Question about Brother XL-3510 Mechanical Sewing Machine
Thread is knoting at the bottom and bursting. The machine is only sewing with elastic thread. When I try sewing with straight stitch or zig zag it will knot at the bottom and burst.
    Genius:
  • 1,788 Answers
Maybe you need to adjust your tension and double check your threading. I have never (in 50 years) sewed with elastic thread but I think a call to Singer customer service at 1-800-4singer may be in order.
Posted on Dec 29, 2010
  • shairun Dec 29, 2010
    I tried threading it over but it still knotting and bursting
  • Mary Dunn Dec 29, 2010
    I am at a loss for any other suggestions, other than the elastic thread is too stretchy. Are you threading your bobbin with it, if so, use regular thread in the bobbin instead of elastic thread. I know for invisble thread (kind of like fishing line) you have to use regular thread. Otherwise, call Singer. good luck
Why isbobbin stitch on top weird how do i fix
sorry but the bottom stitch does not move but the top one does . if you want straight stitch the machine setting has to be changed to straight .
May 22, 2015 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I'm sewing a zig zag stitch and the underside is a perfect zig zag and the upper side looks like it should be the underside....how can I fix this so that the beautiful zig zag is on the top?
FIRST > Make sure your bobbin case is threaded correctly...
NEXT
For normal straight sewing the top tension should be around 5, for zigzag or satin stitch you need to lower your upper thread tension a bit. Try it at 4, if it still pulls your bottom thread to the top try it at 3 etc...
Jan 15, 2011 | Euro-Pro Deluxe 7130 Mechanical Sewing...
My machine is not shirring. I hand wind the elastic on the bobbin properly(in fact 4 different ways from no tension to medium tension on the elastic). I have it on a straight stitch and selected 4 as the...
you are doing it wrong, thread the machine top and bottom as normal, shirring elastic on your lap, select a small zig zag or pattern, sew and as you sew pull the shirring elastic taught, mif you wind the shirring elastic on the bobbin you will mess the tensions up.
Apr 22, 2010 | Brother CS-100-T Computerized Sewing...
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
May 23, 2009 | Bernina Virtuosa 150
Shirring fabric?
Drop the bobbin with the elastic in the holder without feeding it through the holder, and enlarge the stitch length,
Mar 29, 2009 | Brother XR7700
Zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
Aug 24, 2008 | Kenmore 15516 Mechanical Sewing Machine
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Brother XL-3510 Mechanical Sewing Machine Logo
100 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
