Question about Hoover Washing Machines
Hoover washing machine, VHD9123D - Showing error code E07
Good morning,
I have the a Hoover washing machine, as listed, and after use this morning has shown error code E07.
The machine will complete a wash programme, showning end on the display, when complete. But if left the display will show E07.
If the machine is turned off for a period of time and then turned back on the display is clear of this code, and can be used with no sigh of malfunction. But the code will always show after a wash programme has completed.
Is this serious and can I continue to use the machine?
Your assistance would be appreciated.
rickead1
  • 1998 Answers
SOURCE: I have a hoover washing
e o2 is a not filling with water error have u checked the lines going into the machine as well as the water valve? please remember to rank how this post helped and write back for futher questions thanks again
rickead1
p.s. u can also goto this site and it will help you diagnos your machine http://service.hoover.co.uk/fault-finder/FaultFinder.aspx?Section=11
have a great day
Posted on Aug 17, 2010
caroldon
  • 17130 Answers
SOURCE: once its completed and shown
It is possible that the program controller, the door switch has to be checked. if the program controller is not working to reset due to a possible failure of a capacitor this can happen.
Have the washer put on for a day or so and tried if the situation improves. Similarily after the program ends, press and hols stop/pause button , switch off and try if the program can be set up.
make sure the door switch is latching well or use a cleaning spray to wash the contacts.
Posted on Sep 30, 2010
EO2 on my washing machiner
Posted on Feb 01, 2011
Macmarkus
  • 2605 Answers
SOURCE: washing machine unable to complete
Hello, welcome to FixYa.
I will start by saying your post indicates it is a washer, however if you could post the complete model number, make/brand name and the approximate age I can speak directly about your's instead of generalizing.
Hopefully you can appreciate there are many differences even within one brand, let alone an unknown brand. On most the "no spin" is indeed related to the pump/drain as you indicated is clear, however it can also be due to a lock, pressure switch, control, motor etc etc...but I'll need to clarify the model number before detailing much of course. I'll watch for your reply before moving forward.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on Jun 06, 2011
SOURCE: Hoover 10kg washing machine, going
http://www.fixya.com/support/t10143344-hoover_
Hi take a look there.
kvedja
kolbrun
Posted on Aug 17, 2011
What is error code 7 on hoover wmh168d?
Louise, E07 means "Motor fault. check motor, tacho and associated wiring, check drum has not jammed" Presuming you can spin the drum by hand, I'd put my money on the carbon brushes in the motor being worn out and needing replacement
Sep 23, 2015 | Hoover Washing Machines
EO7 error code
E07 - "Motor fault. check motor, tacho and associated wiring, check drum has not jammed" Probably worn out carbon brushes need replacement
Aug 30, 2015 | Hoover Washing Machines
Seems to be washing ok but at the end of the cycle it is showing code e07
sorry but what can we do when there is no make or model listed we are not mind readers nor magicians
May 13, 2015 | Washing Machines
Error code E07 on my Hoover WDYN 854 DB results in me not being able to open door after a wash cycle any ideas how to open door
Switch off and for Door lock fault or Motor fault .
Check both are ok and make sure nothing is jammed or restricting the operation as it is according to which main board is fitted to the machine.
Feb 02, 2015 | Hoover Washing Machines
I have an error code E07 on my Hoover WDYN 854dB which results in me not being able to open the door after a wash cycle any idea how to open the door
make sure its drained 1st even drop hose to ground level which will gravity drain then door should open, could be blocked filter.
I cannot get my washing machine door to open and alos have error code e07?
On your washing machine control panel you have little icons, find the security. Icon and it should have a line going from it to another button on the control. panel. Press both buttons at dame time and hold till it enters service. Mode. This should make it so the door will open, and will probably tell you what is wrong. with. the machine
Oct 14, 2014 | Hoover DYN8164D White 600 mm Washer Front...
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Error message e07 showing up on washer dryer model w856d Hoover
E07 is listed as a faulty door interlock switch or Jammed motor, please remember:
POWER OFF & PLUG OUT BEFORE CHECKING.
If you don't have the equipment or knowledge to safely check your machine, please call a good local repairman.
Jun 09, 2011 | Washing Machines
I have a hoover washing machine vhd9123d and error E02 keeps showing up. Filter seems to be clean etc.
rickead1
have a great day
Aug 17, 2010 | Hoover Washing Machines
Washing Machines Logo
363 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
