Question about Seiko Melodies in Motion Clock
The clock face opening movements gets stuck and doesn't close. Sounds like it is clicking and the face stays in its open position.
2 Suggested Answers
gemineye61
  • 831 Answers
SOURCE: my seiko motion clock face opens and does not
Thank you for contacting FixYa
I am not as experienced in the clock side of Seiko, but I did find their website and it is filled with great recommendations for clock repair. I would highly recommend you contact Seiko on this.
Best regards. Here is a link to go to:
http://www.seikoclocks.com/#FAQ
Thanks for your rating too!! Jewel
Posted on Sep 02, 2010
How do I get the chimes to work on a howard miller grandfather clock they worked fine till I rewound the weights and stopped
There are a number of things that can cause this. The most obvious is to ensure the weights have been wound up (either by pulling the chain or using the key that comes with the clock). Next is to ensure the clock isn't on "silent" mode. Some clocks, especially the more expensive models, have a small pull rod just behind the clock face. You can usually find it by opening the front door, and looking just under the wood frame the surrounds the clock face. Pull or push to enable/disable silent mode. The next option is to look at the clock face/dial itself, check to ensure it's not on silent. Sometimes there is a lever on the right or left of the clock face. Next, some "triple chime" clocks have either a turn dial or lever on the left or right of the clock face. This lever usually has four options Westminster, St. Michael's, whittington and silent. Check to ensure it's not on silent. If it's on for example Westminister, try moving it to St. Michaels. If the clock then starts to chime, you know there is an issue with the movement that needs repaired. You can also open the clock, if you feel comfortable and check the lifting levers aren't stuck, I've found this a few times. Additionally, while it's a bit hard to explain, on some movements there is a long rod that pulls almost all of the rods back at the same to make the "bonging" sound when the hour chime arrives. This sometimes ends up misplaced on the wrong side of the chime hammers. As you can see there are a number of things that can cause a clock to stop chiming, but a little research on your model and some confidence and you can usually fix most problems fairly easily. The only exception is if the movement has been neglected over the years (failure to oil etc), in which case a rebuild may be required.?
Dec 02, 2017 | Home
Sunroof won't close
see the diagram attached and fix it. God bless youaa64eb51-7e11-4e93-a5bc-68a552df4913.jpg3d325aa6-02b4-4a16-b487-b8a581cd3d55.jpg
Jul 15, 2013 | 2002 Toyota Camry
GMC Envoy 2004 XUV tailgate won't latch closed. Pressure switch makes latch click but when I go to close it, it does not latch.
Two things happen. One the latch is already latched and therefore it's closed before the gate shut, When you try to close it you might notice that the door don't close all the way. This doe'snt have to be thwe case. the other thing that happens if the lock mechanism is working, You here it click? The latch is stuck as the opener is stuck. You might get lucky and spray the latch with Blaster or other rust buster type penatrant. Theres angles though the opening of the latch . Spray on several angles and repleatly close the door trying to vibrate the Penatrant into the stuck area. Looking at the latch use a screw driver to move the latch and see if you can cycle it though it's positions to see if you can latch and unlatch it with the tool and reopen by pullung the handle ( you may need to try ther inside handle too and even the remote openner if you have one. Ussaaaly you need to push the button twice to open the rear hatch so it may take a few trys and spraying to get it to come loose.. Some vehicals stay closed a long time and stuck is the way to think.. But if the door is used often the linkage inside the door mayh have come off the the latch is closed and the linkage doesn't open the laTCH AND THE THING MANAGED TO GET CLOSED WITHT THE DOOR OPEN.
May 09, 2011 | 2004 GMC Envoy
The trunk of my car doesn,t shut properly...you have to slam it really hard for it to close properly. I,ve tried W-D40 but that only helped a little. Any sugestions, 98 hona accord
Two possibilities:1) The latch part (the one installed in the chassis, not on the lid) has adjusting screws, these might have become loose, pushed down, and the lid part cant reach it when you close it. 2) The remote cable lid opener might be stuck on the open position, not allowing the lid to lock. Check the remote tab by the driver´s side for freedom of movement, and proper return to rest position.
Sep 27, 2010 | 1998 Honda Accord
My oven stays on, only way to shut off it to shut breaker
Do you mean it continues to heat, or the indicator "says" it's on ? These wall ovens have notorious problems with the erc (clock/timer) could be a relay stuck in the closed position. trip the breaker, pull out the erc and visually inspect it, or if you're really inclined check to see if the relay "cycles" (clicking on & off/open & closed) through out operating.
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
Top of printer is stuck in the open position showing cartridges
i had the same problem: the acess cover was locked in the open position. i disassembled the whole lot including hinges( not a good advice). try some silicone spray( no mineral oil, but maybe cooking oil) directly into the hinge and bring some movement into the lid. there are no gears or latches that can lock the hinges.
Jul 18, 2009 | HP Photosmart 3210 Printer
Cant get back door to stay closed . The lock is stuck in locked position I think and the door is open. When I go to close it, it is'nt staying closed. Had to duck tape it to stay closed. LOL! I keep...
It sounds to me ( correct me if I'm wrong ) like the door latch on the side vertical edge of the door is in the LOCKED POSITION. In order to unlock it perform the following. First electrically with the LOCK button UNLOCK the locks. Now with one hand hold the OUTSIDE DOOR HANDLE IN THE OPEN POSITION, while at the same time FLIPPING OPEN THE LATCH. All Done . Now you can close the door. Hope this helps
Jun 27, 2009 | 1997 Chevrolet Lumina
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
2002 Oldsmobile Alero Sunroof Stuck in the Vent position
The sunroof continues to open and close normally from front to back, but the vent stays open.
Apr 01, 2009 | 2001 Oldsmobile Alero
Face is stuck in odd position, won't close/open play
does your stereo have a reset button ?or does it have FACTORY SETTINGS option in the settings menu ?
First try these options ,then write in FixYa with the model number .
Jul 09, 2008 | Car Audio & Video
Seiko Melodies in Motion Clock Logo
78 people viewed this question
Top Seiko Home Experts
Jimmy Accardi
Jerry Greenberg
Jerry Greenberg
Are you a Seiko Home Expert? Answer questions, earn points and help others
