Question about APC Back-UPS 300 UPS System
I have a back UPS 300 an its not working. when there is a power outage the whole computer just shuts down. i recently replaced the battery too and its still not working. it is connected properly because the light is green meaning it is on..please help..thanks
    Guru:
  • 2,178 Answers
Check the battery Voltage - it may not be fully charged.
Posted on Dec 28, 2010
Computer restarts as soon as power goes off, its not an ups . When i manually turn off the power to the UPS, it switches / relay works fine, but if actually if there is a power outage the relay does not...
Your question is slightly confusing. Do you mean that the computer is not powered by a UPS? If the computer is not connected to the UPS, then why have a UPS? If the computer is not connected to the UPS and restarts when you turn the UPS On, your circuit feeding the UPS is overloaded and the voltage dips. If the computer is connected to the UPS, and restarts when there is a power outage, the fault may lie in the reaction of the HP 800. This unit looks to be a line interactive unit and it is not a true on-line UPS. The line interactive and battery backup (no voltage regulation) units both should have a switch to battery power time of 4 msecs, or less. If this unit is faulty and the switchover time is longer, it will not continue to hold up the computer internal power supply. If you are trying to run a laser printer on the HP unit, it won't have enough output capacity.
Feb 20, 2011 | HP Computers & Internet
What problems do these technologies solve in UPS?
1. Provide conditioned clean AC power to computers & other peripherals (except laser printers, which should not be powered by UPS).
2. Protect equipment from the harmful effects of brownouts & sags.
3. Supply power to equipment during a power outage for a specific time, either to allow for the graceful shut down of systems, or to keep the systems working during the power outage (depending on the battery capacity).
Jul 17, 2009 | Fenton Technologies Computers & Internet
UPS shuts down when the mains is off.
Hi
After 3 years, i would by a new UPS...
The battery will have to be changed if you want to keep the old one.
What i've seen mostly here in south africa. When the battery life has ended they customer opens the ups and takes out the battery and then connects a car battery to the terminals. The then close the ups and let the car battery stand outside the ups.
Hope this info helps...
Apr 26, 2009 | Powercom BNT-600AP (bnt600ap) UPS System
Fellowes UPS 425AP
where the model u using is 4 to 5 yrs so as well the battery too normally the battery life spam is up to 2 to 3 yrs and slowly the battery efficenit start to wore off.. the cost of changing the battery it also not cheap. ard 200 to 300 dollar in the market. well if you hav the in attendtion to buy a new ups i suggest the brand is APC or liebert. i recommend u the APC it will be sua750i or Liebert gxt2-1500rt230 both model is user friendly and easy to configue. and it has a very effiecent of excute proper OS shut down when power sugre is occur. and this durablity it higer can maintain up to 5 yrs above. if u need asst on what kind of ups u refer pls mi know will try to help up... thkss
Mar 26, 2009 | Fellowes 99052 UPS 425VA Battery Backup...
My universal battery do not have enough back up.
Cpcute,
Yes, initial charge should be for 24 hours before initial use (in general).
The UPS is an Uninterrupted Power Supply and is intended to Power your system in the case of a Main Power Failure long enough for you to Save/Backup your work and shut down your system safely so you don't lose data. Five minutes should be plenty of time to do this? It's not intended for you to continue using your system throughout the Power Outage. The UPS will/should let you know when the Battery needs to be replace, so when it does let you know, replace it at your earliest convenience and it should continue to function as it should.
Good luck.
Mar 20, 2009 | Computers & Internet
Battery Backup/Surge Protector Question
Considering the low draw of power you intend for the UPS it will work well. I have two monitors on a strip plugged into UPS along with desktop, routers and modems, UPS handles all well, it's just shortens battery backup times. Have had to power down from outages several times without any probs.
Jan 30, 2009 | APC Back-UPS RS Battery Backup (apw...
ONLY 2 MINUTES MAX OF BATTERY BACK-UP TIME BEFORE EVERYTHING SHUT
you can program your power bottom to hibernate, and connect the screen direct without the UPS, so you get more time...then when the electricity goes off, without seeing the screen just push the power bottom to hibernate.
Dec 03, 2008 | Minuteman Office Plus 500 UPS System
Ups troubles
What is happening here is you are transferring load to battery during a power outage but on return of Line Power the UPS is not smoothly transferring back to Normal mode. As a result you are basically turning off your computer. Two options... shut down your computer orderly during an outage or buy a new UPS.
DD
Dynamic Power Solutions LLC
Aug 20, 2008 | Computers & Internet
Dynex Te685avr backup battery doesnt work
If the battery outlets do not work, typically the Dynex TE685AVR UPS (battery backup) just needs a new battery. These batteries usually last 3-5 years.
The model of the battery is a WKA12-7.5F2 and can be purchased at: http://www.replacementupsbattery.com/Product_pages/wka12-75f2.html.
Jun 26, 2008 | Dynex (TE685AVR) UPS System
APC Back-UPS 300 UPS System Logo
97 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
