Question about ASUS A7V8X-MX SE Motherboard
My pc wont boot up after i tried putting new ram in the other ram didnt fit
  • ASUS Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Dec 28, 2010
My Dell optiplex Gx240 wont boot after installing new ram . It saids stopped at check point vcls.
The new RAM has a problem. Insert one at a time and power up. You may have a bad RAM stick.
Oct 26, 2012 | Dell OPTIPLEX GX240 P4 1.7GHz 256MB 20GB...
My parents have a Dell Dimension B110 computer and they were going to install some new RAM. They took the old ram out, realized they bought the wrong kind, put the old ram back in and now the computer...
Make sure the ram is installed correctly. You didnt break it when you put it back in did you ...
If you get it going again... please go to www.4allmenmory.com and have them scan your computer. Review their results and recommendations
Im sorry their computer isnt working.
Thanks for using fixya.com
a
Oct 26, 2009 | Computers & Internet
Asus p5 vdc-x motherboard not recognizing ddr2
Ok i am just guessing here
maybe your motherboard does not support
ddr2 rams and hence it wont boot up as it does not detect any ram in the slots......
try to boot with one old and one new ram (ddr and ddr2) and post the result
are you sure whether the ddr2 ram is supported?
Jun 30, 2009 | ASUS P5VDC-X Motherboard
Acer aspire L320 wont boot up can hear drive running I'm fixing this L320 for someone and it also has the same problems as above, i've took the system apart, changed the memory, put the hdd into my own...
When you say wont boot is it getting and video ouput at all? I'll assume its not. Check all your connections. One time i didnt have a SATA cable fully seated, it was just at the slightest angle creating a short and freaking the whole computer out (it was my dvd drive too!). Check all the cables and ram is fully seated as well as the CPU. Only try to boot with one ram stick at a time, possible dead ram stick too. IF its a cheapy motherboard best to just replace it.
Jun 03, 2009 | Acer Computers & Internet
Screen goes black
i had the same problem, it ended up being a bad stick of ram for me. what you need to do is pull out all of your PCI cards, and try to boot, if it still doesnt boot, pull out a stick of ram (if you have 2) try to boot. if it still doesnt boot, swap out the sticks of ram. if the pc boots after you pull out your PCI cards, put them in one-by-one, if it boots after you put a PCI card in, leave it in, and put another one in. once you find one where it wont boot, scrap that card, it is damaged. if you get all of your PCI cards out, and back in, and it still wont boot, try switching your jumper blocks, you will have to google what jumper blocks are its too hard to explain. if that doesnt work, and you only have one stick of ram, you proably have bad ram. try to find a buddy with good ram and see if he will let you borrow it to try, but make sure it is the same kind of ram. if your buddy's ram works, go out and buy a stick of that ram. if all of the above doesnt work, you have a processor problem, and you are better off buying an brand new pc. because processors arnt cheap, and they are easily damaged. hope this helps.
Apr 30, 2009 | Gateway GT4024 PC Desktop
Dell 6000 Inspirion wont boot after trying to replace RAM
use ac power
try the 1 gig in each slot make sure it's secure.
If system still won't boot
then restart and try to get into bios setup
then set to default settings restart
if still not successful then replace the old ram make sure it's secure in the slots and restart
Then i would suggest taking new ram back and if you give them your make and model they can suggest ram for you
Feb 15, 2009 | Dell INSPIRON 6000 CENTRINO...
Computer wont boot
Try disambling the system. Clean it with a wind blower. Check BIOS battery capacity. Replace if possible. Power on the laptop. Do you hear humming sound from hard disk ? If you hear sssssssshhhhh sound from hard disk; it's OK. Replace RAM with new one. If problem still exists Than change main board. Hope that not happen. Keep informing.
Feb 02, 2009 | Compaq Evo N1020V Notebook
Dell laptop inspiron 5150 wont come on
Did you try re-seating the ram? I repair and resell computers. The most common problem with laptops is the memory modules become unseated from moving them around. The screen won't light on most of them if the ram becomes unseated. Just remove the ram cover on the bottom, remove the modules and reinstall them. A bad module will do the same thing. If reseating them doesn't work, try removing one and then the other to see if you have a bad module.
Nov 25, 2008 | Computers & Internet
Dell 5100 laptop memory upgrade
try removing it again power on then off. again put yr ram it should boot. less u want to may be remove the processor then put it back as well at times they could stop system from booting
May 23, 2008 | Dell Inspiron 5100 Notebook
Computer wont boot up
hi, If it is a continuous beep then it a RAM error not a harddrive, so you try to change the ram slot if it doesn't happen change the ram thanks arun
Sep 04, 2007 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
ASUS A7V8X-MX SE Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
