Question about Broan-NuTone N-8663RP Combination Light Fan Exhaust Fan
Housing is stuck in 1 corner when trying to remove
    Sergeant:
    Champion:
  • 342 Answers
This should solve your problem
open this and the first figure has a picture of the dome housing
http://www.nutone.com/PDF/InstallGuides/8673RPins61784.pdf
Posted on Jan 01, 2011
How do i remove the PTO from an IH 856. The lower PTO shaft broke and the unit will not slide out
make sure all the bolts are out should be 1 short bolt and 8 long bolts to remove pto after that it is stuck to gasket. short bolt is in lower left corner of housing
Dec 26, 2012 | Farmall IH Tractor 706, 756, 806, 856,...
How do i get the headlight housing off of my 92 dodge caravan?
remove plastic grill screws2 then 1 screw on outside corner of headlight housing and open hood there is one long screw that needs removed then the headlight assy will almost fall off the vehicle.
Feb 17, 2011 | 1992 Dodge Caravan
Dishwasher does not fill with water. Moter or pump is running but machine will not fill with water.
The first thing to check is the float. Remove the lower rack, in the front right corner there is a plastic float that looks like a hat. Check to make sure something like a spoon is not stuck under it. The float should move up and down about 1/2" freely. If it is stuck up the dishwasher will not fill.
The second cause could be the house supply got shut off under the sink, this would only happen if you had someone working under there.
The last thing would be the water valve on the machine. If you take the two screws out of the lower kick panel it is located near the front left corner. It has 2 wires and 2 hoses going to it. If you have a meter you can check the coil for resistance or power to the valve when trying to fill.
Let me know if you have more questions.
Apr 30, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
How to remove the blower motor from a 1978 ford bronco full size truck?
Deluxe Hi-Lo Heater
  1. Disconnect the battery cable, remove the carburetor air cleaner and partially drain the coolant system.
  2. Remove the heater hoses from the heater core.
  3. Remove the glove box liner and remove the register duct by pulling from the instrument panel register and releasing the clip at the plenum.
  4. Disconnect the right cowl outside air inlet vacuum hose from the outside/recirculating door vacuum motor.
  5. Remove the rear housing from under the instrument panel. Remove the outside air inlet duct from the rear housing (4 nuts and 1 bolt) and install one upper nut to retain heater housing-to-dash after rear housing is removed.
  6. Remove two screws retaining plenum-to-dash (above transmission tunnel) and two screws to heater housing and remove the plenum.
  7. Install a piece of protective tape on A-pillar inner cowl panel, at lower right corner of instrument panel.
  8. Remove the lower right instrument panel-to-A-pillar bolt to hold the panel in the rearward position.
  9. Remove the heater core (3 screws retaining 2 plates).
  10. Remove the temperature blend door (snaps off).
  11. Remove the temperature blend door arm support (2 screws) and pivot arm retainer (1 screw).
  12. Remove blower motor (2 screws) and remove blower wheel.
To install:
  1. Transfer blower to blower motor and panel assembly.
  2. Install door arm pivot retainer (1 screw) and door arm support (2 screws).
  3. Install the temperature blend door (snaps on).
  4. Install heater core.
  5. Install the plenum (4 screws).
  6. Connect blower wires.
  7. Remove heater housing upper retaining nut and install the heater outlet (4 nuts and 1 bolt). Position the air inlet duct.
  8. Connect the white vacuum hose to the outside/recirculating door vacuum motor.
  9. Reposition the instrument panel, install the retaining bolts and remove the protective tape at the A-pillar inner cowl panel, lower right corner of instrument panel.
  10. Install the right register duct assembly and install the glove box liner.
  11. Connect heater hoses to the heater core assembly.
  12. Fill cooling system, install the air cleaner and connect the battery cable to the battery.
  13. Check blower motor operation.
Jan 19, 2010 | 1981 Ford Bronco
How do you change the turning signal on ford contour sport?
