Question about Radio Shack Pro-97 Handheld Scanner
I want to reset scanner to factory settings - Radio Shack Pro-97 Handheld Scanner
    President:
  • 2,761 Answers
- Power the scanner OFF.
- Power the scanner ON. "Multi-system Trunking Scanner" will display.
- Press 0 (zero) while the above message is showing.
- Press 1 (one).
- Press ENT. "Initializing please stand by" will display for about 5 seconds.
When the process is complete "M 000" will appear on the top line of the display, and "Bank 0 Ch 00" will display on the third line.
NOTE: The above will delete/erase ALL information that you have programmed into the scanner and restore it to the original factory settings.
Bill B.
Listening in since the 60's
Posted on Dec 29, 2010
Squelch on maycom 108 works on VHF but not Airband. Was working last week?
factory reset: Push and hold AI + FUNC and turn the scanner on.
The message INITIAL are shown in the display..
Now it's reset to the factory settings,
with 124 MHz stored i memory channel 1 in the Air band,
and with 156 MHz stored i memory channel 1 in the "VHF band".
Oct 08, 2016 | Maycom AR-108 Scanner
How do I Reset BCD436HP?
I can't find anything about a reset for the scanner.
Perhaps you refer to the manual, for setting back to factory settings?
Or how to program or put in a new program, using a micro SD card. http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/BCD436HPom.pdf
May 31, 2014 | Uniden BC346XT Handheld Scanner
Reset bct8 back to factory settings
Turn the scanner off, then hold down the 2 , 9 and HWY (State) button....all three at the same time and then turn the scanner back on. This does a full reset to factory settings.
with radio off, press and hold 2, 9, & hold button, then turn on and hold all three for at least two seconds to reset.
With the scanner off, firmly hold down 2+9+State at the same time while turning the scanner on. (You may have do it several times) When you see (Clear)
its reset.
Dec 24, 2013 | Uniden BCT8 Base Scanner
Reset ImageFormula scanfront 300 to factory settings
Below you have link for manual in page 79 you can read how to reset to default values.
Manual
Nov 29, 2013 | Canon imageFORMULA ScanFront 300 4574B002
How to do a factory reset on pro 107 iscan scanner
Hi Anthony,
I'm not familiar with your 107 (iscan) radio scanner, but every scanner I have ever owned has a reset button, which is usually recessed.
Look for a tiny hole eith n the lower front panel or rear panel, it should be marked(not always) reset, you will need a thin ball point pen or similar to press this button in for aprox 3 seconds, while the radio is turned on.
By doing this, you would have restored it to factory default settings.
I hope I have been of assistance to you.
Cheers,
Peter
Feb 16, 2013 | Radio Communications
When I scan with Symbol DS6707 I normally get letter b showing up after the scanned numbers. Please help!
There is probably an rule set on the scanner from the previous user. To be sure that you are not using any old settings. I would suggest to reset it to factory settings.
Connect the scanner to your Desktop PC. Download the Reference Guide for DS6707 at the page http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=8397807apdf Scan the Barcode Set All Defaults Scan the Barcode Erase All Rules
The scanner is now in factory settings and you can configure it as you need.
Oct 26, 2010 | Symbol DS6707 Barcode Scanner - P/N...
How to reset radio shack pro 97
As soon as the Scanner is turned on press the keys 0 and 1, this should reset it back to factory settings.
Here http://wiki.radioreference.com/index.php/Pro-97 is a link to a Wiki page about your Scanner.
May 14, 2010 | Radio Shack Pro-97 Handheld Scanner
I have pro 135 from radio shack. How do I reset it and keep the channels that are programed in it?
The RESET function will clear everything that you have programmed into the scanner and restore original factory settings. You can, however, restore the 150 pre-programmed frequencies after a RESET.
To RESET:
- Hold down the 2, 9, and PSE keys and power the scanner ON.
- CLEAr appears on the display as the scanner resets.
- Do not power the scanner OFF until CLEAr disappears from the display.
To restore the original 150 pre-programmed frequencies:
- Turn the scanner power OFF.
- Hold down the 3 and ENT/PGM keys and power the scanner ON.
Bill B
Apr 28, 2010 | Radio Shack Pro-82 Scanner
Ricoh IS200e Web interface password
default login: scanner
default password: password
Jul 17, 2008 | Office Equipment & Supplies
Psc qs6000 plus
If, during the programming session, you find that you are unsure of the scanner's settings or wish to reset the scanner's configuration, use the Return to Factory Settings label available in the Programming Overview section of the above programming guides. (Note: Use this label with caution, as it will disable ALL features that may have been programmed since the scanner's installation.)
Apr 08, 2008 | PSC QS6000
Radio Shack Pro-97 Handheld Scanner Logo
558 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
