I looked at my humidifier last night, it looks like it hasn't worked in a long time. the filter cage had thick build up where it had been sitting in the water. How is it suppose to work?
    Master:
  • 383 Answers
A couple questions so I can be sure we are talking about the same machine:
Is your humidifier, located near your furnace, and in one of the sheet metal ducts?-- These kind circulate humidity through-put all the open registers in the connected heating system...
Or is this a portable humidifier that you place in one room, and that room is the first to get the increase in humidity-- These are portable, plug-in-the wall powered units.
The first ones (Mounted in the duct..)
Usually has a rotating 'cage' that has an absorbent pad -- maybe 10 inches in diamter-- and a little motor and gearbox, that slowly rotates this pad thru the trap of water in the bottom. As this bad rotates like this, and the house system's air fan is drawing air past this wet pad, you can see how moisture would be added to your house and it heated air.
This pad needs to be replaced at least annually-- So -- can you replace that pad?-- The local hardware store can sell you replacement pads, and you just stable, or sew them on the large wheel-- Make sense?
If your's is the portable kind-- There may not be a rotating drum-- but maybe stationary pads?
-- Can you remove them?-- and take them to the local Hardware store (after they dry!!) - carry in a sealed plastic bag, for thre may be some nasty mold spores in those pads!
Tell us more-- we want to help!
Mack B
Posted on Dec 28, 2010
  • 2 more comments
  • Anonymous Dec 28, 2010
    it is a Kenmore unit on the furnace. I just replaced the pad and the water tray. It looks like it hadn't rotated for awhile, there was a lot of lime buidup. I put it on its lowest setting and I'll see if that makes a difference. Thanks for the help..
    Tom
  • Mack Baxter Dec 29, 2010
    Hi Tom,
    GLAD TO HEAR IT!
    You will be able to tell if the wheel is rotating, when yo check it later, and see that the pad is well soaked, all over-- (Note-- Likely the wheel only rotates when the fan is running.)
    Note: The little motor and gearbox is replaceable, too, if need be later.
    Mack B
  • Anonymous Jan 02, 2011
    Well its cold and dry outside and the humidifier pad is still dry, I have the humidastat on its lowest setting. Could the humidastat be bad?
  • Mack Baxter Jan 02, 2011
    Remember, this is a HUMIDIFIER-- That means you want to INCREASE the humidity with this device-- Therefor, INCREASE the humidistat-- and the wheel should rotate, get wet, and then be able to ADD humidity to your house.
    Make sense?
    A few more things to check:
    Is the water valve maintaining a supply of water in the little pan?
    and does the pad sit in the water-- so it is soaked, where it sits?
    All of these things have to be true-
    THEN-- the wheel needs to rotate,
    (So it rotates with an INCREASED setting on the humidistat-)
    Let me now what you find now.
    Mack B
What should the heating element look like after I've cleaned the buildup? I am doing this for the first time in a few months and the buildup is thick.
The heating element casing on which the buildup grows is made of an aluminum alloy that is originally black anodized which looks like plastic, but you should take care to not scratch the protective black anodize because over time it will corrode and makes a rough finish. It is not important to remove all the scale on the eating element, but only what falls off. You may let the element soak into vinegar or "CLR" cleaner from within the humidifier underneath pan such that would not need to scrub as it will dissolve and fall off. You have to rinse the pan and the eating element after soaking. If the layer of scale left is a thin that is OK, the water will go through as it is porous so the humidifier will continue to work normally. Keep in mind that the eating element is designed with a thermal protection built-in such that if the layer of scale is too thick to transfer the heat into the water, it will shut down by itself until it has cooled down enough.
Apr 01, 2015 | Vicks 1.0 Gallon Warm Mist Humidifier -...
CF is displayed on my humidifier...what is that?
Check Filter Indicator
The ability of any humidifier to efficiently supply humidity output relies heavily on the
condition of the filter. As the filter loads with impurities it gradually loses its wicking
capability. When this happens, moisture output is reduced and the humidifier has to work
longer to satisfy the selected setting. This humidifier has a check filter reminder timed to
appear after 720 hours of operation. When the Check Filter (CF) message is displayed,
disconnect the power cord and check the condition of the filter. If a build-up of deposits or
severe discoloration is evident replace the filter to restore maximum efficiency. The CF
message is reset when the humidifier is plugged back in.
