Question about Hotpoint RVM1635 Microwave Oven
Panel doesnt work reads pf - Hotpoint RVM1635 Microwave Oven
  • the_doad Dec 28, 2010
    buttons slowly stopped working then allbuttons stopped working.unpluged unit and the pf reading apeered.
  • 4,323 Answers
Hi
PF means power failure, to resolve this issue take a hair dryer and with the unit unplugged and the control apart blow air on the electronic part of the control. If the issue returns then the control board should be replaced. Hope this helps...
Daniel
Posted on Dec 28, 2010
  • Daniel Scott
    Daniel Scott Dec 28, 2010
    That was the reason I told you that it is the electronic control board that is bad, don't think its anything else that is bad.
One day the microwave just showed PF on the screen, unplugged and plugged in tried to use it, worked for 30 seconds, stopped and showed PF again. Any ideas? It is only a few years old and used in our...
PF is Power Failure. Check and see if the Oven has a reset switch or power button. Try and hook up an extension cord, plug one end into a usable output (wall plate) and the other into the 110VA line plug attached to the Oven. Turn on....if it works then the problem is a circuit breaker or wall interface. If it fails with the extension, then it is an electrical problem with the microwave device itself. If there are no Reset features on the oven, an internal fuse may blow, or other shorts are occurring. The cost to fix is more than a new unit. Lowes has them as low as $150.00.
Dec 18, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
My hotpoint microwave says PF -- the buttons are not working either - but i notice some are now - like the light etc -- the clock doesnt work
Hello & Welcome to FixYa
PF error means power failure which is generally caused when the control board inside the unit goes bad. You can try unplugging the unit for 15-30 minutes, if the issue returns then the control board needs replacement. Please get back to me if you have any other questions.
Kevin
Aug 06, 2011 | Microwave Ovens
Does not turn on all the numbers on panel are zero's and blinking, did try unplugging still nothing
Flashing zeros are a sign of a momentary power loss. Usually you also get a Pf error also. Not always....
Try this and if it does not work let me know.
Press Stop / cancel
Press clock
Set time
Press clock
Attempt normal use.
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Sharp R-209HK Microwave Oven
Pf code flashing on oven
PF = Power failure.
Usually all you have to do is press stop / cancel, then Clock then CLOCK again. After the time is set your microwave should work normally again.
If this does NOT correct your problem I need a complete model number in any future responses.
Thanks for choosing FixYa.
Kelly
Jan 04, 2011 | Microwave Ovens
My microwave shows PF on the screen and none of the buttons are working, not even the timer button. How to solve this problem ?
PF = Power failure. Try and push the clear or cancel button (or start, or clock etc) You may have missed one. If that doesn't work try and unplug it for 10 seconds or so and retry.
Sep 14, 2010 | Microwave Ovens
I have a Kenmore over-the-stove microwave oven that is not heating food. Everything else works. I received a message of PF on the keypad. Is there anything I can do before I have to call a repair...
PF - Power Failure - PF error code indicates a power failure during the cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 13, 2010 | Kenmore 62702 Microwave Oven
Got code PF and control keypads not working?
Hello :
PF indicates power failure . Displays this message after it has been unplugged or if there has in fact been a power failure .
good luck .
please rate !
Apr 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave when i plug it in comes up with PF on the screen and does not work at all,it has power and the light inside is on,i can press the 3 minute button and the microwave will wor but that...
ther should be instrustions manual sound like mocro is working suspect control panel it needs 2 be reset how read manul panosonic push stop 1 at same time menu comes up push reset this is a minor problem hopes this help u
Jul 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Hotpoint RVM1635 Microwave Oven Logo
105 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
