Question about Vacuums
How do i charge my i stubble 7890u it came with 2 pin plug i changed it to a 3 pin plug but it keeps blowing the socket
    Master:
  • 383 Answers
It sounds like you have a stray wire shorting in the 'new' 3-wire plug..
Or some other form of mis-wiring--
Look at the plug, and make sure that your 2 wires are connected only to the 2 spade shaped plug blades--- NOT to the Ground plug.
May I ask-- why you converted to the 3 wire plug?
The 2 wire plug worked in the 2-wire plus ground receptacles, OK, didn't it?
Mack B
Posted on Dec 28, 2010
How do you get to the fuse in the dc28?
The 3-pin mains plug will have a plastic fuse holder which can be levered open with a small screwdriver. Look on the pin side of the plug. There will also be small writing on the plug to tell you which size of fuse is fitted to the plug. Replace with the same size of fuse. It is important to note that the fuse in the mains plug is only likely to blow if there is an electrical issue inside the machine, so replacing the fuse may just result in the fuse blowing again. If this happens then the vacuum needs proper checking and repair. DO NOT try using a bigger fuse, as you may cause more damage to the vacuum, or cable overheating or risk of electric shock.
Jan 09, 2017 | Dyson DC28
When I plug it in to charge the blue charging light comes on for 2 or 3 minutes then goes out and charging stops. Have I blown the charger by constantly leaving it plugged in? Please help!
Hi Alvina, it's Jack at Dyson.
DC59 will display a blue indicator light at the base of the hand grip while the machine is taking in power. The light will go out when the machine is fully charged. DC59 will take 3.5 hours to charge fully when the charge is completely depleted, but it will take less time than this if there is still some charge remaining on the battery after use.
Please note, the machine's intelligent control software is designed to ensure the battery only takes in enough power to recharge, and to keep itself topped up. It's safe to leave the machine connected to the charger at all times when not in use - the machine is designed to be stored in this way, so it's always ready to go when you need it.
From the information you've provided, I'm not clear on whether or not you're finding your DC59 works as normal once the blue charging light goes out, or whether it's not working at all. To make sure everything is correct, please get in touch with our experts directly. We'll be happy to talk you through some simple diagnostic checks when you have your machine easily to hand.
You can reach the Dyson Customer Helpline by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
We'll look forward to speaking with you.
Feb 27, 2016 | Dyson DC59 Animal Bagless Cordless Stick...
I opened the vacuum,i checked the cord and it is in the correct form,not tangle etc..still doesn't work after pluging it the wall out let..help
Possibly a broken wire. It is common for the flexible cable to break at the 3 pin plug end from constantly pulling the cord / plug out of the socket or if its a retractible cord, they get broken where the cord enters the machine rewinder. this happens when the cord is pulled out to its maximum length all the time and eventually cuts through the cord. I would try a new 3 pin plug first.
Apr 13, 2015 | Vacuums
My karcher window vac does not seem to charge?
Have you tried to take it all apart just a small bit of rubbish will stop it from working.
Jul 24, 2014 | Karcher WV50 Window Vacuum
I have 2 cotton candy machines. One says 25 amps and the other says 30 amps on it. I would like to take either one of them to parties at people's houses, but am afraid of blowing fuses. Is there...
Hi marieu2005..
The only way to avoid blowing breaker or fuses is to ask the person do they have an available 25/30 amp socket, and you need it to fit the plug you have on your machine.
Please take time to rate me
Sep 02, 2011 | Vacuums
My Braun tootbrush has never charges-i have a 240 & 11v shaver socket but nothing seems to happen when i plug it in?
When charging a device on some type of charging block you need to plug it into a regular 110 socket as the block has the correct modifications in it for the device that it charges. This 11volt shaver socket is for older shavers that dont charge up you just plug them in and use them.I hope this helps you ....good luck
Oct 13, 2010 | Vacuums
Light says its charging but it wont turn on
Well first of all you may check that the charger (adapter) is working or not, you may use a volt meter to check it out or use another charger to make sure....... further you may follow the step below -
1. Remove the battery pack from Vacuum.
2. Hold down the power button for five seconds.
3. Reinstall the battery to reset the system.
4. Plug the Charger directly into vacuum.
5. Charge the battery untill the power light is solid green again and keep the vacuum on the charger for an additional 72 hours (3 days). Important: Do NOT interrupt this charging cycle.
If further you have the same problem it means it's time to change the old battery with new one.
Good Luck!!
Thanks for using FixYa!!
Sep 18, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
Light goes on my kone but it won't work
Good Luck!!
May 19, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
Vacuums Logo
144 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