This is for the 95-97 Contour. 98+ are different, because the light housing changed completely.
1. Open the hood.
2. In each front corner of the hood, there is a torx bolt, head about the size of a nickel. Removing this one bolt allows you to remove the corner marker/turn signal housing.
3. Once the housing is free, you have access to the back of the bulb holder. If I recall correctly, it's a half-twist to remove, but I'm not sure. Could just be barbed clips, or something. Anyway, from here should be no problem to figure out how to remove and replace the bulb.
4. Replace corner marker/turn signal housing, and re-install torx bolt. That's it!
Oct 11, 2009 | 1997 Ford Contour
Cant open the access door to get to the lamp housing
2 possibilities.
1. On either side of the set just behind the lower left and right corners there are "thumbscrews". Loosen them and then pull the lower front off.
2. If there are no thumbscrews, just grab the front cover from the botton on either side and tug strongly, it will come off as it is held with small catches and springs.
Jun 03, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
'88 toyota camry rear window stuck in down position
To get to the Window:
Remove Door Inside Handle:
remove screw, slide the handle forward.
Disconnect the control link and remove the handle.
Remove Door Trim with Inner WeatherStrip:
Remove the two screws from the armrest.
Insert a screwdriver between the trim retainers and the door panel to pry it loose.  Eight hidden fasteners. 1 top left side of door.
1 right side about same height as top of armrest. 1 (each side) about same height as bottom of armrest. 1 on each corner bottom. 1 bottom in middle.  1 on left side between bottom corner and the previous at about lower armrest height...
Remove Service Hole cover.
Remove Door Glass Run.
Remove Division Bar (upper window section divider):
Remove the two screws under the weatherstrip
Remove the bolt.
Pull out the division bar.
Remove the Window Glass:
Place the glass in the door cavity.
Remove the two glass channel mounting bolts.
Remove the window glass by pulling it upwards.
You now have access to the Power Window Regulator; possible replacement of motor etc.
What type of 'things' have you tried for fixing the window and restoring operation?
Jan 22, 2009 | 1988 Toyota Camry
FLSE72GCSA top drum glide
remove screws holding console on ..2 on bottom rail and 1 in each lower corner of console they are recessed .console will drop slightly and off 1 screw in each corner of front panel be sure to not loose them they go in these spots only..flat heads..recommend removing large front panel between 2 units remove blower housing 2 clips or screws each corner lint screen housing on inside..reach through and remove belt this will make reassembly easier by removing downward pressure on drum ..
Jul 04, 2008 | Frigidaire FEX831CS Top Load Stacked...
Clicking nosie from scanner bed on epson cx5800f
I had a similar problem, the scanner bar was stuck to the far left side. Here's how I fixed it:
1)Unplug the printer, disconnect any cables/phone lines to it.
2)Lift up the entire scanner bed housing(you will see the printer ink cartridges).
3)Locate the access patch (approx 1 cm x 1 cm square) along the left edge of the scanner bed housing(this is the side that closes in, next to the keypad buttons).
4)Using a small knife blade, peel off the patch from the corners and edges(it's sticky. Save it, you can stick it back over the hole when you're done).
5)Stick a pen through the access hole, and push the scanner bar to the right, approximately 2-3 inches.
6)Now, close the scanner housing, plug in the printer, and power it on.
It should reset and re-calibrate the scanner bar. If it doesn't, repeat steps 5) and 6) a couple times, until the printer correctly performs calibration. Then, you can put the sticky patch back over the hole, and you're ready to go. Hope this helps!
Jun 28, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Replace tail light bulb
1. open tailgate. 2. remove corner floor piece by lifting. 3. remove corner side panel. pull out from tab on bottom. 4. remove two hex bolts(#10) to release light housing. they look like large allen wrenches. 5. replace bulb(s) and refasten again.
May 15, 2008 | 2004 Volvo XC90
Broan-NuTone N-8663RP Combination Light Fan Exhaust Fan Logo
73 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
