Question about Samsung Refrigerators
Hi my Samsung fridge is freezing up? What do i do?
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
Samsung fridge freezer problem click here
hi what model do you have - if its the american style one
fridge freezer up is a common prob with samsung
you could have a look on youtube - there a guy who has a dedicated youtube - samsung fridge freezer repair channel
heres one of the videos >>>>>>ebay links below videos where you can pruchase spares
hope this helps , if you require parts look under youtube videos as there are links you can click onto that will take you to this guys ebay samsung spares shop ..">
Posted on Mar 20, 2011
  • 4,793 Answers
Although most freezers are frost free,a lot of fridges are not,just defrost it naturally,and set the internal temp to +2C to +5C,over filling/uncovered food and running too cold are the causes.
You did not included a model # so i could be more specific.hope this helps.......
Posted on Dec 28, 2010
Hi I have a samsung fridge freezer. Sl39wj1/xeu. Doesn't seem to be doing anything no light but is continually flashing f5
not sure what you mean water in fridge and ur assuming? did it freeze everything or not freeze? is fan not running or compressor? any noise or sounds?
Mar 14, 2015 | Samsung Refrigerators
Very noisy fridge, back wall freezing up
Possible bad freezer fan motor. I need more information such as brand and model number
Mar 10, 2014 | Samsung RS2630WW Side by Side Refrigerator
Samsung refridgerator regularly beeps with power freeze switching on and off
Sounds like a faulty temperature sensor calling and not calling for the power freeze to come on. Change the sensor!
Jan 01, 2013 | Samsung Refrigerators
Hi I have a Samsung fridge freezer the fridge is not coolinng and the freezer is not freezing but the motor is going.Regards Maria
have a look here for
this guy has few videos with various diy solutions for samsung fridge freezers
Jan 27, 2011 | Samsung Refrigerators
Hi i have a samsung cooltech fridge freezer and the fridge freezes everything overnight...turned the thermostat down to min but made no difference...best way to fix it ????
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
I hope that this will helpout in solving the problem.....
Dec 09, 2010 | Samsung Refrigerators
Hi i am having samsung fridge cooltsech plus silver nano i have a prob;em in my fridge that in winter the cooling in the refrigerator is very sytrong i have increased the temperatire to 7 degress which is...
If your veg is freezing you need to RAISE the temp in the fridge,if #7 is coldest,then #1 is warmest.SET IT TO #3.You should keep a fridge at +5C for best storage of CHILLED food.you should also adjust your fridge for summer and winter ambient temperatures.a fridge/FREEZER thermometer is ESSENTIAL.OTHERWISE YOUR WASTING MONEY/ENERGY.
Nov 12, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Freezing eggs in fridge area and freezing produce in crisper
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 29, 2009 | Samsung RB1955VQ Bottom Freezer...
Side by side refrigerator freezing up
inside the fridge there is a cold radiator which has filled with condensation or water from freezing it when say cleaned out the fridge this can be remedied by letting set for a few days outside in the sun so that water can evaporate properly or you can call a repair man and he can pull out frost radiator inside and defrost all the water out by dry wet vac and heater dryer
ice builds apon ice even a little bit can build up to a mountain same thing happended to my top end whirlpool i pulled the metal grate and defrosted this by pouring tap water over the ice which it went down the defrost tube outside water drain this helped greatly havent had trouble with ice since
Apr 21, 2008 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
332 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
