Question about Kenmore 53642 / 53644 Side by Side Refrigerator
I have a side-by-side Kenmore refrigerator model #59762990, it have same cool air on both side which is good enough for the refrigerator site but not freezer side. Remove the back panel inside the freezer and no frost build up in evaporator coils, no clicking noise from relays or compressor.
SOURCE:
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
the dr
  • 447 Answers
SOURCE: inside fan motor - evaporator
Yes if you dont hear the evap fan wprking remove rear panel in freezer let me know what you see. Is coil iced over? Is fan running? Is the motor warm? Attempt to spin the blade gently to see if the motor is bound. You can oil these.
Posted on Dec 02, 2007
bobotfel
  • 241 Answers
SOURCE: kenmore freezer and fridge is not cold - not frost build up - compress anf fans are all running
You need a qualified technician for this problem.
- Your unit may have leaking try to check for oil traces.
- The system maybe restricted, system reprocess is needed for this unit.
- If the unit is no frost try to check if there is an air circulation inside the unit. If no air is present then check your fan motor inside.
Posted on Jan 11, 2008
docjohn174
  • 943 Answers
SOURCE: Frost build up in freezer/ very little cold air is blowing down to the bottom
HI thanks for your question. look to see if you can hear the fan motor running. if it is check for frost build up. if frost build up. its not going into the defrost cycle. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
tech master
  • 120 Answers
SOURCE: kenmore fridge model#596.52679200 side by side
remove back cover on evaporator inside frezeer if is full of ice all over then you have a defrost problem and you might have a faulty defrost timer or defrost thermostat repl both so you wont go wrong if the coils are clean and not frost is on coils then check compressor to see if its running just by touching you can find out if it si not running then you have a faulty relay or overload repl and compressor should start.if there is only partial frost then you have a leak or restriction depending when you bought it most refrigerators have a maufactures warranty on compressor for about 5 years call for service on the number on the sticker inside refirgerator
Posted on Oct 14, 2008
Kenmore elite refrigerator/freezer displays error code "er rf" and the refrigerator section is not cooling. Error code resets when power is disconnected but reappears in a few hours.
Well Dennis...
Welcome to FIXYA... Were all the (FREE) fun
is about trying to figure out which machine you
might actually have: BEFORE attempting to
address your "problem"...
((no extra charge for including MODEL number))
I have read enough OWNER'S MANUALS to be
able to GENERALIZE...
(really a bit easier than quoting chapter & verse.
Most of the REFRIGERATOR to FREEZER issues
are caused by AIR-FLOW issues...
They very chilled air (in & about the FREEZER)
gets somehow BLOCKED from making it to the
REFRIGERATOR side...
MOST
common among those causes are food ITEMs
improperly placed blocking ADEQUATE air flow.
FREE fix... just read and follow OWNER's
manual instructions...!!
Suggested sites were community contributes
ideas & solution... Proper MAKE & MODEL
numbers ARE REQUIRED... but still FREE.
Appliance-part-pros
Search Over 2 1 Million Appliance Parts
RepairClinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
PartSelect
PartSelect Appliance Parts and Repair Help ...
Hope these inspire (comment back for better
resolution from me... I saunter by daily (still FREE).
Carnac the Magnificent
Jan 12, 2018 | Kenmore Refrigerators
Kenmore side by side - model - 253.54739304. we moved it from one house to another. it was working fine. now won't freeze or cool properly. like it is in defrost mode. compressor was not running...
if while moving it , you laid it on its side, it collected air in the lines, having it unplugged is a good idea, normally 24 hours is enough for the air to settle,, try it again after that time,
Jul 09, 2011 | Refrigerators
Kenmore coldspot model 106-54592400. The refrigerator is not getting cold enough, has been hovering around 45 to 50. The freezer is working.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 10, 2010 | Kenmore 50522 / 50524 Side by Side...
Have a Kenmore side by side model#363.58062893 the freezer side is cooling and making ice but the refrig. side is not cooling there is some cool air but not enough to keep food cool enough. Traci
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 17, 2010 | Kenmore Refrigerators
Model#10651562104 refrigerator side not cooling enough
heatman101
Aug 04, 2010 | Kenmore 51572 / 51574 Side by Side...
Can not reach cooling temperatures.
Clean all the dust and lint accumulation from under the unit, remove the condensation collection pan and clean it, and make sure the bottom fan is running.
I can't emphasize strongly enough how much of an enemy the accumulation of dirt and dust under a refrigerator can be its worst enemy. It can make the refrigerator exhibit symptoms of much more serious problems. Sometimes a good cleaning can have it operating like new with no real 'repairs' whatsoever.
Good Luck. Hope this helps.
Aug 28, 2009 | Kenmore 57029 Side by Side Refrigerator
Condensor running, some cool air on both sides, not cool enough
There are 2 things I an think of right off. the most likely is a defrost problem. Look at the back wall of you freezer compartment and look for snowy ice build up if so most likely culprit would be defrost termination switch. the switch is inexpensive and easy to replace. you will need to order it by your model and serial number.
the next not as likely problem would be a low freon charge this problem would require a good service company to repair for you.
Good luck peyton
Jan 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator is not cooling
Hello hazraan
Welcome.
You said your Kenmore model 60852990 freezer is working but refrigerator is not cooling.
Lets try a couple of ideas.
Is your freezer filled up where the packages are covering the air vents in the rear of the freezer?
Refrigerators and freezers must share the cold air and circulate between them. If the freezer is packed full with not enough space at the air vents in side it, the fridge will get warmer!
Next,Turn off the fridge and freezer controls, and then go to the breaker box and turn off the breaker to the fridge for 5 minutes!!!!!
Then restart it and the fridge and freezer controls.
This should reset the system and solve the problem. let me know if either were the case.
If either was the reason,it now will take some 8 to 12 hours to gets back to temperature.
Waiting your response.
Huuum, Please remember to leave a rating.
Oct 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator.
If you have determined that the evaporator fan in back of the freezer compartment is running, then you might have a stuck or broken air diffuser. The diffuser acts like a damper to divert air into the refrigerator compartment. Sometimes they jam or break due to frost buildup.
Jul 23, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
157 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
