Question about Home
Eljer Titan 17" tank fills
  • 43,501 Answers
What you need to fix that is the part #1 in this picture...
http://www.plumbingsupply.com/eljertoiletparts-titan.html
This will get your toilet working again...
heatman101
Posted on Dec 29, 2010
Korky anti-siphon. Tank water slowly drops, accompanied by a hissing sound. Then, after dropping about 1/2 inch, it refills. Wha?
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl slowly...causing the fill valve to run every few minutes or so. hope this helps but if you need anything else just text me here:)
Jul 29, 2011 | Lavelle Industries Korky& Universal Toilet...
My toilet keeps leaking water and then fill ups on its own. Where could the leak be how do I fix it? Also I have to hold down the flush lever awhile for the toilet to completely flush. Can this be fixed ?...
If you are not getting puddles on the floor then it is probably the 'FLAP" that holds the water in the tank. It is the rubber part that is connected to your handle. Any hardware store will carry that part since it is an item that will fail, especially in hard water. It is probably the cause of both problems.
Jul 25, 2011 | Eljer & Titan Elongated Toilet Bowl
Elijer Diplomat toilet flushes perfectly, but after the water in the bowl takes forever to fill up again. You have to wait 10-15 min. before the water is up to normal level and it will then flush...
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
Jan 28, 2011 | Eljer Aqua-Saver 12" Two-Piece...
The bowl will not hold water. This is the second toilet we tried because Kohler thought it may be a faulty tank but same problem. Everything works correctly in the tank but after flushing the bowl will...
the tube that goes from the fill valve to the fill tube may not be installed correctly. the water must be going in the tube and not the tank. also it is a water conserving toilet so it uses less water also it is a comfort height toilet and to make it taller the bowl is extended so the water may seem even more shallow.
Jan 18, 2011 | Kohler Highline - Comfort Height Two-Piece...
The refill water in the toilet bowl is low ever since installation. How can I add more water?
Most toilets use less bowl water. But to check yours, be sure that the little plastic refill hose goes down the overflow tube.
Sep 14, 2010 | Eljer & Titan Elongated Toilet Bowl
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
Low water level in bowl after flushing
The small black tube that goes into the overflow is used to fill the bowl after flushing. Would check to make sure that water is coming out of that tube at full force or if its coming out at all.
May 11, 2010 | Eljer & Elongated Toilet Bowl
No water in bowl
check the water stopper in the bottom of the tank is it closing all the way.
Apr 25, 2010 | Eljer & Elongated Toilet Bowl
Super low water level in bowl decreases after flush refills
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
Jun 16, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
In the tank, when I flush, water comes shooting out of the black plastic thing, about 2 feet high! How can I make this stop so it flushes properly again? (its an eljer 2001)
is the black thing between the the tank and the bowl?
if so, go to any of the home center or plumping store for the seal.
shunt off the water and unbolt the 3 bolts that holds the tank to the bowl from the buttom. you may need a flat screw driver to help hold the bolts. pull up the tank slowly, and lay it on the side, replace the seal, reseat the tank on to the bowl and tighten the bolts. make sure all bolts are equal pressure and the tank is level.
May 05, 2009 | Eljer & Patriot& Elongated Toilet Bowl
Home Logo
18 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
