Question about Microwave Ovens
Good afternoon, In trying to turn the circuits back on for my washing machine, I accidentally turned off the circuits for my whirlpool range. Turned circuits back on and now the entire range (stove, oven, light, clock) does not work. Not sure what the problem is. Everything was working fine before I turned the circuits off. Please help! Thank you.
    Novelist:
  • 222 Answers
I think we need to replace your breaker,some is corroded due to old one,or the breaker is in high ampere or overload,call the electrician to check all your wiring in your house to make sure.for your safety.
Posted on Dec 28, 2010
No power, no lights, no clock. Nothing works on my Samsung over the range microwave model SMH17138
Your microwave may be plugged into a regular receptacle which is on a circuit breaker often in a cupboard above the range.Check around to see if anything else is not working. Check your circuit breaker box for a breaker that needs resetting. If you see one out of line with the others turn it off and then back on. Good luck..
Dec 09, 2016 | Samsung Microwave Ovens
I have a frigidaire over the counter microwave and the turntable quit working
Good Afternoon Friend, I appreciate your post!
If the turntable of your Frigidaire microwave has stop working, often the possibilities include one of three culprits:
  • Power Supply
  • Turntable Turned Off
  • Turntable Support Damaged
I always recommend resetting your microwave first before reaching out to a professional. You can do so by unplugging your appliance or flipping the circuit breaker for about ten minutes and then turn on your microwave.
Best of luck!-Z
Sep 07, 2014 | Frigidaire Over-the-Range Microwave
Indicater light shows S. E. what does it mean?
Good Afternoon Sandra, thank you for allowing me to assist you!
Typically error code SE indicates a shorted key on the keypad. Try unplugging the microwave or flipping the household circuit breaker off first. Wait approximately ten minutes and turn the unit back on. If the error code continues to display, then I recommend contacting a professional to make a precise diagnosis.
Oct 05, 2013 | Frigidaire Over-the-Range Microwave
Thanks for taking my question. Model Info: Whirlpool Accubake system electric range Super Capacity 465...... my wife moved the range to clean behind and it sparked at the plug and blew the breaker. ...
try fitting a new plug. if you do cut back the cord back at least 3 inches try it again. before you do check socket with another appliance.let me know if that fixed it or not
Jul 26, 2011 | Microwave Ovens
Light bulb not on and microwave not turning on. Was working fine in the am but went to warm something in the afternoon and the light wouldn't come on and didn't warm the coffee.
Firstly check fuses in your microwave. You will have to take off the outer casing and check on the power circuit board to see if there are blown fuses.
Best wishes,
Graemevm
Jan 22, 2010 | Whirlpool RMC275PD Microwave Oven
Whirlpool Range RF315PXDW. Electric range. Top burners and oven will not turn on. Clock on top of stove and oven light turn on. Oven preheat timer operates but heating elements in oven do not turn on....
It sounds like you are missing part of your input voltage.
I would take a voltage reading at the receptacle and confirm you are reading 220-240VAC. Some homes have the 220 service receptacles wired up with two 120 volt breakers to make up your 220 service. If your home is configured this way, you may have one of the breakers tripped. Or, the receptacle itself may be bad. If you confirm you have the correct voltage at the receptacle, your power cord may be bad.
The reason the clock and display will still appear to work is because the clock only uses 110-120VAC and is tapped off the source voltage. The surface burners and the oven heating elements, however, require the full 220 service.
If you are confused by this explanation, please post back and let me know. Hopefully, this is a problem that will not require any parts or a service call. If the power cord is bad, you can purchase a replacement at any hardware store. I hope this information is helpful.
Dec 19, 2009 | Microwave Ovens
Does the rf375pxdw whirlpool range have a fuse or reset button? burners and oven does not work. there is power from the 220 plug into the range and the clock operates but not the 220. I checked circuit...
No reset buttons or fuses. Find the circuit breakers for the unit, it should be a double breaker with at least 40 Amp rating. Push it to the off position HARD (make sure not to pull the breaker out of the panel doing that). Turn it back on. Check voltage in the range power outlet. It should measure 220-250 Volts between the right and left connectors, and 110-125 Volts between the center and each side connectors. If not - problem is in the wiring or breaker. If you get those voltages and the range is still not working - problem is in the range itself. Check for shorted and loose wires.
Dec 18, 2009 | Microwave Ovens
Unit not getting power
These machines seem prone to having a bad magnetron. Look for a circuit breaker near the power cord entry point. If tripped, reset and try to heat a cup of water. If it makes a loud buzz and then pops the breaker again, the consensus view is a bad magnetron. This is one repair that is recommended to send out. (~$150). You need to evaluate the probable cost vs a new machine.
Apr 13, 2009 | Whirlpool MH7155XM Microwave Oven
Whirlpool microwave 2003 stopped working & inside light is on
The most likely cause is a blown fuse or a kicked circuit breaker. Look in the cabinet above the microwave and see if the microwave is plugged into the ou let in that cabinet. If it is plug a blow dryer or some other little appliance in to that same outlet to see if you have power there. If no power go to your electrical panel and either replace the fuse or turn the breaker off and then back on.
Mar 18, 2009 | Microwave Ovens
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
