Question about Bose Acoustic Wave (32022) 5-Disc CD Changer
It won't play disks and just makes a lot of mechanical noises as it goes from disk to disk trying to play one.
  • Bose Master
  • 6,771 Answers
The mechanical parts are working but the laser pickup assembly is not reading the disc. The possible causes are, dirty laser pickup lens, bad pladder motor, or no b+ to the motor, or worn out laser assembly system. Because of the expense of buying the Bose units I highly recommend a professional service man to work on the item.
Posted on Dec 28, 2010
PS3 won't accept certain disks. A few disks i have won't play in my ps3. it happens to both blu-ray movies and games, and it seems to only happen with blu ray disks. i'll put the disk in, and...
Hello
The noise is actually a product of dust from a blue ray disc.Over time these discs heat up and leave a residue on the blue ray lens.
Try using a lens cleaner to remove dirt and clean lens.
Also i read an article that using a wireless controler can also cause freezing of the blue ray.
Oct 01, 2011 | Sony Playstation 3 (PS3) Console
When I insert any game, my ps3 will make the loading noise and then it won't even show the disc under the game category, meaning it won't play games, only movies??
there could be a possible error with your disk reader/ blu ray. If you still have it under warrenty get a new one, if not call up playstation and try and sort something out.
Jun 01, 2011 | Video Game Consoles & Games
My RCA RTD317 has problems recognizing most DVD movie disks. It will play some disks most of the time and all audio disks, so I figure the lasers are working. What could be the problem?
If you've tried cleaning the Laser with a Lens Cleaner Disk or directly with Lens Cleaner Fluid and a QTip without any improvement then the Laser is Failing.
It takes less power to read some DVDs than others and a lot less power to read an Audio CD. The Laser will continue to deteriorate until it won't play anything.
May 08, 2011 | RCA RTD317 Theater System
My united will not play. when loading makes load noise, spins then stops. eather says no disc orun known. tryed a lot of dvds. did show that it was loading but that has stoped also
Sounds like a hardware problem.
This is typical when one one of the DVD mechanism (motor fails, laser can't track, etc).
Although you can try some sort of DVD cleaning disk, or better yet
if mechanically inclined you can open it up and clean the DVD head and motor mechanisms manually.
Search here, or on the web on the steps to open up and clean them.
If it's still under warranty, call manufacture technical or customer support for a possible replacement.
Jul 20, 2010 | iLO DVDR05 DVD Recorder
Will not play DVD, makes rubbing noise when DVD goes around, then says cannot play this disc
If it has a paper label on it That can cause the rubbing sound. Is it only this one DVD or will non play? Try using a cleaning disk to remove mess from the laser eye, as well as cleaning this problem disk with a suitable disk cleaning kit
remove any paper labels if it is possible
Please rate my help++++Thanks for uisng FIXYA
Jun 11, 2010 | Sony DVP-NS715P DVD Player
Won't read diisc and makes funny noise
Check first to make sure there are not Two (2) disks in the tray.
The disk may not be seated completely in the tray.
The disk may be upside down.
Try a different disk. If it plays properly, the disk in question is probably bad
Read Ya,
Z
Jan 01, 2010 | Televison & Video
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Very noisey
It depends, is it noisy when you play a game from DVD or just when it is running ? From Xbox, you can expect that it is just as noisy as computer without a silent fan.
If it is noisy when playing a game, it is normal since it's loading everything from the disk and Microsoft made the disk to spin fast so you won't have to spend a lot of time waiting before the game loads.
Then, if it is only when you play a game - i recommed for you to install it to your hard-drive, that way the console won't have to use the disk to load everything.
Dec 31, 2008 | Microsoft Xbox 360 Console
Audiovox MVDVD4
Just stumbled upon this as I was searching for a new MVDVD4 and thought it might help you out!! :
When the van was a little over 3 years old, the DVD player suddenly quit working. I would put in a DVD, the player made some noises like it was trying to read the DVD, then the display would say "NO DISK".
As it was out of warranty and I have a background in electronics, I opened the player. After playing around for a little while, I was able to fix the player real easily. If you have the same problem (and the player is out of warranty), open up the DVD player by removing the screws and breaking the seal. I blew out the inside with compressed air, but I doubt this made a difference. The problem was that the DVD was not spinning. The spinning mechanism under the DVD tray was not starting like it should. I carefully sprayed a couple drops of WD-40 (well actually Remington's Rem Oil) where the metal rod the spinner sits on goes into the motor mechanism that spins it (it will make sense when you look inside. It is where the little metal rod goes into the plastic casing). After a couple of drops of oil, the player worked fine again.
Mar 02, 2008 | Audiovox MVDVD4 Car Video Player
Problem with disc drive
You didn?t mention the type of disk (something you burned or bought) or the physical condition of the disks (brand new, some scratches or lots) but if they?re commercial CDs or DVDs and you can play them in another laptop or player you should be able to play them in your laptop consistently. About the only thing I would recommend doing to a new laptop drive still in warranty would be to clean the drive using a commercial CD cleaning disk. If you still have trouble reading commercial CDs that play in other devices I would contact the manufacturer?s technical support for repair.
Nov 26, 2006 | Dell Inspiron XPS M140 Notebook
Bose Acoustic Wave  (32022) 5-Disc CD Changer Logo
737 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
