I bought Grundig GU37FHD1080 tv from argos today. The tv is great, but there are no instructions or a button on the remote where you get Freeview listings or programme information for the evening. How do you get freeview viewing listings please?
There's an EPG button bottom right above the TV/RADIO button
Posted on Dec 30, 2010
Testimonial: "Thank you, not sure how EPG means tv guide but thank you x "
  • 1 more comment
  • 5407708 Jan 01, 2011
    If you plug a USB memory stick, or hard drive into the usb port at the back, you can also record programs, you can arrange to record later by selecting your program on the Electronic Program Guide, or press the rec button. you then need to select media as the source, and choose movies to view back what you have recorded
  • Diane Webb Jan 03, 2011
    your right, honestly, epg button shows all the listings I want. Thank you !!
  • shumon_84 Jan 12, 2011
    EPG = electronic programme guide
Its called epg on the remote
Posted on Jan 12, 2011
Which device button on a signalex 10 in 1 remote control do I press to set a freeview box
Signalex Universal Remote - instructions? ' AVForums
www.avforums.com > ... > Remote Controls
I have the instructions for this model URC22B (SK012) 15-in-1, if you can ... hi jeff,i need to control a goodmans tv, model no 295ns, hope u can help me, ... Press and hold button "SET" and press selected equipment button (ie TV1, .... iv just bought a poundland signalex universal remote which wont pick up my freeview box.
signalex 10-1 poundland remote simplified instructions ' eBay
www.ebay.co.uk > ... > Remote Controls
eBayTo Set Code Find your TV model (or other appliance) code; then you press and holdbutton "SET" and press selected equipment button (ie TV1, TV2, AUX, ...
Dec 21, 2015 | Televison & Video
Grundig gu37fhd1080
Hi Bill
It sounds like a fault with its main system control memory IC. Please contact any service technician, to confirm it. In most cases, this component might need replacement. Gopakumar Gopalan Google
Mar 07, 2014 | Televison & Video
Can't find sky remote code for grundig gu37fhd1080
Hello
Sky remote codes for Grundig are:
563 582 515 098 584 219 104 233 223 065 471
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
Aug 20, 2011 | Televison & Video
I have grundig lenaro 32"tv
Sounds like you're only viewing analogue channels.
Go into Menu and find Inputs and select & choose DTV. This will restore reception of Freeview (Digital TV) channels.
Mar 30, 2011 | Grundig Televison & Video
I cant make the freeview box work without the operating instructions
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box;
2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work;
3. Connect the SCART cable to Freeview box and the back of the TV;
4. Switch the TV on;
5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control.
B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
Good luck - I'll await your reply.
Regards,
BElectric
Feb 09, 2011 | Televison & Video
I require a user manual for grundig gdt1500
I also have this problem. I have sent a request to Grundig.co.uk. There is some information here:
http://support.thetechguys.com/layout.aspx?ID={28880c68-4c71-4f8f-b787-d81337345574}&CatID={68268fd3-68bd-4930-9469-e82274f9f26e}
It shows the connection layout and remote control functions.
Oct 11, 2009 | Grundig Televison & Video
20 year old Quasar colour TV (no remote)
That is because the switches of the front panel buttons are stuck or defective.
Try first unplugging power for ten minutes, this probably wont work.
To fix this the TV must be taken apart from an expert, and front panel replaced.
You can enquiry here for parts.
What you can do at home, is getting a replacement remote and using TV with a remote, or buying a freeview box, and watching and changing channels through the box.
You can get a replacement remote here: Replacement Remote Control orReplacement Remotes
My suggestion, if it is supported in your area, get a set top box with 30 channels : Freeview - digital TV from Argos.
Oct 11, 2008 | Quasar SP-2723 27" TV
TV controls not working
ARGOS SELL SPARES FOR ALL REMOTE CONTROL DEVICES ON THE ARGOS SPARES SITE. PRICEY BUT WORTH IT!
Oct 07, 2007 | LG 15LW1R 15 in. LCD Television
Televison & Video Logo
641 people viewed this question
Top Televison & Video Experts
Electro Med Services...
