Question about Maytag Neptune MAH9700 Front Load Washer
Get stains on clothes after been washed.. noticed on new white shirts
    Novelist:
  • 222 Answers
What kind of stains like rust color.if yes you need to call a service technician to clean the unit,not an ordinary cleaning we need to dismantle the unit to replace the oil seal and bearing if worn out,but some is just for cleaning,some unit also stains came from the liquid softener,try the cycle wash and put the heater is high level to melt some liquid softener,try for 3 time without cloth inside if this is ok after that cycle no need to call technician,do it every month as a maintainance
Posted on Dec 28, 2010
How to remove grease stain from laundered shirt
How to Remove Grease Stains ' Stain Removal
www.howtocleanstuff.net > ... > Clothing & Fabrics > Stain Removal
Begin by blotting with a clean cloth to remove as much of the grease as possible. ... If your clothing is durable, spray oven cleaner on the stain and let it set for ...
Oct 07, 2015 | Washing Machines
How can I repair a bleach stain on a t-shirt
For an immediate treatment of a bleach stain, try Sodium Thiosulfate (often referred to as photographic fixer, it is an agent that has been used as a way to neutralize bleaching effects of other substances. Blot stain at first with a white cloth that has been dipped in ST until stain begins to disappear of fabric becomes saturated. Rinse with cold water and repeat until desired effect or no more progress has been made.
If you wanna get rid of the stain without using laboratory grade chemicals, use white vinegar. Before this, make sure you rinsed bleach out of fabric, if you don't it will release a toxic chlorine gas.
Soak a clean white cloth with vinegar and start blotting stain, keep doing this until fabric won't hold anymore.
Aug 06, 2014 | Clothing
Kenmore top loading washing machine does not clean clothes well.
I would seriously consider getting a newer machine. A brown stain could be rust, or an oil leak. Either way it probably is not worth putting any money into. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Kenmore Washing Machines
Black stains on white dress shirts
The rollers, guides, or wheels that are used to support the clothes drum may be worn out. When this happens, it may cause the drum to drop down slightly in the front or rear. Clothes can get caught between the front or rear of the drum and the dryer interior. This can cause clothing to have marks and/or tears. Check out the rollers, guides, and wheels for excessive wear or damage. Sure hope this helped ya!
Jul 20, 2009 | Whirlpool WGD5900S Gas Dryer
Round stains on clothing
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 11, 2009 | Kenmore 5.7 cu. ft. Coin Operated Electric...
WF860 doesn't clean the clothes at all!
Lack of water in wash cycles. possibly due to blocked filters in water valves where hoses connect to machine or faulty water valve, normally cold inlet is the main problem
Mar 30, 2009 | Hotpoint Ultima WF860 Front Load Washer
Grey Stains on my whites
Need ot check the main seal and the main bearing. You can do this by accessing the rear of the unit.
Feb 13, 2009 | EuroTech EWC177 Front Load Washer / Dryer
STAINED WHITE T-SHIRTS, DULL LINEN
Hi! I am a habitual cleaning type person and clean clothes rate at the top of my list. I have 4 recommendations that SHOULD help tremendously for ALL your clothes but is most evident in your whites.
#1 is the right washer. I NEVER knew how clean my clothes could come out till the past year and a half I finally bought front loader. And let me tell you was I ever surprised at how clean and soft they were, LIKE NEW! Those old top loaders,even the new ones are no comparison to the front loading systems. BUT expensive if you have to go out and buy a new one BUT also a GOOD excuse to tell hubby you need a new one...LOL
#2 Always use liquid detergents, they seem to wash and rinse out so much better than any powder
#3 A HUGE helping hand I discovered some 30 years back that I STILL have not found that can be beat is "BIZ" bleach. It's miraculous! It's a great pre-treater to soak badly needed whites in and helps to retain bright colors if used in non-white laundry. Actually I even use it in a powder form. AFter loading all my clothes in m y front loader I scoop out a cup and actually scatter it OVER my laundry. Then add the liquid detergent (Tide or the like, I get mine at Costco or Sam's club depending on what region you live in) and wash like normal.
#4 Last but not least, for whites and ALL colors I have found nothing better than DAWN dish washing liquid. Immediately pre-treat ANY stain no matter the size with Dawn and just fold it over and toss it in the laundry. Best if washed within the same week at the latest.
GOOD LUCK to all you Domestic Goddesses! ;-)~
Jan 19, 2009 | Washing Machines
My whites are not comming clean and are not a bright white
I don't know if this is a solution to your particular problem but when we wash whites, first, we wash them twice,with hot water, second, we dont use bleach!!! (this will eventually yellow them). Third, we dont use liquid softner. For the whites we use a softner sheet in the dryer. Since we started to use this procedure I have noticed a marked decrease in areas such as under arm stains in white under shirts. I have some that are 2 years old and have no stains or yellowing like this. Hope this helps
Jan 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH9700 Front Load Washer Logo
211 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
