We had an old 1970s fan heater in the ceiling of the kitchen that was attached to a light switch to turn on/off. We want to attach a light fixture to the ceiling where the heater was and use the same switch. I have allready attached it a troubleshot the problem, but for some reason the light wont turn on.
    Master:
  • 381 Answers
Sounds like we need to do some tracing of history over they years:
1.) How long has the heater NOT been used? (Has it been removed?)
2.) Since a heater draws considerable current-- It likely was on a separate circuit.
Could that circuit have been re-wired to some other load in the house?
Or could that circuit have tripped?- or blown a fuse?
3.) Has the switched remained connected to this circuit all this time?
Is the switch still turning on and off the light? (or did I just mis-understand that statement?)
Give us more information, so we can help you further.
Mack B
Posted on Dec 28, 2010
I am trying to install a ceiling fan and from the ceiling I have a copper white and black wire. Now from the fan itself there is a black blue and white wire. Not sure where to connect the copper wire.
Good question, proper wiring is a crucial virtue that needs to be one hundred percent accurate.
Three wires showing from the ceiling lamp fixture harness, positive, negative, and ground.
The negative wire is the white wire,
The Hot wire (positive) is the wire of brighter color than known negative,
220V AC (alternating current) home wiring to(" duplex outlet switch, GFI switch, single/dual pole light switch, lamp fixtures,") the Hot wire or lead, is normally Black, the lighter color, or White is neutral or neggative,
Neutral wire (completes circuit) allows current flow to continue through to other parts of house, Alternating current.
The Ground wire is usually wrapped in green color, or unmarked copper.
The copper wire from the ceiling will need to be grounded to the metal bracket on the new light fixture, a gold or silver screw, sometimes tagged with green, is the proper grounding location, Any place on Metal not attached to ceiling bracket, Ground should be attached to metal on fan,
White wire from Fan is neutral, Negative.
Black wire from Fan is Hot Wire, Positive,
If Blue wire from Fan is Not Manufacture spliced, Meaning no Copper is exposed, Wire is not used, Blue wire is NOT ground,
If Fan has a light, Voltage from Hot Black wire will supply both light and fan functions,
Safety First.
flip off breaker switch to the room fan is being installed.
Doubble Check
Black^Black wire connection is secure.
White^White neutral wire connection is secure.
Ground is fastened securely to metal or wrapped under a screw.
Using splice caps is recomended, The plastic shell encloses the wire connection ensuring No stray copper is exposed, limits possibility of cross wiring.
Google the brand of fan being installed, and Check wire color code, and wiring diagram, Info good to have, and checking twice will only guarantee Lamp Fixture Install Well Done.
(Blue wire may be there for installing multiple ceiling fixtures in a loop circuit, so all controlled by same light switch.)
Enjoy Your New Fan,
Jos
Thoughts&Comments, encouraged jtobias1020@gmail.com
Mar 26, 2017 | Dryers
Electrical/wiring for a pendant fixture
white - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Dec 29, 2013 | Dryers
My ceiling fan has two pull chains The pull chain for the light broke too short. When it broke the light was off. Now I don't have a ceiling light for my kitchen. How can I replace the pull cord?
You will need to replace the pull cord switch. It is inexpensive. You will need to open up the fixture and reemove the old one. Usually it is held on with a nut. If you are not sure of what switch to buy, take out the old one and bring it to a hardware store. Make sure the power is off. Cut the two line to the old switch and splice in the new switch with wire nuts, also use some electrical tape to insulate the connection. Reinstall the nut and close up the fixture. Good luck.
Oct 05, 2011 | Hampton Bay 52 In. White Redington...
We purchased a house that is more than 10 years old. The ceiling fan w/light does not turn on with the wireless remote that is attached to the wall and there is not other switch but this one to turn it on....
You need to know if there is power to the fixture. If there is , then you might need to replace the receiver. It should be under the canopy where the power is connected for the fan.
Sep 01, 2011 | Hunter Ceiling Fan Light Remote Control
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
Hello, All of a sudden my kitchen ceiling lights are acting flakey...here is the problem. There are two ceiling fixtures, both of them were controlled by two separate on/off switches on opposite ends of...
I would suggest you call in an Electrician. It sounds like there is a definate short somewhere and if you don't address the issue immediately, there could be a very real issue of a fire. Please do not put this off as something that may fix it's self. hope this helps.
Oct 12, 2009 | Hunter 52" Ceiling Fan With Light And...
We are installing a lighting fixture on our Casablanca 4944D Concentra. We can get current across the various wires, but can not get the light to turn on. The colors of the wires are blue, black, red,...
On ceiling fans, the blue wire is designated for the accessory light kit. If you are using the Casablanca kit, it should be wired with a matching plug that just, well, plugs into the fan.
If you are adding another brand of light kit, you only need to connect the blue wire (hot/common) to the black wire of the light being attached, and the white (neutral) to the white wire of the light being attached.
Your fan will not have a pull chain/switch for the light attachment, as that is normally supplied pre-wired and installed in the light accessory.
If in doubt about about the wiring, contact Casablanca for a manual showing what light kits are acceptable for adding onto your particular fan model.
Also, please turn off the power before connecting the light kit to the fan.
Hope that helps and best regards!
Jul 31, 2009 | Casablanca Fan 4944D Concentra Antique...
Fixing Ceiling Fan
An easy-to-install ceiling fan can make a real difference in your home's climate - both cooling and heating - at a far lower cost and operating expense than almost any other item.
The installation begins with choosing where the fan should be located. In almost all homes, the fan is installed in the center of the room, replacing a central light fixture. This spot provides a smooth air flow to most of the room. Since a fan draws about the same power as a ceiling fixture, the electrical circuit shouldn't be overloaded. But if your fan includes lights, be sure the circuit it's on has enough extra capacity to handle the load. If not, you must run a new circuit with a new circuit breaker from the house main service panel or subpanel to the fan. If there is no central light fixture, you'll have to create a place to hang the ceiling fan. Then, you'll need to bring electrical power to it. You can tap into an existing circuit to do this.
Sep 25, 2008 | Dryers
Problem with Hampton Bay 54 In. Flemish Pewter Ceiling Fan With Heater
did you check the circuit breaker to see if its tripped?im assuming the voltage rating of the wires your decribing are 110 volts and the fan likewise.the white wire could possibly be a neutral wire,meaning you should hook up the red and black wire.let me know
Jul 30, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Ceiling fan
There's a rubber circle that is the damper between the blades and the motor shaft that rotates. The circle has spokes connecting the outer ring, which the blades screw into, to the inner ring which attaches to the shaft and holds it. If the spokes break you get the symptoms you describe, motor hums but no rotation, but blades can turn manually if you hand turn them them. If this is the case you need to remove and replace the blade mounting ring/damper. (About 25 bucks online)
Apr 27, 2006 | Hunter Sontera 52" Ceiling Fan with...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
