom. On a flat surfaced stove, this will concentrate all the weight of what is after all quite a heavy pot onto a small part of the stove top. If the bottom of the pressure cooker is still nice and flat, I don't see any problem.
A.
Mar 08, 2008 | GE Spectra JBP78 Electric Kitchen Range
Space heater will power up, but not start,
These fans have a safey feature (sensor) that shuts the heater off if it is tipped over. It sounds like this component is not functioning correctly - may be set wrong and will not allow the heater to turn on unless you shake it to reset the sensor. If it is still under warranty return heater, if not call Patton and ask for help.
Mar 28, 2007 | Patton PUH9000-U Heater
GE JBS55 Electric Kitchen Range Logo
63 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
