Question about RCA Televison & Video
I have an rca tv model j27330bl, can not program channels.
3 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: Cannot get channels programmed for RCA F27615
The chassis used in this set is one of several that are known for problems caused by bad solder connections. RCA used the metal shield around the tuner section to provide ground connections for several circuits. Cracks develop and all sorts of funny problems start to pop up. Tuning problems such as you describe are one of them. Often the troubles can be fixed by resoldering the required areas. Sometimes the bad connections can lead to failure of the memory chip that stores TV settings and data for the computer, but replacements are easy to find. A TV shop should be able to do the repair for you. RCA had several technical bulletins about this, although they never really admitted it was a design flaw, and there was a class-action lawsuit that resulted in a lot of repairs under an extended warranty.
Posted on Jun 19, 2009
TODDAS
  • 431 Answers
SOURCE: Just bought an RCA
There's no way to reset factory default but can access service menu, Hold down menu button on front panel and press volume up and power at the same time, on the top right screen, use volume up, Press to scroll to 72, press volume up and your are in the service menu.
Posted on Nov 12, 2011
Just bought an RCA tv that came from a hotel,model # J27330BL, and trying to reset to factory defaults as it only allows certain channels to be utilized. Also, trying to get reset so I can switch to...
Aug 20, 2011 | RCA F27442 27" TV
I have a Sylvania 6424FF tv and i cant get it programmed to a univeral RCA remote the codes listed are NOT working
Hello
RCA- RCU 500 model universal remote has Sylvania TV coded with. The codes are:
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
Jun 14, 2011 | Sylvania 6424FF TV
RCA TV model F27252GY. Don't think I have original remote. Need to set to input or video channel to use my new DVD. How do I do this?
You can try channeling up or down to get to channel 99.Rca in the past has used this to get to the video input. If this does not work you can buy a universal remote. In most cases, after programming the universal remote the major functions such as channel select, volume control and input select will work.
I hope this helps.
Skyassoc
Dec 12, 2010 | RCA F27252GY 27" TV
Need help to program my new T.V. to my remote
hold down code until it stays lit, then press tv then keep hitting channel up or channel down (either one can be used, keep pressing channel button til tv changes channels when it does press enter, or ok if enter is not there, it may take awhile maybe a few channel pushes up to 200 and up times, you use this method when you don't know the code for your tv. Hope this helps.
Nov 30, 2009 | RCA D770 Remote Control
Jun 19, 2009 | RCA F27615 27" TV
Cannot program new phillips remote to rca tv
[http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1] follow this web link it will take you to the RCA customer support web page for programming universal remote controls and lists codes under system components. The television codes for the universal remote are listed under TV. This web page should be able to help you solve your problems with the programming of the universal remote control and give you the codes needed to use it with the components in your system. Thank you for using FixYa and have a nice day!
Dec 02, 2008 | RCA DIRECTV Satellite Remote Control
I was given a rca j27330bl tv when hotel switched to plasma and channels are very limited and does not allow to change the set up
I also am not able to program the channels with the menu on the tv or with the remote. I contacted RCA and they were absolutely no help. Does anyone know how to reset these tvs??
May 02, 2008 | Televison & Video
Programming my rca universal remote for basic cable the stations wont turn
I can only suggest that you Double check you have the connections correctly set ie. coax ariel to ,(dvd /digi box reciever ect...)
Also check again (& i know this is state the obvious)
your tv manual. IF you havent a manual do a google search for your tv (make & model) & search for a manual.
Ive have had a simmular experience when programming channels to a Vid-Recorder & when i finished the channels dissapeared.
I realised I didnt have the video set to the correct channel with the tv usually channel 9 or the highest channel on the tv.
So i waisted a good half hour for nothing.
Dec 09, 2007 | RCA Universal Remote Control
Rca tv
1) Buy RCA remote part # 240895 original about $25.00
2) Enter channel 00 for video sometimes works
3) Channel down 4-3-2-Vid 1, Vid 2, etc. sometimes works
4) Try Auto-Program Channels selection ( can be accessed on
front of set buttons or remote
Let me know ...........................................T.
Nov 04, 2007 | RCA F32649 32" TV
Televison & Video Logo
106 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
