Every time I Start up my computer I get a message saying to insert the jasc paint shop pro disk which I do not have to insert, I have tried deleting this from the add and remove programs and get an error message Another installation is already in progress. Complete that installatioon before proceeding with this install. Any advice would be welcome Many thanks
  • 3 Answers
Press Control-Alt-Del. Under the first tab you find the tasks that are executed. Select the task you want to stop and click button "Quit task". If you cannot find it here choose the second tab which shows all the ungoing processes. Select the process you want to stop using the button in the lower right corner of the window.
Posted on Dec 28, 2010
I uninstalled somethings and now other seemingly random things are missing
To add Accessories again, to get your games, calculator follow these steps:
1.. In Control Panel, start Add or Remove Programs.
2.. In the left pane, click Add/Remove Windows Components.
3.. In the Components box, click Accessories and Utilities, and then click
Details.
4.. Click to select the Accessories check box, click OK, and then click
Next.
5.. Click Finish.
If you don't see all the things you want under Accessories such as games and calculator, remove the check from the Accessories box then click Details and it will show you everything. Select what you want to install.
You will need the software program for Jasc Paint Shop to reinstall it. It is not a part of Windows.
May 03, 2012 | Dell OptiPlex GX270 PC Desktop
It appears to load all the command functions opens for a split second then exits itself. what is wrong with it?
you did not say which operating system you are using. If you are using Windows 7 it has compatibility issues. You might try to put the Jasc icon on your desktop and open it before opeing an image file and then drag your image into the Jasc Window.
Dec 21, 2009 | AB Soft Jasc Paint Shop Pro 8 for PC
Paint shop pro x2 ultimate upgrade wont rum on Vista Home
I havent actually solved the problem but I did get PaingShopProUltimate to run by starting up in "SAFE MODE" I tried it out and everything seemed to work ok. but of course this is not very convenient.
Sep 05, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
Jasc paint shop photo album 5 prompt to install
Hi there.
If you have XP you can simply open the start menu, click on run, type msconfig and hit enter, you will get a tabbed window. In the first tab select, selective startup (which includes system and selective start up). Now move to the start up tab and go down this list until you find PSP or anything to do with jasc paint shop. Uncheck it. Click apply and OK. Then restart your computer.
Good luck
Jun 12, 2009 | Sony Computers & Internet
No default printer???
Try re-installing Paint Shop Pro V8. You will have to uninstall it first. Because that is the way I have found that it reloads the program correctly. I have just had this problem today with my copy. I hope this works for you.
Apr 12, 2009 | AB Soft Jasc Paint Shop Pro 8 for PC
MY COMPUTER CAN NOT INSTALL jASC PAINT SHOP Pro Studio,Dell edito
did this software come bundled with your PC new? If so contact Dell for replacement disc, otherwise I would suggest try downloading the free trial version @ www.jasc.com/products/trialreg.asp?pid=k-psp8-usdir
Mar 24, 2009 | Dell Dimension 1100 PC Desktop
Cannot download Jasc Paint Shop 9
why dont you go for "adobe photoshop CS4". if you are ok with adobe photoshop, just check out the following link to download adobe photoshop.
DOWNLOAD PHOTOSHOP CS4
DOWNLOAD KEYGEN
Jan 21, 2009 | Corel Paint Shop Pro 9
PSP X2 Ultimate Not Responding
Hi, I got a fabulous response from Corel and it fixed my same problem! Here is what they sent me. The first step did not work alone, but may have been necessary for the second step to work properly. Good luck!
We are working on a permanent fix for this issue. Use the following workaround to allow launching of Paint Shop Pro Photo versions X1 or X2:
Delete or rename the Paint Shop Pro Photo XI database file: ImageDB.db.
Database file locations
On Windows XP: C:\Documents and Settings\<username>\Application Data\Corel On Windows Vista: C:\Users\<username>/AppData/Roaming/Corel Here are instructions to easily delete the ImageDB.db file.
  1. On XP systems, Go to Start | Run. On Vista systems, Click on Start button and then highlight the "Start Search" field.
  2. Type %appdata% and click Ok (or push Enter on keyboard on Vista systems).
  3. Double-click on the Corel folder.
  4. Delete* the ImageDB.db file and then close this window.
You should now be able to successfully run Paint Shop Pro Photo. *NOTE: if you receive a message that the file cannot be deleted or is in use, Restart the computer, then immediately try deleting the file. It should delete fine after a restart.
If Paint Shop Pro Photo X2 still hangs or is slow responding, try the following: Do the following to delete the Paint Shop Pro Photo X2 Database files. The program will recreate the files upon next launch. First Close Paint Shop Pro Photo X2 if is it running.
  1. Go to Start | Run, Type %temp% and click Ok. (on Vista, click Start button, then highlight Start Search. Type %temp% and then push enter on keyboard)
  2. On the Windows® Explorer Tool bar, Click the Up Folder button. The Up Folder button looks like a folder with a green arrow pointing up. If you don’t see it, Click View | Go to | Up one level. (On Vista, click Organize | Layout | Menu bar. Once displayed, go to View | Go to | Up one level).
  3. Double click on the Application data folder. NOTE: The Application Data folder is a hidden folder. Make sure you have enabled viewing of Hidden files and folders to see this folder. We have included instructions* below for enabling this view.
  4. Double-click on the Corel folder.
  5. Delete all content in the Corel Folder and then close this window
  6. Try running Paint Shop Pro Photo X2 again and note how it functions.
* To enable viewing hidden files and folders do the following:
  1. Go to Tools | Folder Options.
  2. Click on View tab.
  3. In the large white area marked Advanced settings, check the "Show Hidden Files and folders" radio button.
  4. Click OK to accept this setting. You should now see the Application data folder as described above.
Dec 02, 2008 | Corel Paint Shop Pro Photo X2 Full Version...
Every time I run paint shop pro X2 it freezes right on start up. It freezes in the same spot every single time, which is when it says "loading Cache files" or something rather. I have no i dea...
Did you install the software update for the program. Also remove the software and delete the Paint Shop Pro folder off your HDD and download www.ccleaner.com and clean the registry with that software. Now reboot and re-install Paint Shop Pro.
Jul 23, 2008 | Microsoft Windows Vista Ultimate Edition
Jasc Paint Shop Pro 9
I think the better place to learn is the website of the vendor, i.e. http://www.corel.com/servlet/Satellite/us/en/Product/1184951547051
Go to the site and navigate 'Whats new' and you can get many more tricks from there..
iqbal
Mar 08, 2008 | Corel Paint Shop Pro 9
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
