Question about Mercury P4VM800M7 Motherboard
Crashin, freezing, and a random system clock
My system kept crashing with both my usual and backup HDD I shut down all applications to hunt for a software problem but still had the same results, noticed then that the clock would come up with random times and dates even after being reset.then the system would not boot up. changed the bios battery, system would boot up but with no aplications running it still freezes requiring dirty shutdown and the clock/date jumps forward randomly 20-30 years even after being reset manually
tried several batteries same results
any clues??????????????
  • 1 more comment
  • casoffice Jul 08, 2008
    Cheers Christianalo will look into this solution
    but the system is sun running unix not accer
  • ffsman Oct 27, 2008
    ******* peice of **** is what it is i got same problem on biostar p4m8000 m7 8.0 the goddamned chipset isn't even detected by sissandra or everest
  • Anonymous Nov 18, 2008
    Have exactly the same problems as above. Still no solution. Re-installed
    Windows Vista 64bit version and all other softwares including games and no change.
    Mike
    Problem Solver:
  • 9 Answers
Try to update your bios with the newest version from Accer I have had a couple like this in the past. It seens that the firmware running the realtime clock sometimes causes all kinds of problems if it is currupt software and hardware
Posted on Jul 07, 2008
Fix freezing windows 7
Get a hammer and beat it to death.
You don't specify what type of "freeze" it is doing.
Just locks up?
Jul 01, 2015 | Microsoft Windows 7 Ultimate for PC
Problems with random shut downs, freezing (especially while playing media) and touchpad randomly stopping
You may have to many running processes, use this procedure to speedup Windows Vista: http://www.pcworld.com/article/143538/windows_vista.html Make sure your Windows and Dell Updates are current and up-to-date. Have you cleaned the fan, vents, and heatsink with Compressed Air? Is the Laptop getting sufficient air flow? Use these two freeware programs to cleanup your Laptop. 1, CCLEANER: http://www.filehippo.com/download_ccleaner/ Use the cleaner and registry to remove junk and free up HDD space. In the TOOLS section, select STARTUP, disable ALL unnecessary startup/running programs, this will free up memory. 2, MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK the Trial Pro version, you want the freeware version, run a FULL scan, delete ALL results, reboot. You can find ALL your Dell Drivers here: http://www.dell.com/support/drivers/us/en/04/Product/inspiron-1545
May 26, 2013 | Dell Inspiron 1545 Notebook
Satellite PSAGCA-06M01N keeps restarting when i try to upgrade windows
Computer randomly restarts is not something unique happened to you. Sometimes there is a dreadful total crash of the system and sometime it sends different errors, upon restarting nothing happens.
-- First of all disable the auto-restart option from your control panel settings
-- Remove any recently installed maliciously software/add-on or any other application or toolbar.
-- Try to cool down your PC as the overheating due to overuse of computer may result in system freezing and sudden restarting.
-- Update your BIOS.
-- Update the drivers
-- Make it sure the error is not caused by the deficient power supply. You may try to change the power supply.
-- Conduct the registry clean up scan for quick fix of the problem.
-- Remove flashy games and/or untrusted antiviruses/antispywares. Conduct the security scan through the most powerful scanners only.
I would recommend to use a system utility tool like PCFresher to fix windows errors and registry errors. Then try updating hope problem is fixed.
Apr 29, 2012 | Computers & Internet
Randomly shuts down. Dell Inspiron 1000 with battery removed it will usually get past login and stay up for a while all hibernation options have been turned off.
check that it is not heated up Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Aug 31, 2010 | Dell Inspiron 1000 Notebook
My computer is shutting down on its own. Is this
May 15, 2010 | Dell Dimension 3000 PC Desktop
Inspiron 531 freezes
You have to do some maintenance cleaning and check up. Both hardware and software. As this age usually two years.One common failure is the harddrive. You should get some backup procedure. As for software you may do the following. 1. Registry cleaning (Ccleaner is good but be careful also) 2. Application cleaning, uninstalling those program not needed in the system. 3. Log and history cleaning. 4. Defrag is good. 5. And virus scanning it also one of the major cause of system freezes. 6. And unloading some files (back it up then unload) As for hardware. You may do some dusting or reseating. Usually the CPU fans and system fans and its airways.
Jun 08, 2009 | Dell Inspiron 530 Desktop Computer
My lenove 3000 N100 just keeps randomly shutting down, with full battery. what do i do?
Hello.The laptop doesn`t get hot? This is usually the problem that causes the system to crash and shut down to prevent hardware damages.
Jun 05, 2009 | Lenovo 3000 N100 Notebook PC
Automatic shutdown, crashing applications & no startup repair
Yes, sounds like some of you applications may have become corrupted. It happens over time. Find the backup program if XP >start>accessories>system tools>backup on Vista just type "backup" in the start box. You will see and option to back up all of your docs., email, web favorites, etc. Back them up then use the Windows disc reload the operating system You will also, have to reload your applications. That will take care of it. Good luck and let me know if you have any questions. Don't forget to rate this solution with 4 stars before you log out.
Feb 10, 2009 | Acer Aspire 4315 Notebook
Crash
Some of HP's laptops had an issue with the motherboard. They're not going to broadcast the info but at least one motherboad has been recalled and will be replaced by HP if you do your homework. This means searching their site for forums on recalls. Googleing your model along with words like recall, wirelless, motherboard, etc..
Dec 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Problems with my HP DV2000
replace the HDD with Proper one for ur laptop.
HDD: Hard Disk
Aug 18, 2008 | Dell Latitude D600 Notebook
Mercury P4VM800M7 Motherboard Logo
109 people viewed this question
Top Mercury Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Roshan Rijal
Roshan Rijal
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
