My samsung ty model TI-14B3 from the front pane menu the tv lock all the pane control key , know the remote can not operate and the menu key also con not operate
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Posted on Feb 19, 2008
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: accidentally locked out of my TV
1) Try P-Lock and pasword "0000"
2) Turn TV off and unplug from wall outlet for 30 seconds
3) Check p. 9 and other relevant sections of your user manual.
4) Call Insignia at 1-877-467-4289
Posted on May 26, 2008
gcrcomputers
  • 170 Answers
SOURCE: I cannot program my Directv RC 23 remote to operate my Polaroid t
Here is the list from Direct tv with your Polaroid TV Codes:
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341
***Note: White remotes RC16, RC23, and RC24 may not be programmable to some later TV models
I hope this helps,
David
If my solution helped please rate accordingly
Posted on Mar 17, 2009
SOURCE: Samsung LCD "keys locked"
I have the same problem, but when i turn off the monitor from the power (plug out) for 10 sec and plug in again the keys work for a while ore much longer but again get locked. Myabe it's connector's fault, i'm using VGA cable
Posted on Mar 18, 2009
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
What do i do to my Union LCD TV, the remote control doesn't work now and the side buttons when i press this words will appear "Key locked" ... i don't know what to do now .. please help me.. ty
Key lock function is now ON with your TV, and side panel key won't work any more, till it has been unlocked. But, if you want to unlock the key-lock function, your remote control must be OK. First check the remote control for its infra-red emission. Surf the site linked below. It has details about how to check a remote control. If remote control is found OK, the remote sensor inside the TV might be faulty, and should be replaced. Anyway, at present condition, you've to make the remote control to work with TV, to proceed any more. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 03, 2013 | Televison & Video
The remote and control panel are locked on my 52" LED LCD tv.
Hello
To unlock the remote control function do the following.
On the front pane touch control pad
1 Press MENU to display the MENU screen, and then
press VOL[--/+] to select "System Options".
2 Press CH [UP/DOWN] to select "Operation Lock Out", and
then press INPUT.
3 Press CH UP/DOWN] to select "Off", and then press INPUT
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
OK.
Feb 16, 2011 | Sharp LC52LE810UN 52 in LCD TV
My greentech tv was locked and dont know how to unlock it.so far only black screen appear with red key logo under the screen.
Hello
To unlock your RCA tv try the folloing. One amoung this method will surely unlock your TV. NB: Before trying each method be sure to switch OFF and switch ON your tv with its FRONT PANEL POWER CONTROL SWITCH.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jan 16, 2011 | RCA TruFlat 27F520T 27" TV
I locked up my set by mistake need to unlock it and adjust channel for directv I lost my remote use the front keys which caused initial problem tried to adjust volume hit channel key
Hello
Tounlock your TV you surely need its remote control. Try to get it from somewhere, from any one of your friends, who own the similar model of TV, or buy it from RCA. After getting it try the following. You can unlock it.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
Jan 10, 2011 | RCA TruFlat 27F520T 27" TV
I can't get the parental block off,I don't know the code.
Hello
You can unlock your RCA tv without knowing it parential code. After unlok, you have to set ti with a new passcode. Try the following. One amoung these procedures will surely unlock your TV.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jan 03, 2011 | RCA TruFlat 27F520T 27" TV
Cant turn on set and remote wont work, how can I reset tv and remote to work after our grandchildren locked the fromt buttons ans remote?
hello it sound like the key lock has been activated
The TV can be set up so that it can only be operated with
the remote control.
This feature can be used to prevent unauthorized viewing.
This TV is programmed to remember which option it was
last set to even if you turn the TV off.
Press the MENU button on the remote
control, then use the UP/DOWN arrow
button to select the Special menu.
Press the RIGHT arrow button to activate
the Special menu.
Use the UP/DOWN arrow button to
choose Key lock, then press the RIGHT
arrow button.
Use the UP/DOWN arrow button to select
On or Off.
Press EXIT button to save and return to
TV viewing or press the MENU button to
save and return to the previous menu.
the remote control.
Language
Main Source
PIP Source
Captions
Caption/Text
ARC
Key lock G
Auto Convergence
Auto Move
F Back Next G
SETUP
VIIDEO
AUDIIO
TIIME
LOCK
SPECIIAL
On
Off
With the KEY LOCK ON, the display
'KEY LOCK' appears on the screen if
any button on the front panel is
pressed while viewing the TV.
which option it was last set to
even if you turn the TV off. good luck
regards
shaun
Dec 12, 2010 | Zenith R56W36 56" Rear Projection...
My sis gave me an old samsung tv. It is just for my son and his x-box. Unfortunately there is no remote control. When switched on it is saying PANEL LOCK. Is there any way i can fix this. Model No TI-14N3....
hello you could try this The front panel of the COMBI VISION can be locked to prevent it
from being used by young children for example.
1 To lock the front panel, display the television menu by pressing MENU
2 Select the SETUP option by pressing the P ▲ or ▼ buttons the required
number of times.
3 Press the + button.
4 Select the PANEL LOCK option by pressing the P ▲ or ▼ buttons the
required number of times.
5 Select ON by pressing the + button.
Result: The buttons on the front panel no longer have any effect.
6 To unlock the front panel, set the PANEL LOCK option to OFF.Another option would be to buy a universal remote from say - Argos carefully open it and use your own batteries and use that remote to unlock the TV then return the remote to Argos or if keep the remote if the original is lost. i hope it helps
regards
shaun
Jan 12, 2010 | Samsung Televison & Video
Turn off child lock
To unlock the Panel Lock, Parent Lock, or Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Note: If you don't have a remote, you may be able to do the same thing by pressing the Menu button on the front or side panel of your TV and using the volume or channel up and down buttons on the TV to scroll to the Key Lock function and set it to Off.
Oct 02, 2007 | Televison & Video
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
