Question about Logitech X-220 Computer Speakers
I need to know the pinout for the 9-pin DIN connector for the X-220. I have only the sub (no satelite speakers included). I need to know: - which pins to jump together to power the device - which pins are the input to the device Thank you
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
likwidstate
  • 17 Answers
SOURCE: Logitech x-230 speaker system
Ironically enough, I went on here because I have the satellites but no subwoofer! LOL, what are the odds. Anyways, if you happen to receive this information, can you please email me at ben.petrofsky@live.com?
Like I said, I'm searching for the same exact information for a similar problem and this would REALLY help as I can't power the speakers without this.
Posted on Sep 02, 2009
SOURCE: need to replace the 9 pin male plug that goes into
All I wanted was a pinout diagram for the male plug so that I could wire up a new plug. Did not want to have to re-mortgage the house to get that. Thought such info would be free.
Anyway have stripped away all the plastic moulding to reveal the connections so am OK now Thanks
Jim Goldsmith
Posted on Jan 19, 2010
SOURCE: logitech x-230 9 pin problem . i need to manualy
worked on this for 3 days but i finaly got it I had to open it an follow coper lines using datasheet, the connector is RS232 the pins are
1 = LED+
2 = IN R
3 = OUT R
4 = OUT L
5 = GND
6 = ON
7 = 5V
8 = GND
9 = IN L
so you have to put a swiths between pin 6 and 7
you should also put a potentiometer GND-IN-(AUDIO SOURCE)
and a led between pin 1 and GND
and that is it!
---POXTRON---
Posted on Aug 04, 2010
SOURCE: I need a circuit diagram for My Logitech Z-640 Computer Speakers
i have 2.1 channel speaker set it was not working what is the solution
Posted on Mar 08, 2011
What is 9-pin DIN pinout?
A DIN connector is an electrical connector that was originally standardized by the Deutsches Institut f?r Normung (DIN), the German national standards organization. There are DIN standards for a large number of different connectors, therefore the term "DIN connector" alone does not unambiguously identify any particular type of connector unless the document number of the relevant DIN standard is added (e.g., "DIN 41524 connector").
th?q=9b+pin+din+connectors&w=100&h=100&c=1&rs=1&qlt=90&pid=inlineblock&mkt=en-ph&adlt=moderate&t=1&mw=247 this is just a sample image of 9 din connector
Feb 16, 2016 | Altec Lansing Acs340 Computer Speakers
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at maurya.mohit07@gmail.com
May 20, 2012 | Altec Lansing VS4121 2.1 Channel Powered...
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
Someone gave me a YST-MS50. The left speaker (no controls) does not work. It is not the speaker or the cable from the main unit to that speaker. I find that only 7 of the 8 wires in the 8 pin cable going...
If you don't get it to work would you be willing to sell me the right satellite speaker with the controls? email me: red...4..dsc..@....g..mail.com... (just take out all the dots)
Dec 05, 2010 | Yamaha YST-MS50 Computer Speakers
X-220 cable is slightly damaged and not making constant contact with sub-woofer mate. Is there a repair where I can replace or cut open & fix the 9 pin cable? To me, the obvious problem is that the...
nothing is wrong with the woofer the connect is broken at the strain relief and the cable needs to be replaced.
You can replace the connector if you know the pinouts. You will need the connector and the schematic.
you may be able to find the pin outs configuration here.
http://pinouts.ru/
As for the connector this may take a search online.
Aug 07, 2010 | Logitech X-220 Computer Speakers
Need input connector (13 pin din?) pinout.
Call Bose. Do google search. They sell accessories on line. They are vry helpful.
Apr 24, 2009 | Audio Players & Recorders
JVC 8 pin pinout - speaker cable
Looking at the connector, there are 3 rows of pins.
Starting with the first row closest to the alignment mark:
[Power On],[Center Speaker],[Sub Woofer]
[Surround Right],[Speaker Ground],[Surround Left]
[Right],[Left]
If you are trying to connect two JVC units, you will need an 8-pin cable that has the SAME pins connected on each side. You will need to test this using a multimeter set to ohms or 'connectivity'.
There are other 8-pin cables out there like the one for apple networking, but they use a crossover pinout where pin 1 on one end = pin 3 on the other end. This is bad. JVC needs pin 1 to = pin 1.
This is a standard connector/pinout setup that JVC uses, so connecting a TH-C3 to a TH-C50 works fine. There is a bunch of intermixing that you can get away with. The only thing to keep an eye on is the power in watts that one unit sends and the other recieves. Worst case is that the speakers are quiter than expected or that you can turn the volume up so high that it can damage the speakers. In all cases, you should get desired volume somewhere on the dial.
If you are trying to wire the speaker set custom, then you will need to take note that an '8-pin' connector is actually a 9-wire connector. Along with the above pinout, you will need to add Case Ground, which is the metal circle that surrounds the pins. To make the speakers turn on, you will need to apply 12v to the Power On pin and ground the 12v source to the Case Ground outer ring.
The system takes 3 to 4 seconds to fully turn on after this connection is made. Speakers should be wired using the center pin for speaker ground and each other pin respectful to each speaker.
Apr 01, 2008 | JVC TH-C50 System
Need wiring and 9pin connector diagram
Pin 8 = Power A
Pin 9 = Power B
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Logitech X-220 Computer Speakers Logo
656 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
