Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool front loader washer. I have checked the plug and circuit breaker and they both work fine, however my washer does not turn on. What could be the problem?
    Novelist:
  • 222 Answers
Try to put in other plug,if the uni is no power or same problem,its means the unit have a problem,if your unit is have a digital,thats the one we need to replace,but how much the cost,check the price and the labor before you make a decision to repair,or buy the new one.
Posted on Dec 28, 2010
Whirlpool aquasteam suddenly dead, no lights at all,as if plug pulled halfway through wash. Tested plug, socket fuses all fine.
Check the fuse (circuit breaker) at the main box. Most Washers are on a separate circuit and thus if the circuit breaker opens, there will be no power to the washer.
Feb 11, 2018 | Whirlpool Washing Machines
Is there a fuse box on the Whirlpool duet steam washer? I can not get the control panel to turn on. I've checked the circuit breaker.
If you have a control panel and it wont switch on, it normally means your board is faulty. Gain access to the board and look for the live(brown) wire and the blue(neutral) wire. Place a tester on the 2 wires and see if you have the required voltage. If so, your board is defective. Normally, there are no fuses in the front loaders.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Power light doens't go o
Plug a working lamp in the washer power outlet. If it lights, the problem is within the washer (look for a breaker button on the back of the machine). If the lamp doesn't work either, look for a bad breaker, a loose neutral wire connection, or loose wire connection on the breaker. Check the wiring on the washer end as well.
Oct 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader no power
Reset your circuit breaker in the electric panel.
Jul 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
It will not turn on. No power
Check the following
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Jun 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not turn on. The knob moves but nothing happens when I turn it on. I've checked the breaker, the water, the plug/outlet, and hoses. Everything looks fine. But nothing happens.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 05, 2009 | Whirlpool LSR9434PQ Top Load Washer
Whirlpool Duet Dryer
Friend,
huuum At your service!
You said:
Everything was working fine, now we get no panel lights, the dryer light doesn't, dead in the water! Checked the plug...unplugged it and plugged it back in. Checked the circuit breaker...ok. What next?
I'm sorry to tell you that you need hands on service.
If I were there hands on I could diagnose the problem.
You may have an electronic malfunction and that only a trained technician can diagnose!
SORRY!
Bless You,
huuum
Please give me a good rating before you sign off
thank You
You will be fine
Bless You ,
huuum
Please give me the best rating for this solved solution!
Thank You!
Sep 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
