Question about Dryers
I have a 4 wired pig tail...dryer has 3 terminals...can I connect the ground wire to the neutral terminal?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Match the red to red, black to black, white to center. Remove the green from the center terminal that connects to the case and terminate it back on the center white terminal. Hook the green from the cord to the cabinet where you removed the green from in previous step. Be sure the black and red wires are on the outside terminals!
Posted on Dec 29, 2010
Switching 3 prong cord to a 4 prong cord
if theres a wire from the center terminal on the dryer terminal board going to the dryer case disconnect it,then Red & Black on the cord go to the outer 2 terminals on the dryer terminal board,the White goes to the terminal in the center between where you put the Red & Black wires this is the Neutral wire,then the Green wire connects to any metallic portion on the dryer case as this is the SAFETY Ground wire and also Red & Black can go on either outer terminal on the dryer terminal board as these are not polarity sensitive because its A.C. power so wire it on the dryer terminal board as in (RED-WHITE-BLACK) on the dryer terminal strip and connect the GREEN to any Metallic portion of the dryer case
Dec 30, 2012 | GE Profile Harmony DPGT750EC Electric...
I have estate dryer by whirlpool that came with a 3 prong cord and I changed it 4 prong because my outlet is ,4 and on my dryer I dont have a bonding strap but a green ground wire connected to the middle...
no,you need to connect the green wire to any metallic part of the dryer,even if the white wire on the neutral terminal has a bonding strap from this terminal to the metallic dryer case as you should never connect more than one wire under any type of terminal unless otherwise specified by the manufacturer
Apr 20, 2012 | Whirlpool Dryers
Trying to change plug from a 3pronge hookup to a 4.The dryer only has 3 wires to hook up extenstion plug has white,red,black,green ...what do i do
It is your responsibility
 To contact a qualified electrical installer.
 To be sure that the electrical connection is adequate and in
conformance with the National Electrical Code, ANSI/NFPA
70-latest edition and all local codes and ordinances.
The National Electric Code requires a 4-wire supply
connection for homes built after 1996, dryer circuits involved
in remodeling after 1996, and all mobile home installations.
A copy of the above code standards can be obtained from:
National Fire Protection Association, One Batterymarch Park,
Quincy, MA 02269.
 To supply the required 3 or 4 wire, single phase, 120/240 volt,
60 Hz., AC only electrical supply (or 3 or 4 wire, 120/208 volt
electrical supply, if specified on the serial/rating plate) on a
separate 30-amp circuit, fused on both sides of the line. A
time-delay fuse or circuit breaker is recommended. Connect
to an individual branch circuit. Do not have a fuse in the
neutral or grounding circuit.
 Do not use an extension cord.
 If codes permit and a separate ground wire is used, it is
recommended that a qualified electrician determine that the
ground path is adequate.
Electrical Connection
To properly install your dryer, you must determine the type of
electrical connection you will be using and follow the instructions
provided for it here.
 If local codes do not permit the connection of a neutral ground
wire to the neutral wire, see "Optional 3-wire connection"
section.
 This dryer is manufactured ready to install with a 3-wire
electrical supply connection. The neutral ground wire is
permanently connected to the neutral conductor (white wire)
within the dryer. If the dryer is installed with a 4-wire electrical
supply connection, the neutral ground wire must be removed
from the external ground conductor screw (green screw), and
secured under the neutral terminal (center or white wire) of the
terminal block. When the neutral ground wire is secured under
the neutral terminal (center or white wire) of the terminal block,
the dryer cabinet is isolated from the neutral conductor.
 A 4-wire power supply connection must be used when the
appliance is installed in a location where grounding through
the neutral conductor is prohibited. Grounding through the
neutral is prohibited for (1) new branch-circuit installations,
(2) mobile homes, (3) recreational vehicles, and (4) areas
where local codes prohibit grounding through the neutral
conductors.
Sep 23, 2011 | Estate EED4100SQ Electric Dryer
Hook up a 4 prong plug in the back of a 3 prong series 90 dryer. What wire go to which screw?
