Question about Toshiba Satellite A100-S8111TD Notebook
Tosiba l300 total lost its not booting screen blank
  • 2 more comments
  • torum Jul 07, 2008
    i wanted boot factory status but noting happening all i get is blank screen
  • nelnel68 Sep 08, 2008
    when u turn it on it flashes logo and then goes black and u cant see nothing else
  • Matt Major May 11, 2010
    What happened to make you want to reinstall?
    Do you get any bios mesages?
  • 63 Answers
Possible that the motherboard is dead on this one i am afraid, if you can get hold of a POST probe analysis card it may tell you, like the one at this link:
http://stores.ebay.com/post2all-store_Diagnostic-CARD_W0QQcolZ4QQdirZQ2d1QQfsubZ664224QQftidZ2QQtZkm
Posted on Jul 08, 2008
Satellite pro L300 screen is blank. Power light is on (green), battery light is yellow, HDD light is off.
Sounds like it's broke. Blank screen means it's broken, battery light is yellow I beleive it means time to replace the batteries.
Apr 16, 2011 | Toshiba Satellite Pro L300 Notebook
Please help my Tosiba L300 is asking for a BIOS password , i cannot access it and my recovey disc will not work
All you need to do to access the BIOS is to reset it. To reset the BIOS you would need to remove the CMOS battery and place it back, the BIOS password will be back to default and you able to access the BIOS.
NOTE: the CMOS battery is located at the back of your laptop, or it will be much better for you to call a local technician and have him do it for you.
For you to use the recovery disc, once you boot the computer press F12 then select to boot your computer to (CD\DVD drive) make sure that the disc is in the disc tray, then press enter. Your computer will automatically boot into you recovery disc.
Cheers
Feb 27, 2011 | Toshiba Satellite Pro L300D-EZ1002X...
Cannot display anything when booting up. no disk activity read. screen blank
Its a black screen,is it?
Do you see a Blinking cursor?
Click the below link for a resolution.
http://support.microsoft.com/kb/314503
Hope this helps.
Cheers!!
Jan 03, 2011 | Toshiba Satellite Pro L300 Notebook
I have a tosiba l300 have no lights and wont power up
check power jack or any ic burn and short
if fix your problem click yes for vote
Dec 29, 2010 | Toshiba Satellite Pro L300 Notebook
My toshiba l300 only has a black screen!! when i start it up the lights come on at the bottom but the screen remains blank!!
L300 series laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Dec 28, 2010 | Toshiba Satellite Pro L300 Notebook
My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
May 08, 2009 | Toshiba Satellite Pro L300 Notebook
Tohiba l300 completely blank screen
If the screen is always blank, even on startup , before loading Windows, than this is probably an hardware fault.
Try unplugging the laptop and removing the battery at the same time, wait 5 minutes, then put the laptop together. This will drain power and reset the laptop.
If that does not work, and you get no pictuer under any circumstance , then there is a fault.
If the screen is black with no light , then it is either a faulty inverter or a problem on mainboard.
If the screen is all lit, but is blank with no signal, then it is often because of a bad LCD ribbon cable , but can be again the video chipset on the motherboard.
Try connecting to an external monitor, if it works then problem is restricted to LCD/inverter and ribbon cable, if it does not work on external monitor is usually a bad video chipset on motherboard.
May 06, 2009 | Toshiba Satellite Pro L300 Notebook
Screen blank
The problem is likely the inverter for the LCD screen. Do a search on laptop screen repairs and you'll find out more about it. doc...
Aug 25, 2008 | Toshiba Satellite A15-S127 Notebook
Tosiba Satellite A105-S2716
Try to use ENABLE VGA MODE when booting Windows.
1. Restart computer.
2. Press F8 continuously untill selection tabs appear.
3. Select ENABLE VGA MODE.
If this procedure works, adjust the Monitor setting or display setting on your control panel to lower settings.
If this procedure works, please spare a little time to rate my solution.
-mrsolution
Jun 12, 2008 | ASI CL51-15 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
