Question about Samsung SlimFit TX-S2782H 27" TV
Hdmi ports not working on back of my Samsung Slim fit model # tx-s2782h what's my next move? Thanks David M.
2 Suggested Answers
SOURCE: my samsung slim fit tv has a horizontal line which
cordless phone base was too close and was giving interference to the television moved away and solved
Posted on Sep 21, 2009
How I hook up my mhl HDMI cable to my vizio eco 1080p?
Essentially one end of an MHL cable will plug into the micro USB port on your phone or tablet while the other will plug into an HDMI port on a television (or monitor) and your phone's screen will then be mirrored on the external screen.
You obviously need an HDMI port on your VISIO which, if fitted, will normally be on the back of the VISIO unit next to other connection ports. If you have a much older Visio which does not have an HDMI port fitted by the manufacturer then you cannot use an HDMI cable obviously.
Dec 08, 2015 | Vizio Televison & Video
Seeking Parts Advice for Broken Samsung TV
I would also just buy a new board .BUT keep the old board for parts! This way if anything goes out you can compare components on the board etc and figure out what's wrong and also use the parts for repairs when you need them. Some of those boards HDMI ports have the tiniest solder joints and you can easily bridge them make the board useless anyway. These things are way more fragile than the old CRT tv's. Just be a little more careful next time.
Dec 30, 2012 | Televison & Video
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
TX-SR606 hdmi ports work when unit warms up? and on screen
Why don't you connect the HDMI cable direct to your tv. For audio run a digital cable to your receiver.
Feb 24, 2010 | Onkyo TX-SR606 Receiver
I cannot get video signal from my Samsung p1590 Blu Ray player via HDMI to pass through my Onkyo TX-SR606 AV Receiver. I get video if I connect Blu Ray player directly to TV, and have tried all HDMI ports...
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Onkyo TX-SR606 Receiver
My samsung slim fit tv has a horizontal line which
hum bar. possibly related to power supply filtering. sometimes reversing the power plug will help. check cable connections for tight fit.
Sep 20, 2009 | Samsung SlimFit TX-S3082WH 30" TV
I have the same problem with my Samsung LE46A656 A1F Full HD
If it was doing it on your old console then its the TV not the PS3.
Causes: HDMI cable (Replace cable), HDMI socket on TV (Get it repaired), If it happens on all HDMI inputs then the video board maybe faulty, Interference - location of PS3 to other equipment.
The first thing to do is move everything else away from your TV except for the PS3, now factory reset the Samsung TV and make sure your firmware is up to date my records show that an update came out in May for your TV, also factory reset the PS3 and setup the HDMI video settings using the wizrad in the PS3, now connect the PS3 through all HDMI inputs to see if its one input or all, if all inputs are the same then the TV maybe faulty.
Let me know how you get on.
Thanks
Sep 05, 2009 | Sony Playstation 3 (PS3) Console
Samsung HD 27" -- Manual Switching of Picture Size Necessary?
check your remote that should have all the features to navigate in to the tv menu.if it is not working check the remote it could be faulty or the eprom in your tv neeeds to reset or replace an eprom does a lot of function in a tv set.good luck.greetings from belize.
Nov 18, 2006 | Samsung SlimFit TX-S2783 TV
Samsung SlimFit  TX-S2782H 27" TV Logo
42 people viewed this question
Henry  Thomas
Henry Thomas
