Question about Moen & Posi-Temp Single Handle Shower Or Tub Valve
How do you adjust hot water on a moan single shower handle adapter# 109113 handle# 116768 I got the handle off now what do I do?
  • 8,197 Answers
On the link below page 10 step 5.1 will tell you how to adjust the temp
http://www.moen.com/shared/pdf/instruction_sheets/ins1997.pdf
Posted on Dec 28, 2010
No hot water - thermostat not working
if u have a single handle shower unit remove handle and cover to access the water adjustments[scold protection] blue is cold red is hot faucets are shipped in coldest setting as a safety precaution need to adjust in the hot water
Dec 03, 2012 | Home
Have hot water in the bathroom sink spigot, but the shower is the single handle and turned on all the way, water is not hot...too much cold mixing, How do you adjust it?
You need to take the handle off...ususally held on with a small allen screw on the bottom side of the handle. After removing the handle there should be a dial setting.
Feb 18, 2011 | Delta & Single Handle Shower Faucet
We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Just had a contractor give me an entire new bathroom. The Peerless Single Handle Tub And Shower Faucet will only go from 90 deg down on the cold side to straight up. it want go to the hot side. What is the...
if u have the paperwork for the unit--in it will explain how to adjust the anti scold settings single handle units are shipped in cold setting u have to adjust the hot -- remove handle and on shaft will see blue and red clips adjust the red till hot water is to ur liking replace handle
May 18, 2010 | Peerless Industries Peerless& Single...
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Mar 24, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
No hot water in bathtub
its called ur anti-scold system its installed in all single shower units to adjust remove the handle and will see usually a blue and red adjustment clips move the red so more hot water can be mixed in try the water adjust until comfort level is achieved
Mar 11, 2010 | Delta & Single Handle Shower Faucet
Single handle moen shower not turning far enough
it is your shower cartrige. ace hardware $45. hot always goes first. just check if it is a posi-temp or moan trol
Dec 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen & Posi-Temp Single Handle Shower Or Tub Valve  Logo
1,938 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
