Question about Craftsman Garden
I have a two stage blower. the auger and the second stage turns slowly and I am unable to blow the snow effectively. Constantly sticking in the shoot.
  • 173 Answers
Sounds like you have a bad belt
Posted on Dec 29, 2010
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
Nov 26, 2016 | Garden
Loud noise when auger is engaged on 2 stage 24" 208cc
If this is covered with a warren tee I would take it back where I bought it. Sounds like a faulty bearing or something is sprung and hitting when it starts up.
Feb 08, 2014 | Yard Machines 24" 208cc Two Stage Snow...
Accidently hit stick in side yard. now wont throw snow. Everything else seems good
blower might still work but gear case that runs auger is shot or you sheared the shear pins in auger
Dec 17, 2013 | Yard Machines 31AS63EE700 208cc Gas 24-in...
Snow blower auger stops in snow
There are cotter pins on the second stage blower shaft. I would inspect these. Also, check sheer pins in front auger assembly.
Dec 03, 2013 | Garden
Snowblower augers wont turn
Did you check shear pins on shaft for auger
Apr 15, 2013 | Yard Machines Snow Blowers. 22 in....
My yardmachine snow blower 8hp auger won't turn. I replaced the cable and belt but it still won't turn. What else could be wrong?
Check the auger shear pins replace if necessary with correct parts(not regular bolts).
If auger and the impeller are not turning your cable is out of adjustment.
If only the auger doesn't turn, and the shear pins are ok then the brass/bronze gear has shredded which is why proper shear pins must be used. Donyboy73 on youtube show how to replace that gear on an older but similar MTD affiliated blower.
Feb 16, 2013 | Yard Machines 24" 208cc Two Stage Snow...
I have a snow king 5hp snow blower. while clearing snow, the snow only oozes out the shoot.
IT SOUNDS LIKE YOU HAVE A TWO STAGE SNOWBLOWER WITH ONLY ONE STAGE WORKING. I BET THAT YOUR PROBLEM IS THE AUGER IS TURNING BUT THE IMPELLER BLADE THAT IS BEHIND THE AUGER HAS PROBABLY JAMMED UP WITH SOMETHING AND IS SPINNING ON THE SHAFT. YOU WILL HAVE TO REACH BACK AND GRAB IT AND TRY TO TURN IT ON THE SHAFT BY HAND.MAKE SURE THE BLOWER IF OFF!!!! . IF YOU CAN TURN IT BY HAND EASILY IT HAS EITHER BROKE A SHEAR PIN OR BOLT OR SOME TIMES THEY WILL TACK WELD THEM TO THEM TO THE SHAFT. GOOD LUCK
Jan 17, 2011 | Tecumseh 5hp Engine Snow King Mtd Blowers...
On my two stage snow blower--main auger stops turning .
Hi, I figured out the problem. The gear transfer case between the augers must be broke. The auger spins slowly until it hits snow and then stops-- The discharge fan continues to spin fast. I will try to get a local handyman to fix it or else but a new machine, this one must be at least 15-16 years old.
I thank you for your help, it is a great service. ojohn
Dec 10, 2008 | Garden
Garden Logo
102 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
