Question about Maytag Neptune MAH5500B Front Load Washer
When spinning sounds like maybe a bearing is going out and the unit is now leaking water from the bottom
    Novelist:
  • 222 Answers
If sound is to much noise during spin and water leak in tub unit,we need to replace bearing,but not an ordinary or by you to replace the bearing only the service technician can do dat coz of hard to remove some part of washing machine,but check also the price and labor cost before the final changing of the bearing,if your unit is old one,try to get the new one,coz after you replace the bearing some part also wort out after a month.if the price is reasonable to replace,replace it.
Posted on Dec 28, 2010
Kenmore Elite Oasis Top Load Automatic Washer Model 2708 When spinning it makes very loud noise. Also water leaks out the bottom when in operation
Sounds like the main outer tub and bearing assembly is bad. Water has(is) leaking through the main center seal, through the bearings(noise your hearing is these bearings) The tub and bearings with seal and center shaft come as a assembly, not a inexpensive repair. Also the water is getting on a little electronic board called the roto position sensor which can fail, found as part of the motor assembly on the bottom. Causes corrosion on the connection to the wiring. Your main problem is the outer tub assembly........ Good luck.......(I would also suggest you unplug the drain motor(some have a recirculation pump also) to make sure while spinning empty to run only the main motor that this is for sure the noise and water leak if this is your first repair)
Sep 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Fridgeair dishwasher not working making loud sound. water comes in and I can make it drain out but washer does not start
Hello
bearings in the heater fan may get worn out or rust. If this happens, it may become very noisy, either grinding on the bearings, or scraping against the rust. If this happens you need to replace the fan motor. Sometimes, a fan blade may come loose, and you need to replace it.
Sometimes it's the motor that makes the noise you hear. The motor has bearings in it which may become worn or get rusty. When the bearings get worn, they allow the shaft to wobble which can get quite loud. If there is a spin seal leak, water may get inside the motor, washing the bearing grease away. If the spin seal is leaking, you'll notice water leaking from under the dishwasher. There is also a disc attached to the top of the motor called a slinger. It sometimes breaks off and spins around the motor's shaft while it turns, causing some noises. You will need to replace the motor if the bearings are bad. You also need to replace the motor if the slinger is broken as well.
Newer dishwashers may make a squealing or rattling noise on the first run. This is because it has not had any water in it yet, and the motor seals are dry. You may hear this in a unit that hasn't been run in a week or more as well. You should operate the dishwasher regularly to keep the sump water from getting smelly, and to keep the seals lubricated. You can add a quart of water to the sump before running it.
Rattling noises may be produced by dishes rattling inside the dishwasher due to the water pressure from the sprayer arms on the dishes. To determine if the rattling is a loading issue, run the unit empty. If the sound is persistent, it may be that there is debris in the pump.
dishwasher water-inlet valves are noted to make a hum that lasts about 60-90 seconds several times during a washing cycle. This hum is a different hum than the sound of the motor running.
A rhythmic knocking or thumping sound may be caused the sprayer arms hitting something as they go around and around. Rearrange the dishes and resume the wash.
A clunking or clanking may be heard when the detergent cup opens; while a clicking sound may be produced by the timer or electronic control panel.
A solenoid makes a snap sound when it opens. This happens about six times during each load.
Pipes rattling or banging may be caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The sound is caused by the water slamming into the closed section of pipe. A plumber can install an anti-hammer device.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and then remove the item that is making the noise or replace the pump. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher.
Send this page to your printer
Aug 06, 2011 | Dishwashers
How to change the bottom spin bearing?
Two bearings in that model One in tub will be leaking water if bad. One on the lower end of transmission.which is part of the transmission. Whole tub basket unit must be removed from the case to replace either the tub bearing and seal or the transmission.
Nov 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
My top load when it spins it makes a loud noise sounds like a huge fan spinning or tires squaling
The bearings are bad. Perhaps had water leak into them. Maybe just age. Replace main bearing or... Call repair guy or... look at replacing machine
Nov 10, 2010 | Magic Chef Washing Machines
LAST SPIN SOUNDS LIKE LAWNMORE, IS THA NORMAL
It may be due to heavy usage or water leak at the bottom of the unit if you find any water leak kindly replace the two inner bearing along with the water seal top solve your problem
May 08, 2010 | Whirlpool Washing Machines
Loud crunching noise when spinning really noisey
The bearings of the basket, are damage, maybe due to water leaking and getting rusted, or maybe the shocks are also wearing off. expensive fix on the drum basket.
Jan 17, 2010 | Hotpoint WMA58 Front Load Washer
Very loud on high speed spin cycle Sounds like jet turbine Frigidaire Model FWSB67RGS0 almost 10 years old. Was given to me. Don't know if it has always been this loud.
Most likely the tub seal on the bottom is starting to leak water onto the bearing under the tub and now the bearing is starting to go bad.
Jan 01, 2010 | Washing Machines
Leaking water while agitating
it sounds like a bad bearing... the tub is leaking it may leak into the bearing and cause your transmission to lose oil and water ...
Nov 29, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
Jul 20, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore 110-91564100 Top Load Washer Problem
Sounds like my 91 Geo Merto LOL! Anywho when it washes the pump spins one way and water is basically thrown back into the tub, then when on spin it spins in the opposite direction and if there is a hose leak past the pump or the pump itself leaks it will come out of the drain system. As for the thump, check under the unit for anything that shouldnt be under there getting caught up in the mechanics. Let us know :-)
Sep 14, 2007 | Kenmore 23822 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
79 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