If its a four prong cord your wires should definitely be color coded. There should be a black, red, white, and green wire. Since the dryer was a 3 prong wired dryer originally your going to see a terminal that is (or was if it was removed already) jumpered to the frame of the dryer using a piece of metal. Your going to remove that piece of metal. Now the one terminal (not the frame) will be where you connect your white wire or neutral. The other terminal the the neutral terminal was jumpered to is where you will connect your green or ground wire. This allows for the dryer to separate the ground terminal and and neutral terminal in case of ground fault situation. There will be only two terminals left which are your hot terminals for the black and red wires. Order on these hot terminals doesn't matter however I recommend to keep it neat you don't cross any wires and keep each hot wire on the side it falls on.
May 12, 2010 | Dryers
How do i connect the wires on my GE dryer from a 3 prong to a 4 prong withour the gterminal block? My terminal block is missing.
The following link explains how to properly convert a 3-prong power cord to a 4-prong:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
The main difference is how the Neutral and Ground wires are terminated. In a 4-wire configuration, the Ground and Neutral are INDEPENDENT of each and are NOT terminated together.
Match the correcsponding wire colors at the terminal block and make sure the grounding strap (if installed)on the Neutral (White) terminal is removed. The ground wire will be connected separately to a ground lug on the equipment cabinet.
NOTE: If the wires are not color coded, the outer two wires (left and right) are the HOT leads. The center conductor is Neutral.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 01, 2010 | GE DBL333EA Electric Dryer
Change the dryer cord from 3 prong to four prong
Feb 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Connecting 4-wire cord to GE profile dryer
The following link explains how to properly install a 4-wire power cord to your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference between a 3-wire and 4-wire configuration is how the ground and neutral wires are terminated.
In a 3-wire configuration the wires are terminated together at the terminal block via a ground strap.
In a 4-wire configuration the two wires are independent of one another. Match the corresponding colored wires at the terminal block and attach the ground wire to the ground lug on the equipment cabinet.
I hope this explains it well enough for you. If you still have questions, please let me know.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
Change 4 plug out and put in 3 prong plugs it runs but no heat
The main difference between the 4-prong and 3-prong configuration is how the ground and neutral wires are connected at the terminal block.
The color codes are as follows:
RED - HOT (120 VAC)
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND
You simply match the corresponding colors with the wires present at the terminal block on the back of the dryer. In a 3-wire configuration, however, neutral and ground are connected together. This is done by connecting the ground wire from the equipment cabinet to the neutral wire at the terminal block.
In a 4-wire configuration these two wires are INDEPENDENT of each other and are not connected.
Please note that in homes built after the year 2000 it is REQUIRED to have a 4-wire configuration to be within the National Electrical Code.
If the wires at the terminal block are not color coded, Red and Black will be connected to the outer two terminals (left and right) of the terminal block, while neutral will be connected to the center terminal.
If you need more guidance, the following link explains:
If you have any questions, please let me know. I hope this helps you.
Aug 22, 2009 | Dryers
MY DRYER IS NOT HEATING UP. 220 VOLT CONNECTION ON BACK OF DRYER- NEED WIRING DIAGRAM OR WHERE DOES BLACK WIRE GET ATTATCHED IN BACK OF DRYER. THERE IS A BLACK WIRE HANGING THAT IS CONNECTED TO A BLACK BOX...
The following link explains how to correctly install a power cord to the terminal block of a dryer:
Take note of the difference between a 4-wire and 3-wire configuration. The color codes for both installations are as follows:
RED - HOT (120 VAC)
GREEN - Ground
The main difference between the two configurations is how the Neutral wire and Ground wire is installed.
In a 3-wire configuration ground and neutral are connected together at the terminal block.
In a 4-wire configuration ground and neutral are INDEPENDENT of each other. Neutral is terminated at the terminal block, while ground is terminated on a ground lug on the equipment cabinet.
If you have any questions, please let me know. I hope you find this information helpful.
Aug 21, 2009 | Dryers
Electric dryer internal short
Make sure that the dryer is disconnected from the wall outlet before doing any repairs on it. Electric dryer work on 240 volts AC and this could hurt or even kill you. loose connection on the terminal block will cause the wires to get hot. and melt the terminal block and wires and the pig tail wires. you will have to replace the terminal block and pig tail wires and make sure you use the correct bolts and make sure you tighen them. let me know if this helps.krazytech
Sep 09, 2007 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
