Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Robinair Maintenance Manual calls out the fliter as part number 34724. Figure 12 shows two (2) o-rings. Manaul does not give the part numbers for these o-rings?
    President:
  • 180 Answers
You don't need these two O-ring part number as seperate part. because 34724 is part number of filter & two O-rings, This all will come together. so don't worry you have the right part number,go ahead!
Hope this will help you.
Posted on Dec 29, 2010
Change number of rings on a vtech cordless phone system CS6719-16
The CS6719-16 isn't an answering machine. Please give us the make and model of the answering machine on which you'd like to change the number of rings.
Apr 08, 2014 | Vtech CS6719-16 Cordless Phone with Caller...
Tip
Set iPhone+Others for how many rings before voicemail picks up
By default, the iPhone rings 15 seconds before going to voicemail.
1. Figure out your voicemail access number. Dial *#61# and then press Call on your iPhone's keypad. The first block of text you'll see on the screen that comes up will be:
Setting Interrogation Succeeded
Voice Call Forwarding
When Unanswered
Forwards to +1XXXXXXXXXX Enabled
Where +1XXXXXXXXXX is shown as an actual number - write this number down because you'll need it in the next steps.
2. Dial *61*+1XXXXXXXXXX*11*tt# where +1XXXXXXXXXX is the number you wrote down from the first step above and tt is the length of time in seconds for which you want your iPhone to ring. To get the + sign to show up, hold down the 0 key for a couple of seconds and release it when it turns into the + sign in the readout above. Then press Call.
on Mar 08, 2011 | Cell Phones
Increase the number of rings on iphone
http://www.fixya.com/support/r8598373-set_iphone_others_many_rings_before
When Unanswered
Jan 20, 2012 | Apple iPhone 3G
How to change the filter on a 34700z
Swithc on the machine & first press the MAIN MENU key,then keep pressing UP or DOWN arrow key till scree show "CHANGE FILTER" option. Then press "YES" key & now just follow the on screen message(Do not skip any option while active "CHANGE FILTER'').
Filter located on back side of the machine & fixed with the manifold assy.it's long black color & you may see the sticker with part no# 34724 (spin-on filter dyer).
Apr 07, 2011 | Robinair Cool Tech 34700Z Recovery,...
I have lines 1, 2 and 12 hooked up. 1 & 2 have their own phone number and ring fine, line 12 has it's own phone number and won't ring at all. The line still blinks when someone is calling, and when I...
It should have been programmed to ring somewhere and it probably is because you have a blinking light. It's programmed from the maintenance console under ICD groups. It's unusual to put an odd line on the 12th port of a card, but it is what it is. Cards come in 8 or 16 ports. Your PTPM or PM will have access and programming instructions.
Carl
Mar 24, 2011 | Panasonic KX-T7630 Corded Phone
A window glass 4 ft. 2 in. by 2 ft 10in. find its area. show the figure
Below is calculation of window glass area :
4.167 ft '------------------------------------'- ' ' ' ' 2.833 ft ' ' '------------------------------------'--
Total area = 4.167 ft x 2.833 ft = 11.81 ft2
Dec 04, 2010 | CRL Fixed "All Glass Look" Window for Side...
I need to replace the filter in my Robinair 34700Z machine. Where is it located? And where can I find a manual to go with this machine? Mine is missing. . .right when I need it.
Press the main menu key,then upper arrow & go to "Change filter" option,then press "Yes" key & now follow on screen message(Do not skip any option while active ''change filter'' option).
For user manual you can try to robinair web official site www.robinair.com
Apr 20, 2010 | Robinair Cool Tech 34700Z Recovery,...
Incoming call doesn't show what number is calling
go to page 42 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
Feb 19, 2009 | Panasonic KX-TG1033S Cordless Phone
# of rings
Hi Sharon,
The rings you hear when dialing your phone number is a machine in the local telephone office that is in place so you have something to listen to while your call is being processed and not your actual phone ringing, also the caller ID requires one to two ring cycles to gather the information it displays on your screen therefore the amount of rings you hear when calling a number rarely matches the actual number of rings at the phone you are calling. There is no programming in the Samsung 100 to change this as it is controlled by your local phone company. Hope this helps explain the situation, Good Luck
Jul 29, 2008 | Samsung DCS 12 Corded Phone
Unreceivable
Manual can be found here: http://www.samsung.com/support/productsupport/download/FileView.aspx?cttfileid=526982&type=Multi+Function+Printer&typecode=16&subtype=Laser+MFP&subtypecode=&cmssubtypecode=1601&model=SF-5100I&filetype=UM&language= Does the unit ring at all? If it does do the following (taken from the manual) Receiving automatically in FAX mode 1. Press Rcv.Mode/Contrast until the display shows ?FAX MODE?. 2. When you get a call, the machine answers the call on a specified number of rings and receives a fax automatically. You can change the number of rings. See ?RINGS TO ANSWER? on page 5.4. To adjust the ringer volume, see ?Adjusting volume? on page 2.8. If the phone is not ringing, then the call is never even getting to your fax machine. Hope this helps If you need more information, please ask before rating this solution. Ed
Jun 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
152 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
