Question about Maytag Neptune MDE5500AY Electric Dryer
Clothes are now taking much longer to dry. I have cleaned the dryer vent & vent hose. ( all the way to the roof as I did once before that rectified the problem then.) Wet lint is around the door and also over the lint catcher on the metal. Thanks
  • Maytag Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Jan 03, 2011
JLTDC01 Dryer not collecting water in the tank
ck your vent hose,there may be a block vent not allowing air to move around clothes , causeing long drying times.if vent hose is ran long way.more then 4ft say 15 or longer,it should be cleaned once a year or replaced.this in my opinion is the most main problem when having dryer issues.
Feb 25, 2013 | Dryers
Dryer takes too long to dry clothes. Heating element is working because clothes are hot but it takes almost 2 dry cycles to dry clothes.
It sounds like you're lacking air flow. I'm sure you're cleaning the lint trap / filter - but have you clean the VENT HOSE / PIPE?
The 4 in vent hose is supposed to be cleaned annually. If you have the flexible vinyl hose, replace it with either steel, aluminum or flexible aluminum tubing instead. Once you've removed the vinyl hose, it will collect a lot less dust and can be cleaned without worry of puncture.
A typical dryer vent brush.
Make sure there's no obstruction to the flap outside, too. Once cleaned the dryer operation should be restored to new again.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 09, 2011 | Dryers
I cleaned the vent but it still takes to long to dry
if it is heating well, then you have a ventilation problem,make sure lint trap is clean if so disconnect dryer vent hose from dryer turn dryer back on put your hand where vent is make sure good hot air is comming out if so dry a load of clothes without vent tube connected,they should dry in a normal amount of time ,if so then your dryer hose is either bent too much or collasped,if hose looks good then it will be vent leadinding outside you can take a leaf blower and put in vent and blow it out,your dryer either vents on the side of the house or the roof turn dryer on put your hand on exterior vent make sure air is coming through
Jan 23, 2011 | Dryers
Whirlpool gas dryer heats but wont dry the clothes
If your
Dryer Maintenance
heatman101
Dec 14, 2010 | Whirlpool LGB6300 Gas Dryer
Doesn't dry fast
The first thing I will ask is this: does it take several cycles to dry? if so, its most likely the vent and not the dryer especially if it vents on the roof...I would say to be sure, remove vent off of rear of dryer and try a regular load of clothes...if they dry with hose off...your vent is clogged and needs to be cleaned..the screen on the roof vent usually gets clogged with lint...
Nov 28, 2010 | Kenmore Elite HE4 Electric Dryer
Taking long time to dry the clothes
Due to a dryer either heats or no heat , I would suggest pulling the dryer out and removing the vent hose . Dry a load of clothes to see if they dry normally . If they do , this verifys that the vent hose is either kinked ( restricting air flow ) , or , if the vent runs UP inside the wall , there is a restriction between the inside vent hose to the outside vent . May have to go into the attic to clean .
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Electric Dryer takes too long to dry clothes. Hose/vent is not crimped or locked. How do I clean out the vent built into the wall and ends at my roof top?
Here's a trick I used on my laundromats with vertical exhaust vents on the dryers..
When the dryers began drying too slow, taking too much time, giving out too many refunds...
I resorted to climbing on the roof with a webster duster... it looks like a chimney sweep brush on a telescoping pole.
I turned the dryers on and while they were running, ran the webster duster down the vent pipe.. It cleaned out the duct very well! I got "linted" but it worked!
Remember that the vent run should not be too long. If it gets too long, it will not stay clean and it will take too long to dry as well. if this is a recurring condition, you may want to consider a reroute of the duct.
Also, the exhaust end should be free flowing... no screen. A self-closing flap is okay, but no screen..it will simply clog up the works...
Try the webster... they sell them at the local grocery store... they come with their own extension pole too!
Let me know how it goes!
k
May 29, 2009 | Oregon Scientific Electric PTO Clutch for...
Needs 2 drying cycles
I am assuming you are cleaning the lint filter. Check the vent pipe out the back. If it vents into the wall, the piping leading to outside may be plugged. Your washer is spinning the clothes good, right? If the clothes are excessively wet they will take longer to dry also. If its practical, remove the vent hose and let it dry blowing into the room. It may suck but just once for a test.
Mar 06, 2008 | Roper REX4634KQ Electric Dryer
Laundry taking too long to dry!
1. Make sure the filter is clean. A clean filter allows for proper air circulation in the dryer.
2. Make sure the rear dryer vent is clean. Move the dryer, unplug it and remove the rear vent hose and clean out any debris from the vent, in the hose and any debris in the outside vent.
Over time, these things get clogged and reduces the air circulation in the dryer, causing it to take longer for the clothes to dry.
Please let me know if I can be of further assistance to you.
- Jim
Feb 14, 2008 | Dryers
Cleaned vent hose, dryer still taking forever to dry clothes.
you have a family of squirrels living in the rest of the vent tube which is leading outside...check vent outside. I once had flying squirrels come into my house through the dryer vent! My dog had a kitten.
Jun 04, 2007 | Whirlpool GCEM2990LQ Electric Commercial...
Maytag Neptune MDE5500AY Electric Dryer Logo
70 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