Mar 05, 2011 | Bemis 826 800 Humidifier
Model 758743300c no humidy
'No Humidity'-- sounds like the humidifier is NOT adding moisture to the room it is running in?
Can you give us some clues?--
Like-- How is the pad look inside?
Are the fan(s) running?
are there any indicator lights lit?
Did it work for awhile, and stop?
What stopped first?-- the fans, or the little rotating wheel?
any clues that happened at the time it quite?
When was the last time the unit was opened up and cleaned out?
These devices need regular maintenance-- they build up mold and scale.
Please give us some clues to work with--
Mack B
Jan 25, 2011 | Kenmore 14416 Humidifier
I have a Carrier humidifier model #HUMCCLBP2217-A. It appears to be working, but every time it shuts off it emits a very loud "thump". The noise is loud enough to wake me up at night. I have...
Do you feel like looking at the humidifier yourself?
You can open the door on the unit, while the furnace is running--
The humidifier is usually installed in the return air duct, so there will be a sucking of air into the open door, when you open it.
There is usually a large wheel, with a wet pad wrapped around the circumference.
This wheel rotates slowly, and picks up water from the sump-- does everything look and sound quiet as it runs? -- The float valve has to open and close, to c ontrol the leve of water in the sump-- (The pool of water the wheel runs the mat thru--
Possibly the valve shutting off, could make a plumbing BANG-- you could duplicate that, by lifting the float mechanism and stopping the water-- does that make the noise?
If you can reach and operate the Humidistat control from near the humidifier, do so a few time-- or Have someone cycle the humidistat a few times, and you listen for that sound--
Is it in the humidifier itself, or the duct work nearby?
It might be that the humidistat wheel scrapes against the side of the sheet metal duct work? -- Sounds travel a long ways in metal duct work!
Let us know if this helps
Mack B
Jan 19, 2011 | Carrier SBP Humidifier
Vicks humidifier
Even though you change the water every time, if it's like ours you will still need to clean it with vinegar about once a week. I have a container that the insert portion (filter or whatever it's called) will sit in and has just enough room to pour in 4 inches of vinegar. Let it sit for about 10 to 20 minutes and then run water through the part where the mist comes out while holding your hand over the bottom. After a few seconds allow it all to run through. Continue and shake it really good and continue on until it is clear. I was AMAZED at what came out the first time I did this and part of the time I used distilled water. Hope this solves the problem.
Feb 27, 2009 | Humidifiers
Water for humidifier
Distilled or bottled is best. I will help prevent build up internally. Steve
Dec 13, 2008 | Hunter Humidifiers
Honeywell chronotherm III air conditoner
I had that last night. I turned off the unit for a couple of hours and it came back on and ran and cooled. I have no friggin' idea if it will work but it got us through last night.
Jun 05, 2008 | Honeywell Power Humidifier: Furnace...
Filter dries out
2 things could be happening.
#1. Your water has gotten harder in the last year and more deposits are getting caught on the filter. Try soaking it in water and vinegar for an hour. This should clean some of the deposits out and extend the life of your filters. Everytime it gets hard try soaking it.
#2. Your machine is running out of water before you can refill. When this happens and the filters dry out, they aren't as good afterwords.
I would advise trying to clean them with vinegar and water and making sure your machine is always full.
Good Luck.
Feb 20, 2008 | Kenmore 14410 Humidifier
Dog chewed up the filter cage
You can order a new cap, but you won't be able to get one with the filter ball. Every site i went to says they are unavaliable.
If you are interested in just buying the cap, here is the link:
http://www.humidifierfilters.com/parts4models.php?brand=honeywell&model=hcm630
Good Luck.
Jan 21, 2008 | Honeywell QuietCare HCM-630 Humidifier
Bionaire BCM630
Remove the water tank from the main unit. Now look down into the unit where the water tank sits. There is a small knob that you need to turn counter clockwise and the lower part of the unit incl the filter will slide out.
Sep 23, 2007 | Bionaire BCM6010 Humidifier
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
