Question about Kodak Office Equipment & Supplies
Compaq Laptop Kodak Aio esp3 printer (printer works on other laptop Dell) printer shows ready but won't print Access to path C:\programFiles(x86)\Kodak\Printer\Center\ updateurl.txt is denied Downloaded driver for Windows 7 also said, in search of problem, "current security settings do not allow this file to be loaded." All I have is the Windows Firewall on and it is on a medium setting.
  • 5 Answers
SOURCE: Kodak AiO home Center will not open
My son has the same model and issue. I had him go to http://www.kodak.com/global/en/service/downloads/dln_ekn034524.jhtml?pq-path=12667 and get the latest software and firmware update.
Make sure to use the dropdown to select your operating system. The page defaults to XP.
The software is a new version of the AIO home center.
The firmware installer updates the physical printer. Before you run this program be sure to read and understand the instructions.
If both ink cartridges have good levels of ink, and you keep getting the clean the print head issue after updating both the software and the firmware, then call Kodak support. 1-800-421-6699, 7 A.M. to midnight Eastern time, 7 days a week. They will ask you if you put in new cartridges and installed the updates for the firmware and the AiO centre software. Be patient. They will get a solution for you.
Posted on Jan 17, 2009
  • 3 Answers
SOURCE: how do i remove printhead from the kodak esp3,cannot find it.
Pull up the grey lock and it will release.
Posted on Feb 01, 2009
  • 60 Answers
SOURCE: the kodak aio home center won't open getting error
if using vista try this:
Right-click on the Home Center icon.
Select Properties.
Select the Compatibility tab.
Click Run this program as administrator.
Click OK.
reply if does not work.........
Posted on Jun 27, 2009
  • 60 Answers
SOURCE: Battling between KODAK AIO 7 vs Dell wireless laptop.
try this
  1. Open the Printers folder:
  2. XP Operating System: Select Start > Settings > Printers and Faxes.
  • VISTA Operating System: Select Start > Control Panel > Printers.
  1. Delete all ESP 7 and ESP 9 printers from the folder. The printers are listed as "KodakESP7+xxxx" or "KodakESP9+xxxx", where xxxx can be any number.
  2. Close the Printers folder.
  3. Press Ctrl + Alt + Delete on your computer keyboard, then select Task Manager.
  4. Select the Processes tab.
  5. Stop each of the following processes. For each process, click the process, then click End Process.
  6. AiOHomeCenter.exe
  • EasyShare.exe
  • EKDiscovery.exe
  • EKIJ5000MUI.exe
  • KodakSvc.exe
  • mDNSResponder.exe
  1. Power cycle the printer. (Press the power button to turn off the printer. Wait approximately 30 seconds, then press the power button to turn on the printer.)
  2. Open the home center software.
  3. Click Install Kodak Printer in the bottom right corner of the home center to add your all-in-one printer to your computer.
let me know if this worked or not.......
Posted on Jul 08, 2009
SOURCE: Error code 1-2036 on Kodak ESP3 printer
To askmeprinter: following your recommended steps does fix the problem TEMPORARILY. The scanner will work after being re-installed, but will cease working again after going into sleep mode.
Posted on Jul 30, 2009
I have a wire less router the ESP3 kodak rinter is connected to my desktop and the desktop to the wire less router. How can I have my laptop print on the ESP 3 via the wireless router?
go into control panel and printers
right click on the printer and click share, then go onto the laptop and add printer and tell it its a network printer and search for it then once you have done that you can print from your laptop
Feb 13, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3 printer will not connect with Windows 7
On June 8,2010 Kodak released a new driver for ESP3 printer.
Version 5.3.0 for Window 7
Download it HERE
Jul 08, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I clean the print head for a kodak printer
This is for Kodak AiO printer that has home center software installed
1.On your computer, start the KODAK AiO Home Center software.
2.Click the Help (?) icon located at the upper-right corner of the Home Center window
3.From the Help toolbar, select Maintenance.
4.Click Printhead Cleaning, and wait for the printer to complete the cleaning.
If there is NO Kodak AiO home Center software installed
1. 5100 printer HOME CENTER should be use or open the printer access door wait for the printhead to move at the middle then close the printer access door forcing the printehead to eject ink on the printhead nozzle
2.5300 & 5500 printer press the MENU button > select CLEAN PRINTHEAD > then select BASIC/DEEP CLEAN
3. ESP3 printer [press and hold at the same time COPY and CANCEL button for atleast 10 sec or until the printer start moving]
Nov 13, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
The kodak aio home center won't open getting error 1--2010 esp3 printer
Select Properties.
Click OK.
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Need to clean the heads but can't find instructions to do it.
To clean the printhead press: COPY and CANCEL at the same time.
To print a test page press: QUALTITY and CANCEL at the same time.
Go to Kodak AIO home center, click on the"?" and open the "user guide" for the complete manual. Wish they put in a printed version, put they don't. Good luck with the printer, mind has been nothing but problems. And keep trick of what you print. You will be shocked at the low output. Report it to Kodak and they might sent you new inks.
Bob D.
May 26, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
try this
  • EasyShare.exe
  • EKDiscovery.exe
  • EKIJ5000MUI.exe
  • KodakSvc.exe
  • mDNSResponder.exe
May 15, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Cannot add printer to PC on network
heres a link for drivers for your machine.....download the proper driver for each individual system and run setup application
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540
Apr 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
KODAK AiO Home Center has encountered a problem
you need to uninstall the software and reinstall it, if you have not tried that. For XP Start-->control panel-->add/remove programme-->look for Kodak Printer software and uninstall it. For Vista Start-->control panel-->programmes and features and uninstall the software. Run the Kodak clear utility from http://unexpectedtwist4u.com/matthew and click on clear utility and you can either run it or save it first and then run it. Make sure to unplug the USB cable after uninstalling the software and reinstall the software from www.kodak.com/go/esp3downloads. Kodak phone support is open from 9 am to 12 midnight EST. Hope that works:)
Feb 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
94 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
